BLE Long Range RSSI measurement
Hi
I'm testing the range of a custom sensor (nRF52840) by monitoring the RSSI. I use two receivers (the custom sensor and a nRF840 DK) and monitor the received advertising packages. The receivers are stationary, while the sensor is moved around an open field. The received rssi is plotted vs. time below (DK: orange x, Custom: blue +).
The lower threshold seems to be i bit higher than stated in the datasheet of nrf52840 (-103 dBm sensitivity in 125 kbps BLE mode (long range)). The lowest received rssi is actually -99dBm. Why don't i get values closer to -103dBm?
