hi sir
I need to test nRF52810 throughput , on s112
how can I fix the ble_app_att_mtu_throughput example change for nrf52810 ?
thanks
* Copyright (c) 2016 - 2018, Nordic Semiconductor ASA
* All rights reserved.
* list of conditions and the following disclaimer.
* Semiconductor ASA integrated circuit in a product or a software update for
* such product, must reproduce the above copyright notice, this list of
* conditions and the following disclaimer in the documentation and/or other
* materials provided with the distribution.
* contributors may be used to endorse or promote products derived from this
* software without specific prior written permission.
* Nordic Semiconductor ASA integrated circuit.
* engineered, decompiled, modified and/or disassembled.
/**@cond To Make Doxygen skip documentation generation for this file.
#include <stdbool.h>
#include <stdint.h>
#include <string.h>
#include <stdio.h>
#include "amt.h"
#include "counter.h"
#include "sdk_config.h"
#include "nrf.h"
#include "ble.h"
#include "ble_gatt.h"
#include "ble_hci.h"
#include "nordic_common.h"
#include "nrf_gpio.h"
#include "bsp_btn_ble.h"
#include "ble_srv_common.h"
#include "nrf_sdh.h"
#include "nrf_sdh_ble.h"
#include "nrf_ble_gatt.h"
#include "nrf_ble_qwr.h"
#include "ble_advdata.h"
#include "app_timer.h"
#include "app_error.h"
#include "nrf_cli.h"
#include "nrf_cli_rtt.h"
#include "nrf_cli_uart.h"
#include "nrf_pwr_mgmt.h"
#include "nrf_ble_scan.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#define DATA_LENGTH_DEFAULT 27 /**< The stack default data length. */
#define DATA_LENGTH_MAX 251 /**< The stack maximum data length. */
#define CONN_INTERVAL_DEFAULT (uint16_t)(MSEC_TO_UNITS(7.5, UNIT_1_25_MS)) /**< Default connection interval used at connection establishment by central side. */
#define CONN_INTERVAL_MIN (uint16_t)(MSEC_TO_UNITS(7.5, UNIT_1_25_MS)) /**< Minimum acceptable connection interval, in units of 1.25 ms. */
#define CONN_INTERVAL_MAX (uint16_t)(MSEC_TO_UNITS(500, UNIT_1_25_MS)) /**< Maximum acceptable connection interval, in units of 1.25 ms. */
#define CONN_SUP_TIMEOUT (uint16_t)(MSEC_TO_UNITS(4000, UNIT_10_MS)) /**< Connection supervisory timeout (4 seconds). */
#define SLAVE_LATENCY 0 /**< Slave latency. */
#define SCAN_ADV_LED BSP_BOARD_LED_0
#define READY_LED BSP_BOARD_LED_1
#define PROGRESS_LED BSP_BOARD_LED_2
#define DONE_LED BSP_BOARD_LED_3
#define BOARD_TESTER_BUTTON BSP_BUTTON_2 /**< Button to press at the beginning of the test to indicate that this board is connected to the PC and takes input from it via the UART. */
#define BOARD_DUMMY_BUTTON BSP_BUTTON_3 /**< Button to press at the beginning of the test to indicate that this board is standalone (automatic behavior). */
#define BUTTON_DETECTION_DELAY APP_TIMER_TICKS(50) /**< Delay from a GPIOTE event until a button is reported as pushed (in number of timer ticks). */
#define APP_BLE_CONN_CFG_TAG 1 /**< Tag that refers to the BLE stack configuration. */
#define APP_BLE_OBSERVER_PRIO 3 /**< BLE observer priority of the application. There is no need to modify this value. */
