Problem running a 10kHz PWM on a Timer
I am trying to obtain a 10khz PWM (50%) on an output using Timer2 (see code below). It is working fine up to around 500Hz (2msec), above that (1kHz) I am getting only sporadic PWM bursts, PWM will run up to advertising then will stop, then timer has to overun to startPWM again.
As mentioned, I have S110 advertising running in background, I am certain that I am missing the Timer2 interrupt to update Compare 0 because advertising interrupt is in higer priority.
My question is, how can I easily output a 10kHz PWM without needing to enter an interrupt by software to update an output compare register?
Here's the code:
GPIOTE init:
// Configure GPIOTE channel 0 to toggle the PWM pin state
    nrf_gpiote_task_config(0, LED_6, NRF_GPIOTE_POLARITY_TOGGLE, RF_GPIOTE_INITIAL_VALUE_LOW);
PPI init:
// Configure PPI channel 0 to toggle PWM_OUTPUT_PIN on every TIMER2 COMPARE[0] match.
NRF_PPI->CH[0].EEP = (uint32_t)&NRF_TIMER2->EVENTS_COMPARE[0];
NRF_PPI->CH[0].TEP = (uint32_t)&NRF_GPIOTE->TASKS_OUT[0];
// Enable PPI channel 0.
NRF_PPI->CHEN = (PPI_CHEN_CH0_Enabled << PPI_CHEN_CH0_Pos);
Timer init + start:
 // Init TIMER2 for 10kHz PWM
NRF_TIMER2->MODE = TIMER_MODE_MODE_Timer;			// Set the timer in Counter Mode
NRF_TIMER2->TASKS_CLEAR = 1;						// Clear the tasks first to be usable for later
NRF_TIMER2->PRESCALER = 4;							// 2^PRESCALER (values authorized 1 to 9) 4 : 16MHz / 16 = 10MHz
NRF_TIMER2->BITMODE = TIMER_BITMODE_BITMODE_16Bit;	//Set counter to 16 bit resolution
NRF_TIMER2->CC[0] = 50;
// Enable OC1 interrupt on TIMER2
NRF_TIMER2->INTENSET = TIMER_INTENSET_COMPARE0_Enabled << TIMER_INTENSET_COMPARE0_Pos;
NVIC_EnableIRQ(TIMER2_IRQn);
// Start TIMER2
NRF_TIMER2->TASKS_START = true;
The interrupt:
void TIMER2_IRQHandler(void)
	if (NRF_TIMER2->EVENTS_COMPARE[0] != 0)
		NRF_TIMER2->EVENTS_COMPARE[0] = 0; // Reset event
		// Set next compare in 50nsec
		NRF_TIMER2->CC[0] += 50;
Thanks for any help on this.
Phil
  • For further PWM code reference, there is a PWM library available here for nRF51.
  • Hello Stefan,
    Thanks for the link. One more thing though, I did manage to get the PWM on compare 0 to work fine, however I tried in parallel to run an interrupt on Compare 1 every 10msec and that does not work. The interrupt is not entered and my PWM is 20msec. What am I getting wrong?
    // Init OC0 PWM
    PWM_TIMER->SHORTS = (TIMER_SHORTS_COMPARE0_CLEAR_Enabled << TIMER_SHORTS_COMPARE0_CLEAR_Pos);
    NRF_TIMER2->CC[1] = 10000;
    PWM_TIMER->SHORTS = (TIMER_SHORTS_COMPARE1_CLEAR_Enabled << TIMER_SHORTS_COMPARE1_CLEAR_Pos);
    // Start TIMER2
    Interrupt :
        if (NRF_TIMER2->EVENTS_COMPARE[1] != 0)
            NRF_TIMER2->EVENTS_COMPARE[1] = 0; // Reset event
           // Code to execute
    Regards Phil
  • Hello Stefan,
    // Init OC0 PWM
    // Start TIMER2
    Interrupt :
           // Code to execute
    Regards Phil
