Bonding with pc-ble-driver-py
Hello
System:
Windows 10
nRF Connect v2.6.0 and Bluetooth Low Energy v2.2.0
Python 2.7.13
After some research I didn't find any examples of bonding with pc-ble-driver-py so I decided to ask here.
When I'm trying to do bond using nRF Connect it always done succsessful, I just checking all checkboxes and type passcode after request.
But when I'm trying to do that with pc-ble-driver-py it won't work.
I'm using authenticate() method to do bonding:
res = self.adapter.authenticate(conn_handle, bond     = True,
                                             mitm     = True,
                                             oob      = True,
                                             lesc     = True,
                                             keypress = True)
But in some time after code executed it just will crash.
When I'm trying to pass more arguments to this method I will get the next message: No handlers could be found for logger "pc_ble_driver_py.ble_driver"
To be clear:
I'm trying to bond just after the device is connected(also tested with delay = 3s after connection, nothing changed)
Connection params are exactly the same as in heart_rate_collector.py
Firmware in the dongle: connectivity_1.2.3_usb_with_s132_3.1.hex
Is there a working examples of bonding with pc-ble-driver-py? It would be helpful in solving my problem.
    Do you get any error codes when it crash? Have you seen this thread? Unfortunately, we do not have any examples of this in the Python version.
    Jørgen
  • Can you post the code you are using, for reproducing and debugging this?
  • Well, now I think I resolved the problem with crushes by moving authentication method into the main function instead of event handler.
  • But I still can't perform bond.
    As you will see in the logs below, I'm facing BLE_GAP_SEC_STATUS_CONFIRM_VALUE error, but ble_gap_authenticate(), ble_gap_sec_params_reply() and sd_ble_gap_auth_key_reply() has done succsessfully(I was checking their output from ble_driver.py when they called a softdevice api functions)
    Here is the log from the console output with debug log:
    Auth 1
    Auth completed
    DEBUG:pc_ble_driver_py.observers:evt> sec_params_request conn(0)
    peer_params(Security Parameters bond(1) mitm(1) lesc(0) keypress(0) io_caps(BLEGapIOCaps.display_only) oob(0) max_key_size(16) min_key_size(0) kdist_own(enc(1) id(1) sign(0) link(0)) kdist_peer(enc(1) id(1) sign(0) link(0)))
    Sec params replying done
    DEBUG:pc_ble_driver_py.observers:evt> auth_key_request conn(0)
    key_type(1)
    Key reply finished with code: 0
    DEBUG:pc_ble_driver_py.observers:evt> auth_status conn(0)
    error_src(1)
    bonded(0)
    sm1_levels(<pc_ble_driver_sd_api_v3.ble_gap_sec_levels_t; proxy of <Swig Object of type 'ble_gap_sec_levels_t *' at 0x01ADF1D0> >)
    sm2_levels(<pc_ble_driver_sd_api_v3.ble_gap_sec_levels_t; proxy of <Swig Object of type 'ble_gap_sec_levels_t *' at 0x01ADF2D8> >)
    kdist_own(enc(0) id(1) sign(1) link(1))
    kdist_peer(enc(0) id(1) sign(1) link(1))
    auth_status(BLEGapSecStatus.confirm_value)
    Result: 1
    Pairing done
    And the code I'm using:
    def authenticate(self, conn_handle):
            adapter    = self.adapter                # adapter
            driver     = self.adapter.driver         # driver
            sd_driver  = BLESoftDevice               # softdevice api
            kdist_own   = BLEGapSecKDist(enc  = 1,
                                         id   = 1,
                                         sign = 0,
                                         link = 0)
            kdist_peer  = BLEGapSecKDist(enc  = 1,
                                         id   = 1,
                                         sign = 0,
                                         link = 0)
            sec_params  = BLEGapSecParams(bond          = True,
                                          mitm          = True,
                                          lesc          = True,
                                          oob           = True,
                                          keypress      = False,
                                          io_caps       = BLEGapIOCaps.keyboard_display,
                                          min_key_size  = 7,
                                          max_key_size  = 16,
                                          kdist_own     = kdist_own,
                                          kdist_peer    = kdist_peer)
            print("Auth 1")
            driver.ble_gap_authenticate(conn_handle, sec_params)
            print("Auth completed")
            # Send sec params
            adapter.evt_sync[conn_handle].wait(evt = BLEEvtID.gap_evt_sec_params_request)
            driver.ble_gap_sec_params_reply(conn_handle,
                                            BLEGapSecStatus.success,
