Current Consumption when using timer and scheduler alongwith nrf_pwr_mgmt_run().
Hi Everyone,
I am using the following peripherals in my project
2 UARTE.
2 ADC
1 TWI
BLE
GPIOTE interrupt for 2 buttons
TWI and ADC and BLE and GPIOTE are not consuming more current when there are no events (when its in sleep mode, current is around 240uA)
However , when i initialise the 2 UART and also uninit both of them , the current doesn't come below 1.1mA , Is it Normal?
If not , how can i set up the UART part to use 2 UARTEs without consuming much current in the sleep mode , when there are no events occuring.
I have a custom PCB using nrf52840 , SDK 15.0 And Segger Embedded Studio IDE.
    The UART peripherals will consume current as long as it is enabled (by itself and because it needs other resources such as the HF clock), but it should not cause high current consumption after it has been disabled. Can you share your UART code with us, particularly how it is disabled before going to sleep?
  • https://devzone.nordicsemi.com/f/nordic-q-a/25173/nrf52840-uart1-not-working-in-sdk-14
    I am using the exact same procedure to initalise the UARTs.
    To Uninit , i am using ,
    nrf_serial_uninit(&serial1_uarte);
    nrf_serial_uninit(&serial0_uarte);
    However , to initialise the UART , i am using only the event handler , and not the sleep handler , because UART was disabled after 3 minutes or so which i don't need .
    NRF_SERIAL_CONFIG_DEF (serial0_config, NRF_SERIAL_MODE_DMA, &serial0_queues,
    &serial0_buffs, event_handler_serial0, NULL);
    NRF_SERIAL_CONFIG_DEF (serial1_config, NRF_SERIAL_MODE_DMA, &serial1_queues,
    &serial1_buffs, event_handler_serial1, NULL);
    The approach shown by Stian is a sensible workaround. It uses a hidden register to reset the peripheral. I tested the approach on my side, and I am able to get current consumption down and to reconfigure the UARTE peripherals properly. This modified code from the Serial Port Library Example with two UARTEs example for SDK 15.2 demonstrates the fix:
     * Copyright (c) 2018, Nordic Semiconductor ASA
     * All rights reserved.
    #include <stdint.h>
    #include <stdbool.h>
    #include <stddef.h>
    #include "nrf.h"
    #include "nrf_drv_clock.h"
    #include "nrf_gpio.h"
    #include "nrf_delay.h"
    #include "nrf_log.h"
    #include "nrf_log_ctrl.h"
    #include "nrf_serial.h"
    #include "app_timer.h"
    #include "app_error.h"
    #include "app_util.h"
    #include "boards.h"
    /** @file
     * @defgroup nrf_serial_uartes_example main.c
     * @ingroup nrf_serial_uartes_example
     * @brief Example of @ref nrf_serial usage. Loopback example using two UARTE peripherals.
     *        Please short Arduino SCL and SDA GPIOs to start transmission.
    #define OP_QUEUES_SIZE          3
    #define APP_TIMER_PRESCALER     NRF_SERIAL_APP_TIMER_PRESCALER
    static void sleep_handler(void)
        __WFE();
        __SEV();
        __WFE();
    NRF_SERIAL_DRV_UART_CONFIG_DEF(m_uarte0_drv_config,
                          RX_PIN_NUMBER, ARDUINO_SCL_PIN,
                          RTS_PIN_NUMBER, CTS_PIN_NUMBER,
                          NRF_UART_HWFC_DISABLED, NRF_UART_PARITY_EXCLUDED,
                          NRF_UART_BAUDRATE_115200,
                          UART_DEFAULT_CONFIG_IRQ_PRIORITY);
    NRF_SERIAL_DRV_UART_CONFIG_DEF(m_uarte1_drv_config,
                          ARDUINO_SDA_PIN, TX_PIN_NUMBER,
    #define SERIAL_FIFO_TX_SIZE 32
    #define SERIAL_FIFO_RX_SIZE 32
    NRF_SERIAL_QUEUES_DEF(serial0_queues, SERIAL_FIFO_TX_SIZE, SERIAL_FIFO_RX_SIZE);
    NRF_SERIAL_QUEUES_DEF(serial1_queues, SERIAL_FIFO_TX_SIZE, SERIAL_FIFO_RX_SIZE);
    #define SERIAL_BUFF_TX_SIZE 1
    #define SERIAL_BUFF_RX_SIZE 1
    NRF_SERIAL_BUFFERS_DEF(serial0_buffs, SERIAL_BUFF_TX_SIZE, SERIAL_BUFF_RX_SIZE);
    NRF_SERIAL_BUFFERS_DEF(serial1_buffs, SERIAL_BUFF_TX_SIZE, SERIAL_BUFF_RX_SIZE);
    NRF_SERIAL_CONFIG_DEF(serial0_config, NRF_SERIAL_MODE_DMA,
                          &serial0_queues, &serial0_buffs, NULL, sleep_handler);
    NRF_SERIAL_CONFIG_DEF(serial1_config, NRF_SERIAL_MODE_DMA,
                          &serial1_queues, &serial1_buffs, NULL, sleep_handler);
    NRF_SERIAL_UART_DEF(serial0_uarte, 0);
    NRF_SERIAL_UART_DEF(serial1_uarte, 1);
    static void uart_test(int test_num)
        ret_code_t ret;
        ret = nrf_serial_init(&serial0_uarte, &m_uarte0_drv_config, &serial0_config);
        APP_ERROR_CHECK(ret);
        ret = nrf_serial_init(&serial1_uarte, &m_uarte1_drv_config, &serial1_config);
        static char tx_message[40];
        snprintf(tx_message, sizeof(tx_message), "Hello nrf_serial! Test %d\n\r", test_num);
        ret = nrf_serial_write(&serial1_uarte,
                               tx_message,
                               strlen(tx_message),
                               NULL,
                               NRF_SERIAL_MAX_TIMEOUT);
        (void)nrf_serial_flush(&serial1_uarte, 0);
        int i = 0;
        while (true)
            if(++i > 2) break; // break out after 10 timeouts (seconds)
            char c;
            ret = nrf_serial_read(&serial0_uarte, &c, sizeof(c), NULL, 1000);
            if (ret != NRF_SUCCESS)
                continue;
            (void)nrf_serial_write(&serial0_uarte, &c, sizeof(c), NULL, 0);
            (void)nrf_serial_flush(&serial0_uarte, 0);
            ret = nrf_serial_read(&serial1_uarte, &c, sizeof(c), NULL, 1000);
                continue;
            (void)nrf_serial_write(&serial1_uarte, &c, sizeof(c), NULL, 0);
        // Disable UART to reduce current consumption
        // Workaround by disabling the UART peripherals
        *(volatile uint32_t *)0x40002FFC = 0;   // Power down UARTE0
        *(volatile uint32_t *)0x40002FFC;       //
        *(volatile uint32_t *)0x40002FFC = 1;   // Power on UARTE0 so it is ready for next time
        *(volatile uint32_t *)0x40028FFC = 0;   // Power down UARTE1
        *(volatile uint32_t *)0x40028FFC;       //
        *(volatile uint32_t *)0x40028FFC = 1;   // Power on UARTE1 so it is ready for next time
        ret_code_t ret;
        ret = nrf_drv_clock_init();
        ret = app_timer_init();
        uart_test(0);
        uart_test(1);
        // Enter low power mode
        while (true)
            __SEV();
            __WFE();
            __WFE();
    The terminal printout shows that the UART's work after the have been reinitialized:
    Hello nrf_serial! Test 0
    Hello nrf_serial! Test 1