static uint8_t m_adv_handle = BLE_GAP_ADV_SET_HANDLE_NOT_SET; /**< Advertising handle used to identify an advertising set. */
static uint8_t m_enc_advdata[BLE_GAP_ADV_SET_DATA_SIZE_MAX]; /**< Buffer for storing an encoded advertising set. */
/**@brief Struct that contains pointers to the encoded advertising data. */
static ble_gap_adv_data_t m_adv_data =
.adv_data =
.p_data = m_enc_advdata,
.len = BLE_GAP_ADV_SET_DATA_SIZE_MAX
.scan_rsp_data =
.p_data = NULL,
.len = 0
typedef enum
NOT_SELECTED = 0x00,
BOARD_TESTER,
BOARD_DUMMY,
} board_role_t;
typedef struct
uint16_t att_mtu; /**< GATT ATT MTU, in bytes. */
uint16_t conn_interval; /**< Connection interval expressed in units of 1.25 ms. */
ble_gap_phys_t phys; /**< Preferred PHYs. */
uint8_t data_len; /**< Data length. */
bool conn_evt_len_ext_enabled; /**< Connection event length extension status. */
} test_params_t;
NRF_BLE_GATT_DEF(m_gatt); /**< GATT module instance. */
NRF_BLE_QWR_DEF(m_qwr); /**< Context for the Queued Write module.*/
BLE_DB_DISCOVERY_DEF(m_ble_db_discovery); /**< Database discovery module instance. */
NRF_BLE_SCAN_DEF(m_scan); /**< Scanning Module instance. */
//static nrf_ble_amtc_t m_amtc;
static nrf_ble_amts_t m_amts;
//NRF_SDH_BLE_OBSERVER(m_amtc_ble_obs, BLE_AMTC_BLE_OBSERVER_PRIO, nrf_ble_amtc_on_ble_evt, &m_amtc);
NRF_SDH_BLE_OBSERVER(m_amts_ble_obs, BLE_AMTS_BLE_OBSERVER_PRIO, nrf_ble_amts_on_ble_evt, &m_amts);
NRF_CLI_UART_DEF(cli_uart, 0, 64, 16);
NRF_CLI_RTT_DEF(cli_rtt);
NRF_CLI_DEF(m_cli_uart, " ", &cli_uart.transport, '\r', 4);
NRF_CLI_DEF(m_cli_rtt, " ", &cli_rtt.transport, '\n', 4);
static board_role_t volatile m_board_role = NOT_SELECTED;
static bool volatile m_run_test;
static bool volatile m_notif_enabled;
static bool volatile m_mtu_exchanged;
static bool volatile m_data_length_updated;
static bool volatile m_phy_updated;
static bool volatile m_conn_interval_configured;
static uint16_t m_conn_handle = BLE_CONN_HANDLE_INVALID; /**< Handle of the current BLE connection .*/
static uint8_t m_gap_role = BLE_GAP_ROLE_INVALID; /**< BLE role for this connection, see @ref BLE_GAP_ROLES */
// Name to use for advertising and connection.
//static char const m_target_periph_name[] = DEVICE_NAME;
// Test parameters.
// Settings like ATT MTU size are set only once, on the dummy board.
// Make sure that defaults are sensible.
static test_params_t m_test_params =
.att_mtu = NRF_SDH_BLE_GATT_MAX_MTU_SIZE,
.data_len = NRF_SDH_BLE_GAP_DATA_LENGTH,
.conn_interval = CONN_INTERVAL_DEFAULT,
.conn_evt_len_ext_enabled = false, //false // true
// Only symmetric PHYs are supported.
#if defined(S140)
.phys.tx_phys = BLE_GAP_PHY_2MBPS | BLE_GAP_PHY_1MBPS | BLE_GAP_PHY_CODED,
.phys.rx_phys = BLE_GAP_PHY_2MBPS | BLE_GAP_PHY_1MBPS | BLE_GAP_PHY_CODED,
#else
.phys.tx_phys = BLE_GAP_PHY_2MBPS | BLE_GAP_PHY_1MBPS,
.phys.rx_phys = BLE_GAP_PHY_2MBPS | BLE_GAP_PHY_1MBPS,
// Connection parameters requested for connection.
static ble_gap_conn_params_t m_conn_param =
.min_conn_interval = CONN_INTERVAL_MIN, // Minimum connection interval.
