I meet a problem during programming combo hid(keyboard+multi touch)on nrf52.
Hi
I met a problem during programming a combo of HID on nrf52.
I have set combo HID that have keyboard and multi touch.
after pairing my smartphone(galaxy note 8), keyboard data doesn't sent to my phone but multi touch os ok.
after some debugging, i found that a certain sentence of multich touch HID bring up a problem.
HID sentence of problem is contact identifier. refer to below.
0x09, 0x51,        //     Usage (0x51 - Contact identifier)
0x26, 0xFF, 0x00,  //     Logical Maximum (255)
0x75, 0x08,        //     Report Size (8)
0x95, 0x01,        //     Report Count (1)
0x81, 0x02,        //     Input (Data,Var,Abs,No Wrap,Linear,Preferred State,No Null Position)
I have no idea for soving this problem.
please guide me any way .
thanks
My entire HID report map is .
static uint8_t report_map_data[] =
        0x05, 0x01,                 // Usage Page (Generic Desktop)
        0x09, 0x06,                 // Usage (Keyboard)
        0xA1, 0x01,                 // Collection (Application)
      0x85, 0x01,                 //     Report Id (1)
        0x05, 0x07,                 //     Usage Page (Key Codes)
        0x19, 0xe0,                 //     Usage Minimum (224)
        0x29, 0xe7,                 //     Usage Maximum (231)
        0x15, 0x00,                 //     Logical Minimum (0)
        0x25, 0x01,                 //     Logical Maximum (1)
        0x75, 0x01,                 //     Report Size (1)
        0x95, 0x08,                 //     Report Count (8)
        0x81, 0x02,                 //     Input (Data, Variable, Absolute)
        0x81, 0x01,                 //     Input (Constant) reserved byte(1)
#if 0
        0x95, 0x05,                 //     Report Count (5)
        0x05, 0x08,                 //     Usage Page (Page# for LEDs)
        0x19, 0x01,                 //     Usage Minimum (1)
        0x29, 0x05,                 //     Usage Maximum (5)
        0x91, 0x02,                 //     Output (Data, Variable, Absolute), Led report
        0x75, 0x03,                 //     Report Size (3)
        0x91, 0x01,                 //     Output (Data, Variable, Absolute), Led report padding
        0x95, 0x06,                 //     Report Count (6)
        //0x95, 0x01,
        //0x25, 0x65,                 //     Logical Maximum (101)
        0x25, 0x82,
        0x05, 0x07,                 //     Usage Page (Key codes)
        0x19, 0x00,                 //     Usage Minimum (0)
        //0x29, 0x65,                 //     Usage Maximum (101)
        0x29, 0x82,
        0x81, 0x00,                 //     Input (Data, Array) Key array(6 bytes)
        0x09, 0x05,                 //     Usage (Vendor Defined)
        0x75, 0x08,                 //     Report Count (2)
        0x95, 0x02,                 //     Report Size (8 bit)
        0xB1, 0x02,                 //     Feature (Data, Variable, Absolute)
        0xC0,                       // End Collection (Application)
#ifdef _DUALTOUCH_
        0x05, 0x0D,        // Usage Page (Digitizer)
        0x09, 0x04,        // Usage (Touch Screen)
        0x85, 0x02,        //   Report Id 2
        0x09, 0x22,        //   Usage (Finger)
        0xA1, 0x02,        //   Collection (Logical)
        0x09, 0x42,        //     Usage (Tip Switch)
        0x09, 0x30,        //     Usage (Tip Pressure)
        0x25, 0x7F,        //     Logical Maximum (127)
        0x75, 0x07,        //     Report Size (7)
        0x05, 0x01,        //     Usage Page (Generic Desktop Ctrls)
        0x09, 0x30,        //     Usage (X)
        0x09, 0x31,        //     Usage (Y)
        0x26, 0xFF, 0x7F,  //     Logical Maximum (32767)
        0x65, 0x00,        //     Unit (None)
        0x75, 0x10,        //     Report Size (16)
        0x95, 0x02,        //     Report Count (2)
        0x35, 0x00,                    //     PHYSICAL_MINIMUM (0)
    0x05, 0x0d,                    //     USAGE_PAGE (Digitizers)
    0x26, 0xff, 0x00,              //     LOGICAL_MAXIMUM (255)
    0x46, 0xff, 0x00,              //     PHYSICAL_MAXIMUM (255)
    0x75, 0x08,                    //     REPORT_SIZE (8)
    0x95, 0x02,                    //     REPORT_COUNT (2)
    0x09, 0x48,                    //     USAGE (Width)            //width of contact (0 ~ 255)
    0x09, 0x49,                    //     USAGE (Height)           //Height of contact  (0 ~ 255)
    0x81, 0x02,                    //     INPUT (Data,Var,Abs)
        0x27, 0xFF, 0xFF, 0x00, 0x00,  //   Logical Maximum (65534)
        0x09, 0x56,        //   Usage (0x56 - Scan Time)
        0x09, 0x54,        //   Usage (0x54 - Contact count)
        0x25, 0x05,        //   Logical Maximum (5)
        0x09, 0x55,        //   Usage (0x55 - Contact point maximum)
        0x25, 0x0A,        //   Logical Maximum (10)
        0xB1, 0x02,        //   Feature (Data,Var,Abs,No Wrap,Linear,Preferred State,No Null Position,Non-volatile)
    Does this work on other platforms, like windows 10 or linux?
