Issue with Sending generic level messages from main()
I am working with a motion sensor which sends a message when it detects a motion. I am communicating between the nRF52 DK and the sensor via UART. I am able to receive messages correctly. I am using the experimental_dimming_client example and I tried to send a generic level message whenever the sensor detects the motion. I added the UART library and added the functionality to send generic level messages upon detecting motion in the main() as follows:
for (;;)
        uint8_t cr;
        while(app_uart_get(&cr) != NRF_SUCCESS);
        while(app_uart_put(cr) != NRF_SUCCESS);
        if(cr == 'M')
            button_event_handler(1);
        (void)sd_app_evt_wait();
M indicates motion and button event handler sends the generic level messages.
Here comes the issue:
I haven't provisioned the board yet. When a motion is detected, the board is able to execute the the button_event_handler function for case 1 which is sending a set message.
Now I provisioned the device(didn't set the publication address). For these two situations, output looks like this:
When I add the publication address, it asserts an error:
app_error_weak.c,  108, Mesh assert at 0x0002AEC6 (:0)
After this, I went back to the stock SDK and tried to send generic level messages from the main function (without UART) which resulted in a Mesh error 15 (Forbidden Command)
I have been trying to debug and find why I am unable to publish messages to an address from the main() but I am not successful yet.
What might be the reason? Any ideas on how to resolve it?
Thank you.
  • I have attached the main for the client example. Most of the modification are the same as the patch for the server except for how the publishing is done. Look at the main to see how to send messages from main loop. You can also search for "MODFIED" to see all the modifcation done.
    /* Copyright (c) 2010 - 2018, Nordic Semiconductor ASA
     * All rights reserved.
     * list of conditions and the following disclaimer.
    #include <stdint.h>
    #include <string.h>
    /* HAL */
    #include "boards.h"
    #include "simple_hal.h"
    #include "app_timer.h"
    /* Core */
    #include "nrf_mesh_config_core.h"
    #include "nrf_mesh_gatt.h"
    #include "nrf_mesh_configure.h"
    #include "nrf_mesh.h"
    #include "mesh_stack.h"
    #include "device_state_manager.h"
    #include "access_config.h"
    /* Provisioning and configuration */
    #include "mesh_provisionee.h"
    #include "mesh_app_utils.h"
    /* Models */
    #include "generic_onoff_client.h"
    /* Logging and RTT */
    #include "log.h"
    #include "rtt_input.h"
    /* Example specific includes */
    #include "app_config.h"
    #include "nrf_mesh_config_examples.h"
    #include "light_switch_example_common.h"
    #include "example_common.h"
    #include "ble_softdevice_support.h"
    #include "app_scheduler.h"
    #define APP_STATE_OFF                (0)
    #define APP_STATE_ON                 (1)
    #define APP_UNACK_MSG_REPEAT_COUNT   (2)
    //Modified
    /* Select max event size. This must be large enough for app timer events as well.
     * uint8_t => button number variable
     * APP_TIMER_SCHED_EVENT_DATA_SIZE => App timer event
    #define APP_SCHED_EVENT_SIZE        MAX(sizeof(uint8_t), APP_TIMER_SCHED_EVENT_DATA_SIZE)
    #define APP_SCHED_QUEUE_SIZE        (50)
    #define APP_MAIN_AUTO_OFF_FACTOR    (300)
    #define LED_OFF                     (0)
    #define THREAD_MODE_CLIENT          (0)
    //Modified
    static generic_onoff_client_t m_clients[CLIENT_MODEL_INSTANCE_COUNT];
    static bool                   m_device_provisioned;
    /* Forward declaration */
    static void app_gen_onoff_client_publish_interval_cb(access_model_handle_t handle, void * p_self);
    static void app_generic_onoff_client_status_cb(const generic_onoff_client_t * p_self,
                                                   const access_message_rx_meta_t * p_meta,
                                                   const generic_onoff_status_params_t * p_in);
    static void app_gen_onoff_client_transaction_status_cb(access_model_handle_t model_handle,
                                                           void * p_args,
                                                           access_reliable_status_t status);
    const generic_onoff_client_callbacks_t client_cbs =
        .onoff_status_cb = app_generic_onoff_client_status_cb,
        .ack_transaction_status_cb = app_gen_onoff_client_transaction_status_cb,
        .periodic_publish_cb = app_gen_onoff_client_publish_interval_cb
    static void device_identification_start_cb(uint8_t attention_duration_s)
        hal_led_mask_set(LEDS_MASK, false);
        hal_led_blink_ms(BSP_LED_2_MASK  | BSP_LED_3_MASK,
                         LED_BLINK_ATTENTION_INTERVAL_MS,
                         LED_BLINK_ATTENTION_COUNT(attention_duration_s));
    static void provisioning_aborted_cb(void)
        hal_led_blink_stop();
    static void provisioning_complete_cb(void)
        __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Successfully provisioned\n");
    #if MESH_FEATURE_GATT_ENABLED
        /* Restores the application parameters after switching from the Provisioning
         * service to the Proxy  */
        gap_params_init();
        conn_params_init();
        dsm_local_unicast_address_t node_address;
        dsm_local_unicast_addresses_get(&node_address);
        __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Node Address: 0x%04x \n", node_address.address_start);
        hal_led_mask_set(LEDS_MASK, LED_MASK_STATE_OFF);
        hal_led_blink_ms(LEDS_MASK, LED_BLINK_INTERVAL_MS, LED_BLINK_CNT_PROV);
    /* This callback is called periodically if model is configured for periodic publishing */
         __LOG(LOG_SRC_APP, LOG_LEVEL_WARN, "Publish desired message here.\n");
    /* Acknowledged transaction status callback, if acknowledged transfer fails, application can
    * determine suitable course of action (e.g. re-initiate previous transaction) by using this
    * callback.
