#define Macro syntax got Error message with nRF52840 SDK v15.2.0
Hi, I have a defined MACRO which I initialised the values of ble_gap_adv_params_t in main.c. I will pass this to the  function to start advertising. I used the example (ble_app_blinky_pca10056_s140) to try out.
However , I have two error messages.
1)  "expected expression before '{' token " in the line #define ADV_1M_LEGACY_CONNECTABLE {
2) "expected expression before ')' token in the function int main (void) {        line  m_adv_handle = advertising_init_common(&m_adv_data, ADV_1M_LEGACY_CONNECTABLE );
I wonder is my syntax of #define written wrongly or I cannot use this type.
#define ADV_1M_LEGACY_CONNECTABLE {               \
  .properties.type = BLE_GAP_ADV_TYPE_CONNECTABLE_SCANNABLE_UNDIRECTED, \
  .p_peer_addr = NULL,                                                  \
  .interval = APP_ADV_INTERVAL,                                         \
  .duration = APP_ADV_DURATION,                                         \
  .max_adv_evts = 0,                                                    \
  .channel_mask = 0,                                                    \
  .filter_policy = BLE_GAP_ADV_FP_ANY,                                  \
  .primary_phy = BLE_GAP_PHY_1MBPS,                                     \
  .secondary_phy = 0,                                                   \
  .set_id = 0,                                                          \
  .scan_req_notification = 0,                                          \
static uint8_t advertising_init_common(ble_gap_adv_data_t* ble_gap_adv_data,ble_gap_adv_params_t* adv_params)
    ret_code_t    err_code;
    ble_advdata_t advdata;
    ble_advdata_t srdata;
    uint8_t advHandle;
    ble_uuid_t adv_uuids[] = {{LBS_UUID_SERVICE, m_lbs.uuid_type}};
    // Build and set advertising data.
    memset(&ble_gap_adv_data->adv_data, 0, sizeof(ble_gap_adv_data->adv_data));
    advdata.name_type          = BLE_ADVDATA_FULL_NAME;
    advdata.include_appearance = true;
    advdata.flags              = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE;
    memset(&srdata, 0, sizeof(srdata));
    srdata.uuids_complete.uuid_cnt = sizeof(adv_uuids) / sizeof(adv_uuids[0]);
    srdata.uuids_complete.p_uuids  = adv_uuids;
    err_code = ble_advdata_encode(&advdata, ble_gap_adv_data->adv_data.p_data, &ble_gap_adv_data->adv_data.len);
    err_code = ble_advdata_encode(&srdata, ble_gap_adv_data->scan_rsp_data.p_data, &ble_gap_adv_data->scan_rsp_data.len);
    // Set advertising parameters.
   err_code = sd_ble_gap_adv_set_configure(&advHandle, ble_gap_adv_data, &adv_params);
   return advHandle;
    // Initialize.
    log_init();
    leds_init();
    timers_init();
    buttons_init();
    power_management_init();
    ble_stack_init();
    gap_params_init();
    gatt_init();
    services_init();
    //advertising_init();
    conn_params_init();
    // Start execution.
    NRF_LOG_INFO("Blinky example started.");
    advertising_start(m_adv_handle);
    // Enter main loop.
    for (;;)
        idle_state_handle();
