I meet a problem during programming combo hid(keyboard+multi touch)on nrf52.
Hi
I met a problem during programming a combo of HID on nrf52.
I have set combo HID that have keyboard and multi touch.
after pairing my smartphone(galaxy note 8), keyboard data doesn't sent to my phone but multi touch os ok.
after some debugging, i found that a certain sentence of multich touch HID bring up a problem.
HID sentence of problem is contact identifier. refer to below.
0x09, 0x51,        //     Usage (0x51 - Contact identifier)
0x26, 0xFF, 0x00,  //     Logical Maximum (255)
0x75, 0x08,        //     Report Size (8)
0x95, 0x01,        //     Report Count (1)
0x81, 0x02,        //     Input (Data,Var,Abs,No Wrap,Linear,Preferred State,No Null Position)
I have no idea for soving this problem.
please guide me any way .
thanks
My entire HID report map is .
static uint8_t report_map_data[] =
        0x05, 0x01,                 // Usage Page (Generic Desktop)
        0x09, 0x06,                 // Usage (Keyboard)
        0xA1, 0x01,                 // Collection (Application)
      0x85, 0x01,                 //     Report Id (1)
        0x05, 0x07,                 //     Usage Page (Key Codes)
        0x19, 0xe0,                 //     Usage Minimum (224)
        0x29, 0xe7,                 //     Usage Maximum (231)
        0x15, 0x00,                 //     Logical Minimum (0)
        0x25, 0x01,                 //     Logical Maximum (1)
        0x75, 0x01,                 //     Report Size (1)
        0x95, 0x08,                 //     Report Count (8)
        0x81, 0x02,                 //     Input (Data, Variable, Absolute)
        0x81, 0x01,                 //     Input (Constant) reserved byte(1)
#if 0
        0x95, 0x05,                 //     Report Count (5)
        0x05, 0x08,                 //     Usage Page (Page# for LEDs)
        0x19, 0x01,                 //     Usage Minimum (1)
        0x29, 0x05,                 //     Usage Maximum (5)
        0x91, 0x02,                 //     Output (Data, Variable, Absolute), Led report
        0x75, 0x03,                 //     Report Size (3)
        0x91, 0x01,                 //     Output (Data, Variable, Absolute), Led report padding
        0x95, 0x06,                 //     Report Count (6)
        //0x95, 0x01,
        //0x25, 0x65,                 //     Logical Maximum (101)
        0x25, 0x82,
        0x05, 0x07,                 //     Usage Page (Key codes)
        0x19, 0x00,                 //     Usage Minimum (0)
        //0x29, 0x65,                 //     Usage Maximum (101)
        0x29, 0x82,
        0x81, 0x00,                 //     Input (Data, Array) Key array(6 bytes)
        0x09, 0x05,                 //     Usage (Vendor Defined)
        0x75, 0x08,                 //     Report Count (2)
        0x95, 0x02,                 //     Report Size (8 bit)
        0xB1, 0x02,                 //     Feature (Data, Variable, Absolute)
        0xC0,                       // End Collection (Application)
#ifdef _DUALTOUCH_
        0x05, 0x0D,        // Usage Page (Digitizer)
        0x09, 0x04,        // Usage (Touch Screen)
        0x85, 0x02,        //   Report Id 2
        0x09, 0x22,        //   Usage (Finger)
        0xA1, 0x02,        //   Collection (Logical)
        0x09, 0x42,        //     Usage (Tip Switch)
        0x09, 0x30,        //     Usage (Tip Pressure)
        0x25, 0x7F,        //     Logical Maximum (127)
        0x75, 0x07,        //     Report Size (7)
        0x05, 0x01,        //     Usage Page (Generic Desktop Ctrls)
        0x09, 0x30,        //     Usage (X)
        0x09, 0x31,        //     Usage (Y)
        0x26, 0xFF, 0x7F,  //     Logical Maximum (32767)
        0x65, 0x00,        //     Unit (None)
        0x75, 0x10,        //     Report Size (16)
        0x95, 0x02,        //     Report Count (2)
        0x35, 0x00,                    //     PHYSICAL_MINIMUM (0)
    0x05, 0x0d,                    //     USAGE_PAGE (Digitizers)
    0x26, 0xff, 0x00,              //     LOGICAL_MAXIMUM (255)
    0x46, 0xff, 0x00,              //     PHYSICAL_MAXIMUM (255)
    0x75, 0x08,                    //     REPORT_SIZE (8)
    0x95, 0x02,                    //     REPORT_COUNT (2)
    0x09, 0x48,                    //     USAGE (Width)            //width of contact (0 ~ 255)
    0x09, 0x49,                    //     USAGE (Height)           //Height of contact  (0 ~ 255)
    0x81, 0x02,                    //     INPUT (Data,Var,Abs)
        0x27, 0xFF, 0xFF, 0x00, 0x00,  //   Logical Maximum (65534)
        0x09, 0x56,        //   Usage (0x56 - Scan Time)
        0x09, 0x54,        //   Usage (0x54 - Contact count)
        0x25, 0x05,        //   Logical Maximum (5)
        0x09, 0x55,        //   Usage (0x55 - Contact point maximum)
        0x25, 0x0A,        //   Logical Maximum (10)
        0xB1, 0x02,        //   Feature (Data,Var,Abs,No Wrap,Linear,Preferred State,No Null Position,Non-volatile)
    mycol said:
    #define INPUT_REPORT_KEYS_MAX_LEN           8
    This define must reflect the maximum number of bytes that you send using your descriptor, as it is fed into the BLE_HIDS_DEF() macro.
    As I read your descriptor, the amount of bytes you send is the keyboard descriptor + digitizer usage at the end of your descriptor.
    Have you tried isolating each descriptor to see if they work independent of each other?
    Have you tried capturing a sniffer trace (using the nrf sniffer) to see what goes over-the-air (if yes; please post the sniffer trace) ?
    Håkon