                                            None)
            print("Sec params replying done")
            # Send passcode
            adapter.evt_sync[conn_handle].wait(evt = BLEEvtID.gap_evt_auth_key_request)
            key = util.list_to_uint8_array([0x30,0x30,0x30,0x30,0x30,0x30]).cast()
            res = sd_driver.sd_ble_gap_auth_key_reply(driver.rpc_adapter,
                                                      conn_handle,
                                                      0x01,     # PASSCODE
                                                      key)      # ASCII: 000000
            print("Key reply finished with code: {}".format(res))
            # Get pairing results and save key
            result = adapter.evt_sync[conn_handle].wait(evt = BLEEvtID.gap_evt_auth_status)
            print("Result: {}".format(result['error_src']))
            if result['auth_status'] ==  BLEGapSecStatus.success:
                print("Success")
                adapter.db_conns[conn_handle]._keyset = BLEGapSecKeyset.from_c(sd_driver._keyset)
            print("Pairing done")
  • I solved the problem above, what I had to do is authenticate with display_only iocaps.
  • Thanks .  I'm attempting to do a project that uses a passcode as well.  Do you mind sharing your working example?  I've looked elsewhere but I'm finding it surprisingly hard to find any Python examples.
  • Hi there, I don't have any code or devices right now, so I writed something may help you
    I didn't tested bonding with passcode, so it probably will not work without some changes
    import sys
    import time
    import Queue
    import logging
    from pc_ble_driver_py.observers     import *
    TARGET_DEV_ID = "000"       #Put your target MAC here (in format like ABCDABCDABCD not AB:CD:AB:CD:AB:CD)
    CONNECTIONS   = 1
    def init(conn_ic_id):
        global BLEDriver,        \
               BLEAdvData,       \
               BLEEvtID,         \
               BLEAdapter,       \
               BLEEnableParams,  \
               BLEGapTimeoutSrc, \
               BLEGapIOCaps,     \
               BLEUUID,          \
               BLEUUIDBase,      \
               BLEGapSecKDist,   \
               BLEGapSecParams,  \
               BLEGapSecStatus
        from pc_ble_driver_py import config
        config.__conn_ic_id__ = conn_ic_id
        from pc_ble_driver_py.ble_driver    import BLEDriver,        \
                                                   BLEAdvData,       \
                                                   BLEEvtID,         \
                                                   BLEEnableParams,  \
                                                   BLEGapTimeoutSrc, \
                                                   BLEGapIOCaps,     \
                                                   BLEUUID,          \
                                                   BLEUUIDBase,      \
                                                   BLEGapSecKDist,   \
                                                   BLEGapSecParams,  \
                                                   BLEGapSecStatus
        from pc_ble_driver_py.ble_adapter   import BLEAdapter
        global nrf_sd_ble_api_ver
        nrf_sd_ble_api_ver = config.sd_api_ver_get()
    class HRCollector(BLEDriverObserver, BLEAdapterObserver):
        def __init__(self, adapter):
            super(HRCollector, self).__init__()
            self.adapter    = adapter
            self.conn_q     = Queue.Queue()
            self.adapter.observer_register(self)
            self.adapter.driver.observer_register(self)
            self.keyset = None       # There we will store keys after bonding
            self.conn_handle = None  # Connection handler
        def open(self):
            self.adapter.driver.open()
            ble_enable_params = BLEEnableParams(vs_uuid_count      = 1,
                                                service_changed    = False,
                                                periph_conn_count  = 0,
                                                central_conn_count = CONNECTIONS,
                                                central_sec_count  = CONNECTIONS)
            if nrf_sd_ble_api_ver >= 3:
                print("Enabling larger ATT MTUs")
                ble_enable_params.att_mtu = 50
            self.adapter.driver.ble_enable(ble_enable_params)
        def close(self):
            self.adapter.driver.close()
        def connect_and_discover(self):
            self.adapter.driver.ble_gap_scan_start()
            new_conn = self.conn_q.get(timeout = 60)
                att_mtu = self.adapter.att_mtu_exchange(new_conn)
            self.adapter.service_discovery(new_conn)
            #self.adapter.enable_notification(new_conn, BLEUUID(BLEUUID.Standard.battery_level))
            #self.adapter.enable_notification(new_conn, BLEUUID(BLEUUID.Standard.heart_rate))
