When reading in values from ADC under high noise conditions the ADC reads come into the handler out of order. This is causing application resets left and right, does anyone having experience dealing this this issue?
I'm wondering if it's not the other way around, high noise conditions are causing HW resets and the resets are messing up the order of the ADC.
When I say the application resets I don't necessarily mean that the nrf chip gets a HW reset. Our application goes into an emergency protection mode and shuts off a high power device it's controlling. We have also seen HW resets, but not as often.
Wouldn't a true HW reset actually reset the ADC reads using the driver??
Thanks for the feedback.
"Wouldn't a true HW reset actually reset the ADC reads using the driver??"
The driver does not clear the memory of a buffer before it starts writing to it.
"When reading in values from ADC under high noise conditions the ADC reads come into the handler out of order."
"SMPS in the 1000W range within 10 inches of the chip"
-It would be beneficial to get a scope of the supply voltage when the issue occurs. Large PSUs like that usually has a lot of ripple noise.
"Rarely, but it happens."
-That is interesting. Is seems to indicate that issue occurs in the presence of the PSU, and the nature of the issue (samples out of order) seems to indicate a soft/hard reset or a broken logical state machine in SW. A scope of VDD and your source code would help a lot.
"I'm trying to configure the ADC to read in a single sample from 7 channels on a PPI interrupt at an -interval of approximately 340us."
I'd like to see your source code.
We can change from public to private Question if you do not want to share your IP with the public.
