pstorage won’t fire call back function
I’ trying to save some user configuration data on the NRF51822 Flash using pstorage module.
Below is the code that I wrote, the code runs on the board with no error and all the functions return 0 but the problem is that the pstorage call back function won’t call and the program never enter the call back function.
I put a break point inside the call back function and verify that.
Please give me some suggestions.
pstorage_handle_t       pstorage_handle;
pstorage_module_param_t pstorage_param;
pstorage_handle_t block_handle;
static void example_cb_handler(pstorage_handle_t  * handle,
                                uint8_t              op_code,
                                uint32_t             result,
                                uint8_t            * p_data,
                                uint32_t             data_len)
    switch(op_code)
        case PSTORAGE_LOAD_OP_CODE:
           if (result == NRF_SUCCESS)
               // Store operation successful.
               // Store operation failed.
           // Source memory can now be reused or freed.
        case PSTORAGE_UPDATE_OP_CODE:
               // Update operation successful.
               // Update operation failed.
       case PSTORAGE_CLEAR_OP_CODE:
               // Clear operation successful.
               // Clear operation failed.
			 case PSTORAGE_STORE_OP_CODE:
								oeration_done = 1;
int main(void){
	uint32_t err_code;
	err_code = pstorage_init();
	pstorage_param.block_size  = PSTORAGE_MIN_BLOCK_SIZE;
	pstorage_param.block_count = 10;
	pstorage_param.cb          = example_cb_handler;
	err_code = pstorage_register(&pstorage_param, &pstorage_handle);
	// Request to get identifier for 1st block.
	err_code = pstorage_block_identifier_get(&pstorage_handle, 1, &block_handle);
	err_code = pstorage_clear(&pstorage_handle,16);
	while(true);}
I’m using SDK 6.1.0 and softdevice s110 7.1.0, softdevice is programmed into the chip but i'm not using it right now.
    The pstorage module relies on the SoftDevice sd_flash API in order to work. You will have to initialize the softdevice prior to using the pstorage module. You can just copy the function "ble_stack_init" from any of the S110 example and call this prior to initing pstorage.
    Cheers, Håkon
