Current Consumption when using timer and scheduler alongwith nrf_pwr_mgmt_run().
Hi Everyone,
I am using the following peripherals in my project
2 UARTE.
2 ADC
1 TWI
BLE
GPIOTE interrupt for 2 buttons
TWI and ADC and BLE and GPIOTE are not consuming more current when there are no events (when its in sleep mode, current is around 240uA)
However , when i initialise the 2 UART and also uninit both of them , the current doesn't come below 1.1mA , Is it Normal?
If not , how can i set up the UART part to use 2 UARTEs without consuming much current in the sleep mode , when there are no events occuring.
I have a custom PCB using nrf52840 , SDK 15.0 And Segger Embedded Studio IDE.
  • I could get the low current by disabling the UARTE0 , but not for UARTE1.
    Don't you think , the address to disable UARTE0 and UARTE1 should be different?
  • The addresses for disabling UARTE0 and UARTE1 are different (0x40002FFC and 0x40028FFC). These registers are undocumented as they should not normally be used, but are needed as a workaround in this case.
    Please refer to the code snippet in my previous answer for a full example that demonstrates how you can use both in low power mode. To extract just the main point you should use this code (I include the call to  nrf_serial_uninit() for completeness):
        // Disable UARTs to reduce current consumption
        nrf_serial_uninit(&serial0_uarte);
        nrf_serial_uninit(&serial1_uarte);
        // Workaround current consumption issue by power cycling the UART peripherals
        *(volatile uint32_t *)0x40002FFC = 0;   // Power down UARTE0
        *(volatile uint32_t *)0x40002FFC;       //
        *(volatile uint32_t *)0x40002FFC = 1;   // Power on UARTE0 so it is ready for next time
        *(volatile uint32_t *)0x40028FFC = 0;   // Power down UARTE1
        *(volatile uint32_t *)0x40028FFC;       //
        *(volatile uint32_t *)0x40028FFC = 1;   // Power on UARTE1 so it is ready for next time