.max_conn_interval = CONN_INTERVAL_MAX, // Maximum connection interval.
.slave_latency = SLAVE_LATENCY, // Slave latency.
.conn_sup_timeout = CONN_SUP_TIMEOUT // Supervisory timeout.
static void test_terminate(void);
void data_len_set(uint8_t value);
char const * phy_str(ble_gap_phys_t phys)
static char const * str[] =
"1 Mbps",
"2 Mbps",
"Coded",
"Unknown"
switch (phys.tx_phys)
case BLE_GAP_PHY_1MBPS:
return str[0];
case BLE_GAP_PHY_2MBPS:
case BLE_GAP_PHY_2MBPS | BLE_GAP_PHY_1MBPS:
case BLE_GAP_PHY_2MBPS | BLE_GAP_PHY_1MBPS | BLE_GAP_PHY_CODED:
return str[1];
case BLE_GAP_PHY_CODED:
return str[2];
return str[3];
static void instructions_print(void)
// NRF_LOG_INFO("Type 'config' to change the configuration parameters.");
// NRF_LOG_INFO("You can use the Tab key to autocomplete your input.");
// NRF_LOG_INFO("Type 'run' when you are ready to run the test.");
/**@brief Function for handling BLE_GAP_EVT_CONNECTED events.
* Save the connection handle and GAP role, then discover the peer DB.
static void on_ble_gap_evt_connected(ble_gap_evt_t const * p_gap_evt)
ret_code_t err_code;
m_conn_handle = p_gap_evt->conn_handle;
m_gap_role = p_gap_evt->params.connected.role;
if (m_gap_role == BLE_GAP_ROLE_PERIPH)
// NRF_LOG_INFO("Connected as a peripheral.");
else if (m_gap_role == BLE_GAP_ROLE_CENTRAL)
// NRF_LOG_INFO("Connected as a central.");
// Stop scanning and advertising.
nrf_ble_scan_stop();
(void) sd_ble_gap_adv_stop(m_adv_handle);
bsp_board_leds_off();
// Assign connection handle to the Queued Write module.
// NRF_LOG_INFO("Discovering GATT database...");
// err_code = ble_db_discovery_start(&m_ble_db_discovery, p_gap_evt->conn_handle);
// APP_ERROR_CHECK(err_code);
// NRF_LOG_INFO("Sending PHY Update, %s.", phy_str(m_test_params.phys));
err_code = sd_ble_gap_phy_update(p_gap_evt->conn_handle, &m_test_params.phys);
/**@brief Function for handling BLE_GAP_EVT_DISCONNECTED events.
* Unset the connection handle and terminate the test.
static void on_ble_gap_evt_disconnected(ble_gap_evt_t const * p_gap_evt)
// NRF_LOG_DEBUG("Disconnected: reason 0x%x.", p_gap_evt->params.disconnected.reason);
if (m_run_test)
// NRF_LOG_WARNING("GAP disconnection event received while test was running.")
test_terminate();
/**@brief Function for handling BLE Stack events.
* @param[in] p_ble_evt Bluetooth stack event.
uint32_t err_code;
ble_gap_evt_t const * p_gap_evt = &p_ble_evt->evt.gap_evt;
case BLE_GAP_EVT_CONNECTED:
on_ble_gap_evt_connected(p_gap_evt);
on_ble_gap_evt_disconnected(p_gap_evt);
case BLE_GAP_EVT_CONN_PARAM_UPDATE:
m_conn_interval_configured = true;
// NRF_LOG_INFO("Connection interval updated: 0x%x, 0x%x.",
// p_gap_evt->params.conn_param_update.conn_params.min_conn_interval,
// p_gap_evt->params.conn_param_update.conn_params.max_conn_interval);
} break;
case BLE_GAP_EVT_CONN_PARAM_UPDATE_REQUEST:
// Accept parameters requested by the peer.
