Task delay faster that expected
I am using nRF52832, SDK 15. My code is based on the freeRTOS code examples.
I am trying to Run my Task Every 10 ms. I tried to test this by using a counter to print every minute. And every minute ,the notification appears after 58.6 seconds.
To Run my Task i am using this function vTaskDelayUntil(&LastWakeTime, pdMS_TO_TICKS(10)); the variable LastWakeTime is been initialized with LastWakeTime = xTaskGetTickCount();
It seemed that the Delay for 10.24 (10) ticks (10 ms) could it cause system clock to be faster ?
If i will change the configTICK_RATE_HZ to a round number (2000 for example) would it have any performance downside? (not being a power of 2)  and would it solve this?
Thanks A lot
ibrahim
    I guess the problem will remain.
    The fact is that the RTS is used to clock the core of the RTOS. There is no possibility to choose a divider so that it gives 1ms.
    Currently divide 32 is used (if you look at the documentation, the divisor is given as a power of 2).
    37768 Hz / 32 = 1024 Hz
    Therefore, a context switch every 1000/1024 = 0.976 ms.
    From here and there is an error while waiting.
    If you need precisely deterministic delays, you can use the hardware timer and direct task notification.
    Max
  • Thank you both for the answer ,
    May i have a sample code for the hardware timer and direct task notification??.
    Thanks A lot
    ibrahim
  • This is a very simplified example written in a couple of minutes. But it shows the necessary basic functions.
    bool TimerCreate (void)
      NRF_TIMER1->MODE       = TIMER_MODE_MODE_Timer<<TIMER_MODE_MODE_Pos;
      NRF_TIMER1->BITMODE    = TIMER_BITMODE_BITMODE_32Bit;
      NRF_TIMER1->PRESCALER  = 0x09;		// 16 MHz / 2^9 = 31.25 kHz
      NRF_TIMER1->CC[0]      = 60*31250;    // 60 sec = 1 min
      NRF_TIMER1->INTENSET   = TIMER_INTENSET_COMPARE0_Enabled<<TIMER_INTENSET_COMPARE0_Pos;
      // Enable timer interupt
      NVIC_ClearPendingIRQ(TIMER1_IRQn);
      NVIC_EnableIRQ(TIMER1_IRQn);
      return NRF_SUCCESS;
    xTaskHandle hSomeTask;
    bool CreateSomeTask (uint8_t StackSize, uint8_t Priority)
    	return xTaskCreate(tSomeTask, "SomeTask", StackSize, NULL, Priority, &hSomeTask);
    void tSomeTask  (void *pvConext)
    	// Init all what you need
    	TimerCreate();	// Create 1min timer
    	// Task Body
    	for(;;)
    		// Wait notification
    		xTaskNotifyWait(0x00, 0xffff, NULL, portMAX_DELAY);
    		/* do something*/
    /* Timer interupt handler */
    void TIMER1_IRQHandler(void)
      if(NRF_TIMER1->EVENTS_COMPARE[0])
      { // Clear IRQ event flag
        NRF_TIMER1->EVENTS_COMPARE[0] = 0x0UL;
        volatile uint32_t dummy = NRF_TIMER1->EVENTS_COMPARE[0];
        (void)dummy;
    	// Give Notification
    	xTaskNotifyFromISR(hSomeTask);
    Max
    Thanks a lot for you answer
    i Have another question why do i need this part in the code :
    (void)dummy;
    Thanks you CheMax