    Is the issue specific to this phone, or does it work on other brands/versions of android?
    HĂĄkon
  • Hi
    I tested on winwows10(notebook).
    keyboard data is sending to notebook correctly.
    I haved another test.
    I committed out Contact identifier sentence only as below.
    //0x09, 0x51,        //     Usage (0x51 - Contact identifier)
    then keyboard data is sending correctly but about touch, it operate as single touch.
    I wonder whether this problem is by my firmware or by android itself.
    thanks
    Could you share a bit more regarding how you send data? It sounds like each descriptor itself works individually, but when concatenated; it seems to have issues.
     This part of your descriptor is a part of your main collection, meaning you have to send these for every report being sent (even for keyboard). I do not have much knowledge about multi-touch descriptors, but it looks like you want this to be a part of the report id 2 collection?
    As it it set up now, all these usages are on the top-level collection (meaning; they are required to be set by all report IDs): "scan time", "contact count", and "contact point maximum"
    That might be how you want the application to be, but it does sound a bit unusual.
    HĂĄkon
  • Hi
    As you requested above, i had added three items and tested .
    The result is the same (keyboard data doesn't sent.
    i would like to show you related  functions for more understanding.
    #define INPUT_REPORT_COUNT                           2
    #define INPUT_REPORT_KEYS_MAX_LEN           8
    #define INPUT_REPORT_TOUCH_MAX_LEN        1
    #define INPUT_REP_REF_ID                    1                                          /**< Id of reference to Keyboard Input Report. */
    #define INPUT_REP_TOUCH_ID              2
    BLE_HIDS_DEF(m_hids,                                                /**< Structure used to identify the HID service. */
                 NRF_SDH_BLE_TOTAL_LINK_COUNT,
                 INPUT_REPORT_KEYS_MAX_LEN,
                 INPUT_REPORT_TOUCH_MAX_LEN);
    void sendActionByKey(unsigned char key)                 //function for sending keyboard data
      uint32_t err_code;
     uint8_t  data[INPUT_REPORT_KEYS_MAX_LEN];
     memset(data, 0, sizeof(data));
     data[2] = key;//0x28;
     err_code = ble_hids_inp_rep_send(&m_hids,
                                   INPUT_REPORT_KEYS_INDEX,
                                   data,
                                   m_conn_handle);
      data[2] = 0x00;
                                   data,
                                   m_conn_handle);
    static void hids_init(void)
        ret_code_t                 err_code;
        ble_hids_init_t            hids_init_obj;
        ble_hids_inp_rep_init_t  * p_input_report;
        ble_hids_outp_rep_init_t * p_output_report;
        uint8_t                    hid_info_flags;
        static ble_hids_inp_rep_init_t  input_report_array[INPUT_REPORT_COUNT];
    #if 0
            //0x95, 0x01,
            0x25, 0x82,
            0x29, 0x82,
    #ifdef _DUALTOUCH_
        memset((void *)input_report_array, 0, sizeof(input_report_array));
        //memset((void *)output_report_array, 0, sizeof(ble_hids_outp_rep_init_t)*1);
        // Initialize HID Service
        p_input_report                      = &input_report_array[INPUT_REPORT_KEYS_INDEX];
        p_input_report->max_len             = INPUT_REPORT_KEYS_MAX_LEN;
        p_input_report->rep_ref.report_id   = INPUT_REP_REF_ID;
        p_input_report->rep_ref.report_type = BLE_HIDS_REP_TYPE_INPUT;
        BLE_GAP_CONN_SEC_MODE_SET_ENC_NO_MITM(&p_input_report->security_mode.cccd_write_perm);
        BLE_GAP_CONN_SEC_MODE_SET_ENC_NO_MITM(&p_input_report->security_mode.read_perm);