ble_gap_conn_params_t params;
params = p_gap_evt->params.conn_param_update_request.conn_params;
err_code = sd_ble_gap_conn_param_update(p_gap_evt->conn_handle, ¶ms);
// NRF_LOG_INFO("Connection interval updated (upon request): 0x%x, 0x%x.",
// p_gap_evt->params.conn_param_update_request.conn_params.min_conn_interval,
// p_gap_evt->params.conn_param_update_request.conn_params.max_conn_interval);
} break;
err_code = sd_ble_gatts_sys_attr_set(p_gap_evt->conn_handle, NULL, 0, 0);
} break;
case BLE_GATTC_EVT_TIMEOUT: // Fall through.
case BLE_GATTS_EVT_TIMEOUT:
// NRF_LOG_DEBUG("GATT timeout, disconnecting.");
err_code = sd_ble_gap_disconnect(m_conn_handle,
} break;
case BLE_GAP_EVT_PHY_UPDATE:
ble_gap_evt_phy_update_t const * p_phy_evt = &p_ble_evt->evt.gap_evt.params.phy_update;
if (p_phy_evt->status == BLE_HCI_STATUS_CODE_LMP_ERROR_TRANSACTION_COLLISION)
// Ignore LL collisions.
// NRF_LOG_DEBUG("LL transaction collision during PHY update.");
m_phy_updated = true;
ble_gap_phys_t phys = {0};
phys.tx_phys = p_phy_evt->tx_phy;
phys.rx_phys = p_phy_evt->rx_phy;
// NRF_LOG_INFO("PHY update %s. PHY set to %s.",
// (p_phy_evt->status == BLE_HCI_STATUS_CODE_SUCCESS) ?
// "accepted" : "rejected",
// phy_str(phys));
} break;
} break;
// No implementation needed.
/**@brief AMT server event handler. */
static void amts_evt_handler(nrf_ble_amts_evt_t evt)
switch (evt.evt_type)
case NRF_BLE_AMTS_EVT_NOTIF_ENABLED:
// NRF_LOG_INFO("Notifications enabled.");
bsp_board_led_on(READY_LED);
m_notif_enabled = true;
if (m_board_role != BOARD_TESTER)
return;
if (m_test_params.conn_interval != CONN_INTERVAL_DEFAULT)
// NRF_LOG_DEBUG("Updating connection parameters..");
m_conn_param.min_conn_interval = m_test_params.conn_interval;
m_conn_param.max_conn_interval = m_test_params.conn_interval;
err_code = sd_ble_gap_conn_param_update(m_conn_handle, &m_conn_param);
if (err_code != NRF_SUCCESS)
// NRF_LOG_ERROR("sd_ble_gap_conn_param_update() failed: 0x%x.", err_code);
} break;
case NRF_BLE_AMTS_EVT_NOTIF_DISABLED:
// NRF_LOG_INFO("Notifications disabled.");
bsp_board_led_off(READY_LED);
} break;
// case NRF_BLE_AMTS_EVT_TRANSFER_1KB:
// NRF_LOG_INFO("Sent %u KBytes", (evt.bytes_transfered_cnt / 1024));
// bsp_board_led_invert(PROGRESS_LED);
// } break;
case NRF_BLE_AMTS_EVT_TRANSFER_FINISHED:
counter_stop();
bsp_board_led_off(PROGRESS_LED);
bsp_board_led_on(DONE_LED);
uint32_t time_ms = counter_get();
uint32_t bit_count = (evt.bytes_transfered_cnt * 8);
float throughput_kbps = ((bit_count / (time_ms / 1000.f)) / 1000.f);
// NRF_LOG_ERROR("Done.");
NRF_LOG_ERROR("=============================");
NRF_LOG_ERROR("Time: %u.%.2u seconds elapsed.", (time_ms / 1000), (time_ms % 1000));
NRF_LOG_ERROR("Throughput: " NRF_LOG_FLOAT_MARKER " Kbps.",
NRF_LOG_FLOAT(throughput_kbps));
// NRF_LOG_INFO("Sent %u bytes of ATT payload.", evt.bytes_transfered_cnt);
// NRF_LOG_INFO("Retrieving amount of bytes received from peer...");
// err_code = nrf_ble_amtc_rcb_read(&m_amtc);
// if (err_code != NRF_SUCCESS)
// NRF_LOG_ERROR("nrf_ble_amtc_rcb_read() failed: 0x%x.", err_code);
// test_terminate();
} break;
///**@brief AMT Client event handler. */
//static void amtc_evt_handler(nrf_ble_amtc_t * p_amt_c, nrf_ble_amtc_evt_t * p_evt)
// ret_code_t err_code;
// switch (p_evt->evt_type)
// case NRF_BLE_AMT_C_EVT_DISCOVERY_COMPLETE:
// NRF_LOG_INFO("AMT service discovered at peer.");
// err_code = nrf_ble_amtc_handles_assign(p_amt_c,
// p_evt->conn_handle,
// &p_evt->params.peer_db);
// // Enable notifications.
