GPIOTE EVENT CLEAR
nrf52832, keil with startups from sdk13
Initialization:
    /* Start 32 MHz crystal oscillator */
    NRF_CLOCK->TASKS_HFCLKSTART    = 1;
    /* Wait for the external oscillator to start up */
    while (NRF_CLOCK->EVENTS_HFCLKSTARTED == 0)
        // Do nothing.
    /* Configure Timer0 */
    NRF_TIMER0->PRESCALER = 0;
    NRF_TIMER0->BITMODE = TIMER_BITMODE_BITMODE_32Bit;
    NRF_TIMER0->MODE = TIMER_MODE_MODE_Timer;
    /* Configure GPIO PIN_NUM */
    NRF_GPIO->PIN_CNF[PIN_NUM1] = (GPIO_PIN_CNF_DIR_Input << GPIO_PIN_CNF_DIR_Pos) |
                                 (GPIO_PIN_CNF_INPUT_Connect << GPIO_PIN_CNF_INPUT_Pos) |
                                 (GPIO_PIN_CNF_PULL_Disabled << GPIO_PIN_CNF_PULL_Pos) |
                                 (GPIO_PIN_CNF_DRIVE_S0S1 << GPIO_PIN_CNF_DRIVE_Pos) |
                                 (GPIO_PIN_CNF_SENSE_Disabled << GPIO_PIN_CNF_SENSE_Pos);
    /* Configure GPIOTE 0*/
    NRF_GPIOTE->CONFIG[0] |= (GPIOTE_CONFIG_MODE_Event << GPIOTE_CONFIG_MODE_Pos) |
                             (PIN_NUM1 << GPIOTE_CONFIG_PSEL_Pos) |
                             (GPIOTE_CONFIG_POLARITY_HiToLo << GPIOTE_CONFIG_POLARITY_Pos);
    NRF_GPIOTE->INTENSET |= GPIOTE_INTENSET_IN0_Enabled << GPIOTE_INTENSET_IN0_Pos;
    /* Configure PPI 0*/
    NRF_PPI->CH[0].EEP = (uint32_t)&NRF_GPIOTE->EVENTS_IN[0];
    NRF_PPI->CH[0].TEP = (uint32_t)&NRF_TIMER0->TASKS_CAPTURE[0];
    NRF_PPI->FORK[0].TEP = (uint32_t)&NRF_TIMER0->TASKS_CLEAR;
    NRF_PPI->CHENSET |= PPI_CHENSET_CH0_Enabled << PPI_CHENSET_CH0_Pos;
    NRF_TIMER0->TASKS_START = 1;
    NVIC_EnableIRQ(GPIOTE_IRQn);
IntHandler:
void GPIOTE_IRQHandler(void)
    if (1 == NRF_GPIOTE->EVENTS_IN[0])
        time1 = NRF_TIMER0->CC[0];
        switch (state1)
        NRF_GPIOTE->EVENTS_IN[0] = 0;
With one event everything working well. Then I add another:
        // Do nothing.
    /* Configure Timer1 */
    NRF_TIMER1->PRESCALER = 0;
    NRF_TIMER1->BITMODE = TIMER_BITMODE_BITMODE_32Bit;
    NRF_TIMER1->MODE = TIMER_MODE_MODE_Timer;
    NRF_GPIO->PIN_CNF[PIN_NUM2] = (GPIO_PIN_CNF_DIR_Input << GPIO_PIN_CNF_DIR_Pos) |
    /* Configure GPIOTE 1*/
    NRF_GPIOTE->CONFIG[1] |= (GPIOTE_CONFIG_MODE_Event << GPIOTE_CONFIG_MODE_Pos) |
                             (PIN_NUM2 << GPIOTE_CONFIG_PSEL_Pos) |
    NRF_GPIOTE->INTENSET |= GPIOTE_INTENSET_IN1_Enabled << GPIOTE_INTENSET_IN1_Pos;
    /* Configure PPI 1*/
    NRF_PPI->CH[1].EEP = (uint32_t)&NRF_GPIOTE->EVENTS_IN[1];
    NRF_PPI->CH[1].TEP = (uint32_t)&NRF_TIMER1->TASKS_CAPTURE[0];
    NRF_PPI->FORK[1].TEP = (uint32_t)&NRF_TIMER1->TASKS_CLEAR;
    NRF_PPI->CHENSET |= PPI_CHENSET_CH1_Enabled << PPI_CHENSET_CH1_Pos;
    NRF_TIMER1->TASKS_START = 1;
        switch (state1)
    if (1 == NRF_GPIOTE->EVENTS_IN[1])
        time2 = NRF_TIMER0->CC[1];
        switch (state2)
        NRF_GPIOTE->EVENTS_IN[1] = 0;
I need to measure SENT signal from two channels, minimal signal lenght is 36 uSec, and with two channels sometimes I have 0 in time1/time2 (they are global) vars. I think this because when I for example handled first channel, EVENT_IN[0] didn't be cleared (I didn't see clearing in System Viewer, after NRF_GPIOTE->EVENTS_IN[0] = 0; it is still 1 in System Viewer). And when second channel generate EVENT_IN[1] I came into if (1 == NRF_GPIOTE->EVENTS_IN[0]), but I shouldn't.
