Over consumption just after a flash and no problem after an hardware reset
           Recently I have migrated my app of SDK13 to SDK15.2. It's a little bit complicate but it works with patience, thanks for the migration guide !
My problem now is when I flash my app with the new software, the consumption is about ~2.7mA and after a hardware RESET (cut the power) is just few µA. I flash my own board with KEIL MDK 5, with an NRF52832 eval KIT.
         For the migration I have re-create my project with BLE_APP_BLINKY for restart with a proper base. I have tests to make a NVIC_systeme_reset, a watchdog reset and reset with nrfjprog : rfjprg --family NRF52 -r but no manipulation goes to work.
I see this post : https://devzone.nordicsemi.com/f/nordic-q-a/27255/resetting-dif-to-reduce-interface-current-on-nrf52/107583#107583
And if I make the same manip is working but I would understand what can cause the problem in my code.
Before the changing of the SDK, I had made a BASH script to programme few cards directly and I have the same problem now with this new HEX and with the old HEX and now I'm not sure if I have the problem before. I'm sorry if it's a little bit confuse but this debug wash my brain ...
If someone can help, I will be very grateful !
Regards, Romain.
Build OUTPUT :
JLink info:
DLL: V6.34g, compiled Sep 26 2018 14:45:08
Firmware: J-Link OB-SAM3U128-V2-NordicSemi compiled Jul 12 2018 11:44:41
Hardware: V1.00
S/N : 682779794
* JLink Info: Found SW-DP with ID 0x2BA01477
* JLink Info: Scanning AP map to find all available APs
* JLink Info: AP[2]: Stopped AP scan as end of AP map has been reached
* JLink Info: AP[0]: AHB-AP (IDR: 0x24770011)
* JLink Info: AP[1]: JTAG-AP (IDR: 0x02880000)
* JLink Info: Iterating through AP map to find AHB-AP to use
* JLink Info: AP[0]: Core found
* JLink Info: AP[0]: AHB-AP ROM base: 0xE00FF000
* JLink Info: CPUID register: 0x410FC241. Implementer code: 0x41 (ARM)
* JLink Info: Found Cortex-M4 r0p1, Little endian.
* JLink Info: FPUnit: 6 code (BP) slots and 2 literal slots
* JLink Info: CoreSight components:
* JLink Info: ROMTbl[0] @ E00FF000
* JLink Info: ROMTbl[0][0]: E000E000, CID: B105E00D, PID: 000BB00C SCS-M7
* JLink Info: ROMTbl[0][1]: E0001000, CID: B105E00D, PID: 003BB002 DWT
* JLink Info: ROMTbl[0][2]: E0002000, CID: B105E00D, PID: 002BB003 FPB
* JLink Info: ROMTbl[0][3]: E0000000, CID: B105E00D, PID: 003BB001 ITM
* JLink Info: ROMTbl[0][4]: E0040000, CID: B105900D, PID: 000BB9A1 TPIU
* JLink Info: ROMTbl[0][5]: E0041000, CID: B105900D, PID: 000BB925 ETM
ROMTableAddr = 0xE00FF000
* JLink Info: Reset: Halt core after reset via DEMCR.VC_CORERESET.
* JLink Info: Reset: Reset device via reset pin
* JLink Info: Reset: VC_CORERESET did not halt CPU. (Debug logic also reset by reset pin?).
* JLink Info: Reset: Reconnecting and manually halting CPU.
* JLink Info: AP map detection skipped. Manually configured AP map found.
* JLink Info: AP[0]: AHB-AP (IDR: Not set)
* JLink Info: Reset: Reset device via AIRCR.VECTRESET.
Target info:
Device: nRF52832_xxAA
VTarget = 3.300V
State of Pins:
TCK: 0, TDI: 1, TDO: 1, TMS: 1, TRES: 1, TRST: 1
Hardware-Breakpoints: 6
Software-Breakpoints: 8192
Watchpoints:          4
JTAG speed: 1000 kHz
Erase Done.
Programming Done.
Verify OK.
Application running ...
Flash Load finished at 12:25:26
