Thingy52 Costume Firmware - Logging Module Issue - Lagging BLE Notificatio
Hello Dev-Community,
I have modified the Thingy Firmware for a custom made board which has also the MPU9250 with TWI connected. Everything works fine, if i use RTT Viewer. But when i don't show the log, the ble service notification doesn't send any notification anymore. I believe it is, because the LOG Buffer is overflowing or something.
Some Information:
Uses SDK 13.0.0 with that Logging Module
SEGGER Studio IDE 4.01
Maybe someone experienced the same and can give me a good work around.
Thanks for the Help,
Dominik Pflumm
  • I think when you do not open the RTT viewer, the buffer of the logs are overflowing causing a stack corruption. Please check in your sdk_config.h file to configure the logs buffer properly.
    Make sure that you set this NRF_LOG_ALLOW_OVERFLOW to 1. So that the oldest log buffer can be overwritten. Even though it is set to 0, it should not spill out of the logs buffer, but i am suspecting that there might be a bug there (guessing)
    Increase NRF_LOG_BUFSIZE.
    Also do not have too many logs to print, split your logs into different categories (// <1=> Error ,// <2=> Warning,
    // <3=> Info,// <4=> Debug ) And only set NRF_LOG_DEFAULT_LEVEL that you want to print.
  • Thank you for the response. Since Thingy is running with SDK 13. There is no NRF_LOG_ALLOW_OVERFLOW. And also i disabled the logging module (and tried everything else) and still the same thing happends. As soon as i connect my RTT Viewer to the NRF52 the TMS Service works perfectly. But when i let it run by itself, its not sending anything or rarely something.
    What happenes when i connect RTT Viewer? Maybe it has something to do with the Segger RTT files?
    I would appreciate again your help.
    Dominik Pflumm
     This seems like a bug somewhere. Can you try something, can you please comment out the sleep functions in the code (sd_app_evt_wait) throughout your code and see if there is any difference. This is to rule out something I saw on one chip and want to rule out certain possibilities.
    If commenting out sd_app_evt_wait still has the same behavior and your code does not work without debugger connected, then I need to reproduce it here at my desk. It could either be a timing issue in your code.
  • Thank you so much. If i comment out the sleep function (sd_app_evt_wait), it works. But this means the chip will consume more power because between events he will not be in sleep mode, right?. In the original code of the thingy it works with the sleep mode function. Why doesn't it work in my code?
  • it needs some investigation to understand why sleep is causing overflows. I am suspecting wrong configuration of some log macros in sdk_config.h file.