Is it real? How to clear event correctly?
  • For greater clarity I made project in SES:
    #include <stdint.h>
    #include "nrf.h"
    #define PIN_NUM1 16
    #define PIN_NUM2 18
    uint32_t sent1Time = 0;
    uint32_t sent2Time = 0;
    uint32_t sent1Errors = 0;
    uint32_t sent2Errors = 0;
            sent1Time = NRF_TIMER0->CC[0];
            if (0 == sent1Time)
                ++sent1Errors;
            sent2Time = NRF_TIMER1->CC[0];
            if (0 == sent2Time)
                ++sent2Errors;
    int main()
            // Do nothing.
    /***************************************SENT1 INIT***************************************/
    /***************************************SENT2 INIT***************************************/
    //    /* Configure Timer1 */
    //    NRF_TIMER1->PRESCALER = 0;
    //    NRF_TIMER1->BITMODE = TIMER_BITMODE_BITMODE_32Bit;
    //    NRF_TIMER1->MODE = TIMER_MODE_MODE_Timer;
    //    /* Configure GPIO PIN_NUM */
    //    NRF_GPIO->PIN_CNF[PIN_NUM2] = (GPIO_PIN_CNF_DIR_Input << GPIO_PIN_CNF_DIR_Pos) |
    //                                 (GPIO_PIN_CNF_INPUT_Connect << GPIO_PIN_CNF_INPUT_Pos) |
    //                                 (GPIO_PIN_CNF_PULL_Disabled << GPIO_PIN_CNF_PULL_Pos) |
    //                                 (GPIO_PIN_CNF_DRIVE_S0S1 << GPIO_PIN_CNF_DRIVE_Pos) |
    //                                 (GPIO_PIN_CNF_SENSE_Disabled << GPIO_PIN_CNF_SENSE_Pos);
    //    /* Configure GPIOTE 1*/
    //    NRF_GPIOTE->CONFIG[1] |= (GPIOTE_CONFIG_MODE_Event << GPIOTE_CONFIG_MODE_Pos) |
    //                             (PIN_NUM2 << GPIOTE_CONFIG_PSEL_Pos) |
    //                             (GPIOTE_CONFIG_POLARITY_HiToLo << GPIOTE_CONFIG_POLARITY_Pos);
    //    NRF_GPIOTE->INTENSET |= GPIOTE_INTENSET_IN1_Enabled << GPIOTE_INTENSET_IN1_Pos;
    //    /* Configure PPI 1*/
    //    NRF_PPI->CH[1].EEP = (uint32_t)&NRF_GPIOTE->EVENTS_IN[1];
    //    NRF_PPI->CH[1].TEP = (uint32_t)&NRF_TIMER1->TASKS_CAPTURE[0];
    //    NRF_PPI->FORK[1].TEP = (uint32_t)&NRF_TIMER1->TASKS_CLEAR;
    //    NRF_PPI->CHENSET |= PPI_CHENSET_CH1_Enabled << PPI_CHENSET_CH1_Pos;
        while(1)
           // Do nothing;
    With commented sent1 or sent2 init section there are not zero values (errors). With both init uncommented, zero values appear on 1 or 2 event randomly.
  • Hey,
    Are you sure that EVENT_IN[0] has not been set back to 1 right after you cleared it. Do you have any control of when the events are triggered? Maybe you can use nrf log to print the value of EVENT_IN right after you have cleared it to make sure it has been cleared.
