How to reset TWI during async operation
I have setup TWI peripheral for async transfers via IRQ and callback. After firing the transfer operation, I feel uneasy about having no control until the interrupt happens. Sometimes while playing with TWI wires I've been able to lock the bus, i.e. a TWI operation is initiated but the IRQ handler is never called anymore, also blocking further operations. Due to the async nature, my idea is to start/stop an app timer (single mode, 200ms) on every I2C operation. I'm not sure is the best solution, since I continuously start/stop the timer on each TWI operation and I fear this can interfere with SoftDevice.
  • If the operation completes, I stop the timer from the TWI handler.
  • If the timer handler is called instead, it means I have a pending operation on the TWI driver. I need to gracefully cleanup the TWI hw/sw related stuff and pass an error to the application layer. What's the suggested way of doing this?
I am using SDK 14.2, SoftDevice and app timers with the scheduler (not sure this may be important).
Thanks!
    What you describe is something that happens during prototype development, while doing various debugging etc. However once mounted on the same PCB and the firmware is tested, I am not aware of anyone actually taking any specific precautions for twi transfers. What you describe I would say is more common for UART transfers, however feel free to add safety mechanisms as you like.
    Kenneth
