I am evaluating the nRF5284 SDK 15 Module in HCI mode. I am trying to scan Extended advertise when:
1.Extended non connectable non scannable advertising, Primary_Advertising_PHY=LE 1M and Secondary_Advertising_PHY=LE Coded with or without data , No extended advertising reports received from the scanner.
2.Extended non connectable, non scannable advertising, Primary_Advertising_PHY=LE Coded and Secondary_Advertising_PHY=LE 1M, the scanner crash because no command complete is received during 5 seconds and when the HCI_Reset command is send the events are generated (TED ==Nordic Scanner nRF5280):
2019-01-23 09:01:01,040 :: -------------------------------------------------------------------------------
@ TED command
raw = [0x01, 0x41, 0x20, 0x17, 0x00, 0x00, 0x04, 0x00, 0x80, 0x0C, 0x80, 0x0C]
Opcode = 0x2041 (HCI_LE_SET_EXTENDED_SCAN_PARAMETERS)
Parameter Total Length = 0x17
Own_Address_Type = 0x0
Scanning_Filter_Policy = 0
Scanning_PHYs = 0x4
Scan_Type = [0]
Scan_Interval = [3200]
Scan_Window = [3200]
2019-01-23 09:01:08,631 :: -------------------------------------------------------------------------------
@ TED command
raw = [0x01, 0x03, 0x0C, 0x00]
Opcode = 0xC03 (HCI_RESET)
Parameter Total Length = 0x0
2019-01-23 09:01:10,134 :: -------------------------------------------------------------------------------
@ TED command
raw = [0x01, 0x01, 0x0C, 0x08, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF]
Opcode = 0xC01 (HCI_SET_EVENT_MASK)
Parameter Total Length = 0x8
Event_Mask = 0xFFFFFFFFFFFFFFFF
@ TED event
raw = [0x04, 0x0E, 0x04, 0x01, 0x41, 0x20, 0x00]
Event Code = 0xE (HCI_COMMAND_COMPLETE)
Parameter Total Length = 0x4
Num_HCI_Command_Packets = 0x1
Command_Opcode = 0x2041 (HCI_LE_SET_EXTENDED_SCAN_PARAMETERS)
Status = 0x0 (Success)
2019-01-23 09:01:10,144 :: -------------------------------------------------------------------------------
@ TED event
raw = [0x04, 0x10, 0x01, 0x01]
Event Code = 0x10 (HCI_HARDWARE_ERROR)
Hardware_Code = 0x1 (HCI synchronization lost)
Is it possible to scan Extended advertise packets in LE Coded Phy and what could cause the error 0x1 ?