// err_code = nrf_ble_amtc_notif_enable(p_amt_c);
// } break;
// case NRF_BLE_AMT_C_EVT_NOTIFICATION:
// static uint32_t bytes_cnt = 0;
// static uint32_t kbytes_cnt = 0;
// if (p_evt->params.hvx.bytes_sent == 0)
// bytes_cnt = 0;
// kbytes_cnt = 0;
// bytes_cnt += p_evt->params.hvx.notif_len;
// if (bytes_cnt > 1024)
// bytes_cnt -= 1024;
// kbytes_cnt++;
// NRF_LOG_INFO("Received %u kbytes", kbytes_cnt);
// nrf_ble_amts_rbc_set(&m_amts, p_evt->params.hvx.bytes_rcvd);
// if (p_evt->params.hvx.bytes_rcvd >= AMT_BYTE_TRANSFER_CNT)
// bsp_board_led_off(PROGRESS_LED);
// bytes_cnt = 0;
// kbytes_cnt = 0;
// NRF_LOG_INFO("Transfer complete, received %u bytes of ATT payload.",
// p_evt->params.hvx.bytes_rcvd);
// } break;
// case NRF_BLE_AMT_C_EVT_RBC_READ_RSP:
// NRF_LOG_INFO("Peer received %u bytes of ATT payload.", (p_evt->params.rcv_bytes_cnt));
// } break;
// default:
// break;
/**@brief Function for handling database discovery events.
* @details This function is a callback function to handle events from the database discovery module.
* Depending on the UUIDs that are discovered, this function forwards the events
* to their respective service instances.
* @param[in] p_evt Pointer to the database discovery event.
//static void db_disc_evt_handler(ble_db_discovery_evt_t * p_evt)
// nrf_ble_amtc_on_db_disc_evt(&m_amtc, p_evt);
/**@brief Function for handling events from the GATT library. */
static void gatt_evt_handler(nrf_ble_gatt_t * p_gatt, nrf_ble_gatt_evt_t const * p_evt)
switch (p_evt->evt_id)
case NRF_BLE_GATT_EVT_ATT_MTU_UPDATED:
m_mtu_exchanged = true;
// NRF_LOG_INFO("ATT MTU exchange completed. MTU set to %u bytes.",
// p_evt->params.att_mtu_effective);
} break;
case NRF_BLE_GATT_EVT_DATA_LENGTH_UPDATED:
m_data_length_updated = true;
// NRF_LOG_INFO("Data length updated to %u bytes.", p_evt->params.data_length);
} break;
nrf_ble_amts_on_gatt_evt(&m_amts, p_evt);
/**@brief Function for setting up advertising data. */
static void advertising_data_set(void)
ret_code_t ret;
ble_gap_adv_params_t const adv_params =
.properties =
.type = BLE_GAP_ADV_TYPE_CONNECTABLE_SCANNABLE_UNDIRECTED,
.p_peer_addr = NULL,
.filter_policy = BLE_GAP_ADV_FP_ANY,
.interval = ADV_INTERVAL,
.duration = 0,
.primary_phy = BLE_GAP_PHY_1MBPS, // Must be changed to connect in long range. (BLE_GAP_PHY_CODED)
.secondary_phy = BLE_GAP_PHY_1MBPS,
ble_advdata_t const adv_data =
.name_type = BLE_ADVDATA_FULL_NAME,
.flags = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE,
.include_appearance = false,
ret = ble_advdata_encode(&adv_data, m_adv_data.adv_data.p_data, &m_adv_data.adv_data.len);
APP_ERROR_CHECK(ret);
ret = sd_ble_gap_adv_set_configure(&m_adv_handle, &m_adv_data, &adv_params);
/**@brief Function for starting advertising. */
// NRF_LOG_INFO("Starting advertising.");
bsp_board_led_on(SCAN_ADV_LED);
ret_code_t err_code = sd_ble_gap_adv_start(m_adv_handle, APP_BLE_CONN_CFG_TAG);
///**@brief Function for handling Scanning Module events.