                                                           void * p_args,
        switch(status)
            case ACCESS_RELIABLE_TRANSFER_SUCCESS:
                __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Acknowledged transfer success.\n");
            case ACCESS_RELIABLE_TRANSFER_TIMEOUT:
                hal_led_blink_ms(LEDS_MASK, LED_BLINK_SHORT_INTERVAL_MS, LED_BLINK_CNT_NO_REPLY);
                __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Acknowledged transfer timeout.\n");
            case ACCESS_RELIABLE_TRANSFER_CANCELLED:
                __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Acknowledged transfer cancelled.\n");
                ERROR_CHECK(NRF_ERROR_INTERNAL);
    /* Generic OnOff client model interface: Process the received status message in this callback */
        if (p_in->remaining_time_ms > 0)
            __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "OnOff server: 0x%04x, Present OnOff: %d, Target OnOff: %d, Remaining Time: %d ms\n",
                  p_meta->src.value, p_in->present_on_off, p_in->target_on_off, p_in->remaining_time_ms);
            __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "OnOff server: 0x%04x, Present OnOff: %d\n",
                  p_meta->src.value, p_in->present_on_off);
    static void node_reset(void)
        __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "----- Node reset  -----\n");
        hal_led_blink_ms(LEDS_MASK, LED_BLINK_INTERVAL_MS, LED_BLINK_CNT_RESET);
        /* This function may return if there are ongoing flash operations. */
        mesh_stack_device_reset();
    static void config_server_evt_cb(const config_server_evt_t * p_evt)
        if (p_evt->type == CONFIG_SERVER_EVT_NODE_RESET)
            node_reset();
    static void button_event_handler(uint32_t button_number)
        __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Button %u pressed\n", button_number);
        uint32_t status = NRF_SUCCESS;
        generic_onoff_set_params_t set_params;
        model_transition_t transition_params;
        static uint8_t tid = 0;
        /* Button 1: On, Button 2: Off, Client[0]
         * Button 2: On, Button 3: Off, Client[1]
        switch(button_number)
            case 0:
            case 2:
                set_params.on_off = APP_STATE_ON;
            case 1:
            case 3:
                set_params.on_off = APP_STATE_OFF;
        set_params.tid = tid++;
        transition_params.delay_ms = APP_CONFIG_ONOFF_DELAY_MS;
        transition_params.transition_time_ms = APP_CONFIG_ONOFF_TRANSITION_TIME_MS;
        __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Sending msg: ONOFF SET %d\n", set_params.on_off);
        switch (button_number)
            case 0:
            case 1:
                /* Demonstrate acknowledged transaction, using 1st client model instance */
                /* In this examples, users will not be blocked if the model is busy */
                (void)access_model_reliable_cancel(m_clients[0].model_handle);
                status = generic_onoff_client_set(&m_clients[0], &set_params, &transition_params);
                hal_led_pin_set(BSP_LED_0, set_params.on_off);
            case 2:
            case 3:
                /* Demonstrate un-acknowledged transaction, using 2nd client model instance */
                status = generic_onoff_client_set_unack(&m_clients[1], &set_params,
                                                        &transition_params, APP_UNACK_MSG_REPEAT_COUNT);
                hal_led_pin_set(BSP_LED_1, set_params.on_off);
        switch (status)
            case NRF_SUCCESS:
            case NRF_ERROR_NO_MEM:
            case NRF_ERROR_BUSY:
            case NRF_ERROR_INVALID_STATE:
                __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Client %u cannot send\n", button_number);
            case NRF_ERROR_INVALID_PARAM:
                /* Publication not enabled for this client. One (or more) of the following is wrong:
                 * - An application key is missing, or there is no application key bound to the model
                 * - The client does not have its publication state set
                 * It is the provisioner that adds an application key, binds it to the model and sets
                 * the model's publication state.