            return new_conn
        # Don't remember exactly on which event we have to reply after encryption (1 or 2)
        # 1
        #def on_gap_evt_sec_params_request(self, ble_driver, conn_handle, peer_params):
        #    pass
        # 2
        #def on_gap_evt_sec_info_request(self, ble_driver, conn_handle, peer_addr, master_id, enc_info, id_info, sign_info):
        #    pass
        def on_gap_evt_connected(self, ble_driver, conn_handle, peer_addr, role, conn_params):
            print('New connection: {}'.format(conn_handle))
            self.conn_q.put(conn_handle)
            self.conn_handle = conn_handle
            if self.keyset is not None:
                keys    = self.keyset
                ediv    = keys.enc_key.master_id.ediv
                rand    = keys.enc_key.master_id.rand
                ltk     = keys.enc_key.enc_info.ltk
                auth    = keys.enc_key.enc_info.auth
                lesc    = keys.enc_key.enc_info.auth
                ltk_len = keys.enc_key.enc_info.ltk_len
                self.adapter.encrypt(conn_handle,
                                     ediv=ediv,
                                     rand=rand,
                                     ltk=ltk,
                                     auth=auth,
                                     lesc=lesc,
                                     ltk_len=ltk_len)
        def on_gap_evt_disconnected(self, ble_driver, conn_handle, reason):
            print('Disconnected: {} {}'.format(conn_handle, reason))
        def on_gap_evt_timeout(self, ble_driver, conn_handle, src):
            if src == BLEGapTimeoutSrc.scan:
                ble_driver.ble_gap_scan_start()
        def on_gap_evt_adv_report(self, ble_driver, conn_handle, peer_addr, rssi, adv_type, adv_data):
            dev_name_list = None
            if BLEAdvData.Types.complete_local_name in adv_data.records:
                dev_name_list = adv_data.records[BLEAdvData.Types.complete_local_name]
            elif BLEAdvData.Types.short_local_name in adv_data.records:
                dev_name_list = adv_data.records[BLEAdvData.Types.short_local_name]
            else:
                return
            dev_name        = "".join(chr(e) for e in dev_name_list)
            address_string  = "".join("{0:02X}".format(b) for b in peer_addr.addr)
            print('Received advertisment report, address: 0x{}, device_name: {}'.format(address_string,
        dev_name))
            if (address_string == TARGET_DEV_ID):
                self.adapter.connect(peer_addr)
        def authenticate(self):
            """Do bonding
            :return: Success status (True/False)
            if self.conn_handle is None:
                return False
                                         id   = 1,
                                         sign = 0,
                                         link = 0)
                                         id   = 1,
                                         sign = 0,
                                         link = 0)
                                          mitm          = True,
                                          lesc          = True,
                                          oob           = True,
                                          keypress      = True,
                                          min_key_size  = 7,
                                          max_key_size  = 16,
            # Authenticate
            # Reply after event
                                            sec_params=None)
            # Save keys on success
            result = self.evt_sync[conn_handle].wait(evt = BLEEvtID.gap_evt_auth_status)
                self.keyset = adapter.db_conns[conn_handle]._keyset
                return True
            return False
        def save_keys(self):
            """Saving keys into the file
            # Save self.keyset
            pass
        def load_keys(self):
            """Load keys from the file
            # Load into self.keyset from file
            adapter.db_conns[conn_handle]._keyset = self.keyset # And load it into the driver
            pass
        def on_notification(self, ble_adapter, conn_handle, uuid, data):
            print('Connection: {}, {} = {}'.format(conn_handle, uuid, data))
        def on_att_mtu_exchanged(self, ble_driver, conn_handle, att_mtu):
            print('ATT MTU exchanged: conn_handle={} att_mtu={}'.format(conn_handle, att_mtu))
        def on_gattc_evt_exchange_mtu_rsp(self, ble_driver, conn_handle, **kwargs):
            print('ATT MTU exchange response: conn_handle={}'.format(conn_handle))
    def main(serial_port):
        print('Serial port used: {}'.format(serial_port))
        driver    = BLEDriver(serial_port=serial_port, auto_flash=False)
        adapter   = BLEAdapter(driver)
        collector = HRCollector(adapter)