//static void scan_evt_handler(scan_evt_t const * p_scan_evt)
// ble_gap_evt_adv_report_t const * p_adv =
// p_scan_evt->params.filter_match.p_adv_report;
// ble_gap_scan_params_t const * p_scan_param =
// p_scan_evt->p_scan_params;
// switch(p_scan_evt->scan_evt_id)
// case NRF_BLE_SCAN_EVT_FILTER_MATCH:
// NRF_LOG_INFO("Device \"%s\" found, sending a connection request.",
// (uint32_t) m_target_periph_name);
// // Stop advertising.
// err_code = sd_ble_gap_adv_stop(m_adv_handle);
// if (err_code != NRF_ERROR_INVALID_STATE)
// // Initiate connection.
// m_conn_param.min_conn_interval = CONN_INTERVAL_DEFAULT;
// m_conn_param.max_conn_interval = CONN_INTERVAL_DEFAULT;
// err_code = sd_ble_gap_connect(&p_adv->peer_addr,
// p_scan_param,
// &m_conn_param,
// APP_BLE_CONN_CFG_TAG);
// NRF_LOG_ERROR("sd_ble_gap_connect() failed: 0x%x.", err_code);
// } break;
// default:
// break;
///**@brief Function for initialization the scanning and setting the filters.
//static void scan_init(void)
// err_code = nrf_ble_scan_init(&m_scan, NULL, scan_evt_handler);
// err_code = nrf_ble_scan_filter_set(&m_scan,
// SCAN_NAME_FILTER,
// m_target_periph_name);
// err_code = nrf_ble_scan_filters_enable(&m_scan,
// NRF_BLE_SCAN_NAME_FILTER,
// false);
///**@brief Function for starting the scanning. */
//static void scan_start(void)
// NRF_LOG_INFO("Starting scanning.");
// bsp_board_led_on(SCAN_ADV_LED);
// ret_code_t err_code = nrf_ble_scan_start(&m_scan);
static void log_init(void)
ret_code_t err_code = NRF_LOG_INIT(app_timer_cnt_get);
/**@brief Function for initializing the LEDs.
* @details Initializes all LEDs used by the application.
//static void leds_init(void)
// bsp_board_init(BSP_INIT_LEDS);
/**@brief Function for initializing the timer.
* @details Initializes the timer module. This creates and starts application timers.
static void timer_init(void)
///**@brief Function for enabling button input.
//static void buttons_enable(void)
// ret_code_t err_code = app_button_enable();
///**@brief Function for disabling button input. */
//static void buttons_disable(void)
// ret_code_t err_code = app_button_disable();
///**@brief Function for handling events from the button handler module.
// * @param[in] pin_no The pin that the event applies to.
// * @param[in] button_action The button action (press or release).
//static void button_evt_handler(uint8_t pin_no, uint8_t button_action)
// switch (pin_no)
// case BOARD_TESTER_BUTTON:
//// NRF_LOG_INFO("This board will act as tester.");
// instructions_print();
// m_board_role = BOARD_TESTER;
// } break;
// case BOARD_DUMMY_BUTTON:
// NRF_LOG_INFO("This board will act as responder.");
// m_board_role = BOARD_DUMMY;
// // Set the data length to the maximum if necessary, so that this board
// // accepts whatever value requested by the tester.
