Is there a similar way tot get the radio's MAC address when using Gazell only (no BLE)?
In SoftDevice there is a "sd_ble_gap_address_get()" function call.
The RF address in bluetooth (MAC) is different from the RF address in gazell, in terms of the length and build-up.
To get/set the RF address in gazell, you need to use the functions given by the gazell API: developer.nordicsemi.com/.../a00955.html
Here are the functions you're looking for (snippet from nrf_gzll.h):
* @brief Set the base address for pipe 0.
* The full on-air address for each pipe is composed of a multi-byte base address
* prepended to a prefix byte.
* For packets to be received correctly, the most significant byte of
* the base address should not be an alternating sequence of 0s and 1s i.e.
* it should not be 0x55 or 0xAA.
* @param base_address The 4 byte base address. All bytes are used.
* @retval true If the parameter was set.
* @return false If Gazell was enabled.
bool nrf_gzll_set_base_address_0(uint32_t base_address);
* @brief Get function counterpart to nrf_gzll_set_base_address_0().
* @return Base address 0.
uint32_t nrf_gzll_get_base_address_0(void);
* @brief Set the base address for pipes 1-7.
* Pipes 1 through 7 share base_address_1. @sa nrf_gzll_set_base_address_0.
* @retval false If Gazell was enabled.
bool nrf_gzll_set_base_address_1(uint32_t base_address);
* @brief Get function counterpart to nrf_gzll_set_base_address_1().
* @return Base address 1.
uint32_t nrf_gzll_get_base_address_1(void);
* @brief Set the address prefix byte for a specific pipe.
* Each pipe should have its own unique prefix byte.
* @param pipe The pipe that the address should apply to.
* This value must be < NRF_GZLL_CONST_PIPE_COUNT.
* @param address_prefix_byte The address prefix byte.
* @retval false If Gazell was enabled, or if the pipe was invalid.
bool nrf_gzll_set_address_prefix_byte(uint32_t pipe, uint8_t address_prefix_byte);
* @brief Get function counterpart to nrf_gzll_set_address_prefix_byte().
* @param pipe The pipe for which to get the address.
* @param out_address_prefix_byte The pointer in which to return the
* address prefix byte.
* @retval true If the parameter was returned.
* @retval false If Gazell was enabled, the pipe was invalid or
* out_address was a NULL pointer.
bool nrf_gzll_get_address_prefix_byte(uint32_t pipe, uint8_t* out_address_prefix_byte);
I don't really want to get and set the address for gazell. I understand how those addresses are used.
What I actually want to do with the MAC address is use it is as a unique identifier, instead of creating my own serial number for the device. If there is already a unique random number that is generated at manufacturing of the silicon then I'd like to leverage number as a way of tracking the final product.
So to rephrase my question. Regardless of gazell or softdevice, is the radio's random 6 byte MAC address available via registers to read from the nRF51822?
Yes, there are several such identifiers. The BLE address used by the softdevices is based on a random number that is programmed into the chip during manufacturing. You can use this 48-bit value regardless of gazell or softdevice.
There's also a 64-bit device ID (also programmed during manufacturing) that can be used for this purpose.
Both these numbers are found in the Factory Information Configuration Register (FICR). See section 6 of the nRF51 Reference Manual. Specifically look for the DEVICEID and DEVICEADDR registers.
Thank you very much! Exactly what I was looking for.