                __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Publication not configured for client %u\n", button_number);
                ERROR_CHECK(status);
    //MODIFIED
    static void button_event_handler_app_sched(void * p_event_data, uint16_t event_size)
        uint8_t * button_number = (uint8_t *) p_event_data;
        NRF_MESH_ASSERT(event_size == 1);
        button_event_handler(*button_number);
    static void button_event_handler_irq(uint32_t button_number)
        static uint8_t bt_num;
        bt_num = button_number;
        app_sched_event_put((void *)&bt_num, sizeof(bt_num), button_event_handler_app_sched);
    //MODIFIED
    static void rtt_input_handler(int key)
        if (key >= '0' && key <= '3')
            uint32_t button_number = key - '0';
            button_event_handler(button_number);
    static void models_init_cb(void)
        __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Initializing and adding models\n");
        for (uint32_t i = 0; i < CLIENT_MODEL_INSTANCE_COUNT; ++i)
            m_clients[i].settings.p_callbacks = &client_cbs;
            m_clients[i].settings.timeout = 0;
            m_clients[i].settings.force_segmented = APP_CONFIG_FORCE_SEGMENTATION;
            m_clients[i].settings.transmic_size = APP_CONFIG_MIC_SIZE;
            ERROR_CHECK(generic_onoff_client_init(&m_clients[i], i + 1));
    static void mesh_init(void)
        mesh_stack_init_params_t init_params =
            //.core.irq_priority       = NRF_MESH_IRQ_PRIORITY_LOWEST,
            //MODIFIED
            .core.irq_priority       = NRF_MESH_IRQ_PRIORITY_THREAD,
            .core.lfclksrc           = DEV_BOARD_LF_CLK_CFG,
            .core.p_uuid             = NULL,
            .models.models_init_cb   = models_init_cb,
            .models.config_server_cb = config_server_evt_cb
        ERROR_CHECK(mesh_stack_init(&init_params, &m_device_provisioned));
    static void initialize(void)
        __LOG_INIT(LOG_SRC_APP | LOG_SRC_ACCESS | LOG_SRC_BEARER, LOG_LEVEL_INFO, LOG_CALLBACK_DEFAULT);
        __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "----- BLE Mesh Light Switch Client Demo -----\n");
        ERROR_CHECK(app_timer_init());
        hal_leds_init();
    #if BUTTON_BOARD
        //ERROR_CHECK(hal_buttons_init(button_event_handler));
        //MODIFIED
        ERROR_CHECK(hal_buttons_init(button_event_handler_irq));
        ble_stack_init();
        gap_params_init();
        conn_params_init();
        mesh_init();
    static void start(void)
        rtt_input_enable(rtt_input_handler, RTT_INPUT_POLL_PERIOD_MS);
        if (!m_device_provisioned)
            static const uint8_t static_auth_data[NRF_MESH_KEY_SIZE] = STATIC_AUTH_DATA;
            mesh_provisionee_start_params_t prov_start_params =
                .p_static_data    = static_auth_data,
                .prov_complete_cb = provisioning_complete_cb,
                .prov_device_identification_start_cb = device_identification_start_cb,
                .prov_device_identification_stop_cb = NULL,
                .prov_abort_cb = provisioning_aborted_cb,
                .p_device_uri = EX_URI_LS_CLIENT
            ERROR_CHECK(mesh_provisionee_prov_start(&prov_start_params));
        mesh_app_uuid_print(nrf_mesh_configure_device_uuid_get());
        ERROR_CHECK(mesh_stack_start());
        hal_led_blink_ms(LEDS_MASK, LED_BLINK_INTERVAL_MS, LED_BLINK_CNT_START);
        //MODIFIED
        APP_SCHED_INIT(APP_SCHED_EVENT_SIZE, APP_SCHED_QUEUE_SIZE);
        initialize();
        start();
        int i = 0;
        for (;;)
            //MODIFIED
            app_sched_execute();
            bool done = nrf_mesh_process();
            if (done)
            /* Demonstrate sending of messages from main loop, by automatically turning off the LED
             * after few iterations. */
            i++;
            if ((i % APP_MAIN_AUTO_OFF_FACTOR) == 0)
                hal_led_pin_set(BSP_LED_0, !hal_led_pin_get(BSP_LED_0));
                uint32_t status;
                set_params.on_off = hal_led_pin_get(BSP_LED_0);
                status = generic_onoff_client_set_unack(&m_clients[THREAD_MODE_CLIENT], &set_params,
                switch (status)
                case NRF_SUCCESS:
                __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Client %d cannot send\n",THREAD_MODE_CLIENT);
                __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Publication not configured for client %d\n", THREAD_MODE_CLIENT);
            //MODIFIED end
  • Hello, I am using the nRF SDK version 15.2 and nRF Mesh SDK 3.1.0.
    I could not get this patch working. While it does compile and program a DK, when trying to provision I get a Mesh assert error:
    app_error_weak.c,  108, Mesh assert at 0x0002B0A0 (:0)
    I suspect this is happening because either the mesh stack or a softdevice event is triggering in the wrong priority level, but I thought this patch solved it.
    Just to be sure, what I did was the following:
    1 - Replace the content of the light switch client example main with the content of this patch
    2 - Add app_scheduler.c to the Application project folder on Embedded Studio
    3 - Add $(SDK_ROOT:../../../../nRF5_SDK_15.2.0_9412b96)/components/libraries/scheduler; to c_user_include_directories
    4 - Edit sdk_config.h line number 5792 #define APP_SCHEDULER_ENABLED 0 changed to 1
    This should be enough right? But it still triggers the Mesh assert error when trying to provision.