// uint8_t dl = 0;
// (void) nrf_ble_gatt_data_length_get(&m_gatt, BLE_CONN_HANDLE_INVALID, &dl);
// if (dl != DATA_LENGTH_MAX)
// data_len_set(DATA_LENGTH_MAX);
// advertising_start();
//// scan_start();
// } break;
// default:
// break;
// buttons_disable();
///**@brief Function for initializing the button library.
//static void buttons_init(void)
// // The array must be static because a pointer to it will be saved in the button library.
// static app_button_cfg_t buttons[] =
// {BOARD_TESTER_BUTTON, false, BUTTON_PULL, button_evt_handler},
// {BOARD_DUMMY_BUTTON, false, BUTTON_PULL, button_evt_handler}
// ret_code_t err_code = app_button_init(buttons, ARRAY_SIZE(buttons), BUTTON_DETECTION_DELAY);
//static void client_init(void)
// ret_code_t err_code = ble_db_discovery_init(db_disc_evt_handler);
// err_code = nrf_ble_amtc_init(&m_amtc, amtc_evt_handler);
/**@brief Function for handling Queued Write module errors.
* @details A pointer to this function is passed to each service that may need to inform the
* application about an error.
* @param[in] nrf_error Error code that contains information about what went wrong.
APP_ERROR_HANDLER(nrf_error);
/**@brief Function for initializing the Queued Write module.
static void qwr_init(void)
nrf_ble_qwr_init_t qwr_init_obj = {0};
qwr_init_obj.error_handler = nrf_qwr_error_handler;
err_code = nrf_ble_qwr_init(&m_qwr, &qwr_init_obj);
static void server_init(void)
qwr_init();
nrf_ble_amts_init(&m_amts, amts_evt_handler);
uint32_t ram_start = 0;
// Enable BLE stack.
/**@brief Function for initializing GAP parameters.
* @details This function sets up all the necessary GAP (Generic Access Profile) parameters of the
* device, including the device name and the preferred connection parameters.
(uint8_t const *)DEVICE_NAME,
strlen(DEVICE_NAME));
err_code = sd_ble_gap_ppcp_set(&m_conn_param);
/**@brief Function for initializing the GATT library. */
static void gatt_init(void)
ret_code_t err_code = nrf_ble_gatt_init(&m_gatt, gatt_evt_handler);
ret_code_t ret;
ret = nrf_pwr_mgmt_init();
void preferred_phy_set(ble_gap_phys_t * p_phy)
memcpy(&m_test_params.phys, p_phy, sizeof(ble_gap_phys_t));
void gatt_mtu_set(uint16_t att_mtu)
m_test_params.att_mtu = att_mtu;
err_code = nrf_ble_gatt_att_mtu_periph_set(&m_gatt, att_mtu);
err_code = nrf_ble_gatt_att_mtu_central_set(&m_gatt, att_mtu);
void connection_interval_set(uint16_t value)
m_test_params.conn_interval = value;
void conn_evt_len_ext_set(bool status)
ble_opt_t opt;
memset(&opt, 0x00, sizeof(opt));
opt.common_opt.conn_evt_ext.enable = status ? 1 : 0;
err_code = sd_ble_opt_set(BLE_COMMON_OPT_CONN_EVT_EXT, &opt);
m_test_params.conn_evt_len_ext_enabled = status;
err_code = nrf_ble_gatt_data_length_set(&m_gatt, BLE_CONN_HANDLE_INVALID, value);
m_test_params.data_len = value;
bool is_tester_board(void)
return (m_board_role == BOARD_TESTER);
void current_config_print(nrf_cli_t const * p_cli)
char const * role = (m_board_role == BOARD_TESTER) ? "tester" :
(m_board_role == BOARD_DUMMY) ? "dummy" : "not selected";
nrf_cli_fprintf(p_cli, NRF_CLI_NORMAL, "==== Current test configuration ====\r\n");
"Board role:\t\t%s\r\n"
"ATT MTU size:\t\t%d\r\n"
"Data length:\t\t%d\r\n"
"Connection interval:\t%d units\r\n"
"Connection length ext:\t%s\r\n"
"Preferred PHY:\t\t%s\r\n",
role,
m_test_params.att_mtu,
m_test_params.data_len,
m_test_params.conn_interval,
m_test_params.conn_evt_len_ext_enabled ? "on" : "off",
nrf_cli_fprintf(p_cli, NRF_CLI_NORMAL, "GAP event length:\t%d\r\n",
NRF_SDH_BLE_GAP_EVENT_LENGTH);
void test_begin(void)
// NRF_LOG_INFO("Preparing the test.");
NRF_LOG_FLUSH();
#if defined(S132)
// PHY does not need to be updated for s132.