        BLE_GAP_CONN_SEC_MODE_SET_ENC_NO_MITM(&p_input_report->security_mode.write_perm);
    #if 0
        p_output_report                      = &output_report_array[OUTPUT_REPORT_INDEX];
        p_output_report->max_len             = OUTPUT_REPORT_MAX_LEN;
        p_output_report->rep_ref.report_id   = OUTPUT_REP_REF_ID;
        p_output_report->rep_ref.report_type = BLE_HIDS_REP_TYPE_OUTPUT;
        BLE_GAP_CONN_SEC_MODE_SET_ENC_NO_MITM(&p_output_report->security_mode.read_perm);
        BLE_GAP_CONN_SEC_MODE_SET_ENC_NO_MITM(&p_output_report->security_mode.write_perm);
    #if 1
        //  Initialize HID Service - Touch axis
        p_input_report                      = &input_report_array[INPUT_REPORT_TOUCH_INDEX];
        p_input_report->max_len             = INPUT_REPORT_TOUCH_MAX_LEN;
        p_input_report->rep_ref.report_id   = INPUT_REP_TOUCH_ID;
        hid_info_flags = HID_INFO_FLAG_REMOTE_WAKE_MSK | HID_INFO_FLAG_NORMALLY_CONNECTABLE_MSK;
        memset(&hids_init_obj, 0, sizeof(hids_init_obj));
        hids_init_obj.evt_handler                    = on_hids_evt;
        hids_init_obj.error_handler                  = service_error_handler;
        hids_init_obj.is_kb                          = true;
        hids_init_obj.is_mouse                       = true;
        hids_init_obj.inp_rep_count                  = INPUT_REPORT_COUNT;
        hids_init_obj.p_inp_rep_array                = input_report_array;
        hids_init_obj.outp_rep_count                 = 0;
        hids_init_obj.p_outp_rep_array               = NULL;
        hids_init_obj.feature_rep_count              = 0;
        hids_init_obj.p_feature_rep_array            = NULL;
        hids_init_obj.rep_map.data_len               = sizeof(report_map_data);
        hids_init_obj.rep_map.p_data                 = report_map_data;
        hids_init_obj.hid_information.bcd_hid        = BASE_USB_HID_SPEC_VERSION;
        hids_init_obj.hid_information.b_country_code = 0;
        hids_init_obj.hid_information.flags          = hid_info_flags;
        hids_init_obj.included_services_count        = 0;
        hids_init_obj.p_included_services_array      = NULL;
        BLE_GAP_CONN_SEC_MODE_SET_ENC_NO_MITM(&hids_init_obj.rep_map.security_mode.read_perm);
        BLE_GAP_CONN_SEC_MODE_SET_NO_ACCESS(&hids_init_obj.rep_map.security_mode.write_perm);
        BLE_GAP_CONN_SEC_MODE_SET_ENC_NO_MITM(&hids_init_obj.hid_information.security_mode.read_perm);
        BLE_GAP_CONN_SEC_MODE_SET_NO_ACCESS(&hids_init_obj.hid_information.security_mode.write_perm);
            &hids_init_obj.security_mode_boot_mouse_inp_rep.cccd_write_perm);
            &hids_init_obj.security_mode_boot_mouse_inp_rep.read_perm);
            &hids_init_obj.security_mode_boot_mouse_inp_rep.write_perm);
            &hids_init_obj.security_mode_boot_kb_inp_rep.cccd_write_perm);
        BLE_GAP_CONN_SEC_MODE_SET_ENC_NO_MITM(&hids_init_obj.security_mode_boot_kb_inp_rep.read_perm);
        BLE_GAP_CONN_SEC_MODE_SET_NO_ACCESS(&hids_init_obj.security_mode_boot_kb_inp_rep.write_perm);
        //BLE_GAP_CONN_SEC_MODE_SET_ENC_NO_MITM(&hids_init_obj.security_mode_boot_kb_outp_rep.read_perm);
        //BLE_GAP_CONN_SEC_MODE_SET_ENC_NO_MITM(&hids_init_obj.security_mode_boot_kb_outp_rep.write_perm);
        BLE_GAP_CONN_SEC_MODE_SET_ENC_NO_MITM(&hids_init_obj.security_mode_protocol.read_perm);
        BLE_GAP_CONN_SEC_MODE_SET_ENC_NO_MITM(&hids_init_obj.security_mode_protocol.write_perm);
        BLE_GAP_CONN_SEC_MODE_SET_NO_ACCESS(&hids_init_obj.security_mode_ctrl_point.read_perm);
        BLE_GAP_CONN_SEC_MODE_SET_ENC_NO_MITM(&hids_init_obj.security_mode_ctrl_point.write_perm);
        err_code = ble_hids_init(&m_hids, &hids_init_obj);
    thanks
