for our device we have an input PIN defined with GPIOTE, we expect an event when this input PIN goes from High to Low (interrupt is set by another device on the board):
nrf_gpio_cfg_sense_input(CHARGING_PIN, GPIO_PIN_CNF_PULL_Pullup, NRF_GPIO_PIN_SENSE_LOW); //it's set to low when charging
nrf_drv_gpiote_in_config_t in_config_CHARGING_PIN = GPIOTE_CONFIG_IN_SENSE_HITOLO(true);
in_config_CHARGING_PIN.pull = GPIO_PIN_CNF_PULL_Pullup; //this pin is open drain so must be pulled up
err_code = nrf_drv_gpiote_in_init(CHARGING_PIN, &in_config_CHARGING_PIN, in_pin_handler_CHARGING_PIN);
nrf_drv_gpiote_in_event_enable(CHARGING_PIN, true);
This will fire an event when the PIN goes from High to Low (ok) but we also want the event to be fired when the PIN is already at level Low when the device boots, how can achieve it?
Also, I don't know much about GPIOTE but aren't the 2 parameters in orange redundant?
J.