switch (m_gap_role)
// If no connection was established, the role is not established either.
// In this case, start both the advertising and the scanning.
// scan_start();
case BLE_GAP_ROLE_PERIPH:
m_test_params.phys.tx_phys = BLE_GAP_PHY_2MBPS;
case BLE_GAP_ROLE_CENTRAL:
// scan_start();
static void test_run(void)
counter_start();
nrf_ble_amts_notif_spam(&m_amts);
static bool is_test_ready()
return ( (m_board_role == BOARD_TESTER)
&& m_conn_interval_configured
&& m_notif_enabled
&& m_mtu_exchanged
&& (m_data_length_updated || m_test_params.data_len == DATA_LENGTH_DEFAULT)
&& m_phy_updated
&& !m_run_test);
void cli_process(void)
nrf_cli_process(&m_cli_uart);
* @details Handles any pending operations, then sleeps until the next event occurs.
cli_process();
if (is_test_ready())
// NRF_LOG_INFO("Test started");
m_run_test = true;
test_run();
nrf_pwr_mgmt_run();
m_run_test = false;
m_notif_enabled = false;
m_mtu_exchanged = false;
m_data_length_updated = false;
m_phy_updated = false;
m_conn_interval_configured = false;
if (m_conn_handle != BLE_CONN_HANDLE_INVALID)
// NRF_LOG_INFO("Disconnecting...");
err_code = sd_ble_gap_disconnect(m_conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION);
// NRF_LOG_ERROR("sd_ble_gap_disconnect() failed: 0x%0x.", err_code);
if (m_board_role == BOARD_DUMMY)
// scan_start();
void cli_init(void)
if (CoreDebug->DHCSR & CoreDebug_DHCSR_C_DEBUGEN_Msk)
ret_code_t err_code = nrf_cli_init(&m_cli_rtt, NULL, true, true, NRF_LOG_SEVERITY_INFO);
nrf_drv_uart_config_t uart_config = NRF_DRV_UART_DEFAULT_CONFIG;
uart_config.pseltxd = TX_PIN_NUMBER;
uart_config.pselrxd = RX_PIN_NUMBER;
uart_config.hwfc = NRF_UART_HWFC_DISABLED;
ret_code_t err_code = nrf_cli_init(&m_cli_uart, &uart_config, true, true, NRF_LOG_SEVERITY_INFO);
void cli_start(void)
ret_code_t err_code = nrf_cli_start(&m_cli_uart);
// Initialize.
log_init();
cli_init();
//leds_init();
timer_init();
counter_init();
// buttons_init();
power_management_init();
ble_stack_init();
gap_params_init();
gatt_init();
advertising_data_set();
// scan_init();
server_init();
// client_init();
gatt_mtu_set(m_test_params.att_mtu);
conn_evt_len_ext_set(m_test_params.conn_evt_len_ext_enabled);
// Start execution.
cli_start();
// buttons_enable();
// NRF_LOG_INFO("ATT MTU example started.");
// NRF_LOG_INFO("Press button 3 on the board connected to the PC.");
// NRF_LOG_INFO("Press button 4 on other board.");
test_begin();
// Enter main loop.
for (;;)
idle_state_handle();
