I am creating an iOS which needs to talk with nRF51822 Soft devices 100.
Problem i am facing is, I am not able to Encrypt the connection properly.
I am using
When looking at Wireshark Packets the logs which i can see are
I am using
Will this code run on the nRF51 DK? In that case, can you upload the application FW along with the softdevice so I can test it here? I'm pretty sure that the "RemoveFromWhiteList" line isn't related to pairing. You can check if the peripheral is bonded with the phone by looking at the "My device" list in Settings->Bluetooth. All bonded devices will be listed there.
Encrypted packet decrypted incorrectly (bad MIC)
Note that you will get the same error if the sniffer has not captured the long term key during the initial key exchange.
Yes the above BAD MIC was because sniffer could not capture the long term key, My bad starting the Sniffer at the end of process.
The Logs i attached currently shows most of the interaction happening between iOS and BLE Device.
App Finds the Device.
Connects to it
Try to Retreive the Services and Characteristics
Tries to subscribe to notifications.(After which Pairing Alert is visible to user on UI)
Then you can see in Logs It proceeds with encryption.
Then on packet number 153. I terminate the App, which kills the connection between the device and iOS.
Then at around packet number 359, i again start the mobile app to connect to the BLE Device. but it never gets connected. It keeps on transferring data.
And yes i can see the Paired/Bonded device in iOS settings even after disconnection from App, So looks like Mobile is not throwing any kind of information. but BLE device is not responding to Mobiles encryption request.
Thanks for providing the sniffer trace. Have you tried to debug the code to see if the program gets stuck or reset once you re-connect after the bond is established? I see that there are lot of re-transmits after the slave sends the encryption request which indicate that the link becomes lost as soon as the request is sent.
Edit. not related to the issue here, but wanted to add that you may impacted by this if you use s110: https://devzone.nordicsemi.com/b/blog/posts/what-impact-does-the-deprecation-and-withdrawal-of-bluetooth-core-specification-v4-0-and-v4-1-have-on-your-current-and-future-products?CommentId=84db79f6-ea63-4381-81f5-ca0520ab0cf4
Thanks Vidar, For your response and Letting us know about the impact on s110 because of Deprecation.
I am sorry we dont have the Complete code, its the compiled system that has been passed on to me.
But if you can point me to some place which can detail out how should the encryption proceed if everything is right. And how to understand Packets being transmitted, while looking at sniffer logs.
And i am curious after analysing Sniffer Logs, i can see More Data bit is set to 1 in frame 371(Which is start Encryption request), But its 0 in frame 66, During first time Connection.
Much appreciate your help.
Have you tested this with other phones, an Android phone for instance? If it works with other phones you could use the sniffer trace from those connections to compare against. To me it looks more like an issue with the 51 FW. I couldn't spot any errors in the pairing procedure at least.
Soan said:And i am curious after analysing Sniffer Logs, i can see More Data bit is set to 1 in frame 371(Which is start Encryption request), But its 0 in frame 66, During first time Connection.
I'm afraid I don't have a good explanation for this. I don't think it's a spec. violation, but seems strange that the MD bit is always set on this control packet.