        collector.open()
        for i in xrange(CONNECTIONS):
            conn_handle = collector.connect_and_discover()  # Connect
            collector.authenticate()                        # Do bonding (Note: don't use this method in any event handler defined in pc_ble_driver_py.observers
                                                            # such as on_connected(), so that program will not hang)
            collector.save_keys()                           # Save keys so in the next program's run we don't have to do bonding again
            #collector.load_keys()
            # wait for the device ready to connect
            # wait_ms(5000)
        time.sleep(30)
        print('Closing')
        collector.close()
    def item_choose(item_list):
        for i, it in enumerate(item_list):
            print('\t{} : {}'.format(i, it))
        print(' ')
        while True:
            try:
                choice = int(raw_input('Enter your choice: '))
                if ((choice >= 0) and (choice < len(item_list))):
                    break
            except Exception:
                pass
            print ('\tTry again...')
        return choice
    if __name__ == "__main__":
        serial_port = None
        if len(sys.argv) < 2:
            print("Please specify connectivity IC identifier (NRF51, NRF52)")
            exit(1)
        init(sys.argv[1])
        if len(sys.argv) == 3:
            serial_port = sys.argv[2]
        else:
            descs       = BLEDriver.enum_serial_ports()
            choices     = ['{}: {}'.format(d.port, d.serial_number) for d in descs]
            choice      = item_choose(choices)
            serial_port = descs[choice].port
        main(serial_port)
        quit()
    import sys
    import time
    import Queue
    import logging
    CONNECTIONS   = 1
        global BLEDriver,        \
               BLEAdvData,       \
               BLEEvtID,         \
               BLEAdapter,       \
               BLEEnableParams,  \
               BLEGapTimeoutSrc, \
               BLEGapIOCaps,     \
               BLEUUID,          \
               BLEUUIDBase,      \
               BLEGapSecKDist,   \
               BLEGapSecParams,  \
               BLEGapSecStatus
                                                   BLEAdvData,       \
                                                   BLEEvtID,         \
                                                   BLEEnableParams,  \
                                                   BLEGapTimeoutSrc, \
                                                   BLEGapIOCaps,     \
                                                   BLEUUID,          \
                                                   BLEUUIDBase,      \
                                                   BLEGapSecKDist,   \
                                                   BLEGapSecParams,  \
                                                   BLEGapSecStatus
        def open(self):
        def close(self):
            return new_conn
        # 1
        #    pass
        # 2
        #    pass
                keys    = self.keyset
                                     ediv=ediv,
                                     rand=rand,
                                     ltk=ltk,
                                     auth=auth,
                                     lesc=lesc,
                                     ltk_len=ltk_len)
            else:
                return
        dev_name))
            """Do bonding
                return False
                                         id   = 1,
                                         sign = 0,
                                         link = 0)
                                         id   = 1,
                                         sign = 0,
                                         link = 0)
                                          mitm          = True,
                                          lesc          = True,
                                          oob           = True,
                                          keypress      = True,
                                          min_key_size  = 7,
                                          max_key_size  = 16,
            # Authenticate
            # Reply after event
                                            sec_params=None)
                return True
            return False
            # Save self.keyset
            pass
            pass
        collector.open()
            # wait_ms(5000)
        time.sleep(30)
        print('Closing')
        collector.close()
        print(' ')
        while True:
            try:
                    break
            except Exception:
                pass
        return choice
        serial_port = None
            exit(1)
        init(sys.argv[1])
        else:
        main(serial_port)
        quit()