  • The action is very quick if I write:
            if (0 == sent1Time)
                ++sent1Errors;
            sprintf(rtt_buf, "%s %x\n", "sent1", NRF_GPIOTE->EVENTS_IN[0]);
            SEGGER_RTT_Write(0, rtt_buf, 16);
            if (0 == sent2Time)
                ++sent2Errors;
                SEGGER_RTT_WriteString(0, "sent2 error\n");
            sprintf(rtt_buf, "%s %x\n", "sent2", NRF_GPIOTE->EVENTS_IN[1]);
    I get:
    <spoiler>sent2 0
    sent2 0
    sent1 0
    sent2 0
    sent1 0
    sent1 0
    sent1 0
    sent2 0
    sent2 0
    sent2 0
    sent1 0
    sent1 0
    sent1 0
    sent1 0
    sent2 0
    sent2 0
    sent2 0
    sent1 0
    sent1 0
    sent1 0
    sent2 0
    sent2 0
    sent2 0
    sent1 0
    sent1 0
    sent2 0
    sent1 0
    sent2 0
    sent1 0
    sent1 0
    sent1 0
    sent2 0
    sent2 0
    sent1 0
    sent2 0
    sent1 0
    sent1 0
    sent2 0
    sent1 0
    sent1 0
    sent2 0
    sent2 0
    sent1 0
    sent1 0
    sent1 0
    sent2 0
    sent1 0
    sent2 0
    sent2 0
    sent2 0
    sent2 0
    sent2 0
    sent1 0
    sent1 0
    sent2 0
    sent2 0
    sent2 0
    sent1 0
    sent1 0
    sent2 0
    sent1 0
    sent2 0
    sent1 0
    sent1 0
    sent2 0
    sent1 0
    sent2 0
    sent1 0
    sent1 0
    sent2 0
    sent2 0
    sent2 0
    sent1 0
    sent1 0
    sent1 0
    sent2 0
    sent1 0
    sent2 0
    sent2 0
    sent2 0
    sent2 0
    sent1 0
    sent2 0
    sent1 0
    sent2 0
    sent1 0
    sent2 0
    sent2 0
    sent1 0
    sent2 0
    sent2 0
    sent2 0
    sent1 0
    sent1 0
    sent2 0
    sent2 0
    sent1 0
    sent1 0
    sent1 0
    sent1 0
    sent2 0
    sent1 0
    sent1 0
    sent1 0
    sent2 0
    sent1 0
    sent1 0
    sent1 0
    sent1 0
    sent2 0
    sent1 0
    sent2 0
    sent1 0
    sent2 0
    sent2 0
    sent2 0
    sent1 0
    sent2 0
    sent1 0
    sent2 0
    sent2 0
    sent1 0
    sent2 0
    sent2 0
    sent2 0
    sent1 0
    sent2 0
    sent2 0
    sent2 0
    sent2 0
    sent1 0
    sent2 0
    sent2 0
    sent1 0
    sent2 0
    sent2 0
    sent2 0
    sent2 0
    sent2 0
    sent1 0
    sent2 0
    sent2 0
    sent1 0
    sent2 0
    sent1 0
    sent2 0
    sent1 0
    sent1 0
    sent1 0
    sent2 0
    sent1 0
    sent1 0
    sent2 0</spoiler>
    with no order.
    If I write:
            if (0 == sent1Time)
                ++sent1Errors;
            if (0 == sent2Time)
                ++sent2Errors;
    I get something like:
    <spoiler>
    sent1 1
    sent2 0
    sent2 1
    sent1 1
    sent1 1
    sent1 1
    sent2 1
    sent1 1
    sent1 1
    sent2 0
    sent2 0
    sent1 1
    sent1 1
    sent2 1
    sent2 1
    sent1 1
    sent1 1
    sent2 1
    sent2 1
    sent1 1
    sent1 1
    sent2 1
    sent2 1
    sent2 0
    sent2 0
    sent2 1
    sent1 0
    sent2 1
    sent1 1
    sent1 1
    sent1 0
    sent1 0
    sent2 1
    sent2 0
    sent1 1
    sent1 0
    sent2 1
    sent2 1
    sent1 0
    sent1 1
    sent1 0
    sent1 1
    sent2 1
    sent2 0
    sent2 1
    sent2 1
    sent1 1
    sent1 0
    sent2 1
    sent2 1
    sent1 0
    sent1 0
    sent1 1
    sent1 1
    sent2 1
    sent1 1
    sent1 1
    sent1 1
    sent1 0
    sent2 1
    sent1 1
    sent2 0
    sent2 1
    sent2 1
    sent2 0
    sent1 0
    sent1 1
    sent1 0
    sent1 0
    sent1 1
    sent1 1
    sent2 1
    </spoiler>
    also without any order.
    As I think, debugger isn't quick enough.
    Another question is:
    If I configure GPIOTE event from Hi to Low, NRF_GPIOTE->EVENTS_IN[0] will be triggered on Hi to Low edge, or it can be triggered again on Low level when it didn't get back to Hi level?
  • Try using NRF_LOG_FLUSH() and see if it makes a difference.
     I believe this part from the documentation should answer your question,
    "An event can be generated in each GPIOTE channel from one of the following input conditions:
    • Rising edge
    • Falling edge
    • Any change"
