how to make pairing mandatory
Module: ilumi H52 BLE module (nRF52832)
SDK: nRF5_SDK_15.2.0_9412b96
Softdevice: 132_nrf52_6.1.0_softdevice.hex
Compiler: gcc version 7.3.1 20180622 (release) [ARM/embedded-7-branch revision 261907] (15:7-2018-q2-4)
I'm working with ble multiperipheral / app_UART (NUS) examples.
Since UART (NUS) example doesn't support pairing, I had to implement pairing manually.
Pairing works now. But central devices can still connect to the peripheral without pairing. Requirement is that only bonded devices are able to use the UART service. How can this be accomplished? How to force pairing / bonding for all connecting devices?
  • You should use Peer Manager module. After initialization it with pm_init()  set security params using pm_sec_params_set().
    After peripheral device is connected, call pm_conn_secure() to initiate bonding.
    You might want to check ble_app_hrs_c, where it's implemented.
  • Thank you for your message. But as I wrote, I'm working with the multiperipheral example. So I'm using a peripheral device, not a central device. All incoming connections from central devices should be forced to pair with the peripheral device.
  • You can initiate pm_conn_secure() in peripheral role as well like this:
    void onPeerManagerBlePeripheralEvent(ble_evt_t const* bleEvent) {
        switch (bleEvent->header.evt_id) {
            case BLE_GAP_EVT_CONNECTED: {
                pm_conn_secure(bleEvent->evt.gap_evt.conn_handle, false);
    Also keep in mind that NUS service in the SDK has open read and write characteristics (their read and write access is set to SEC_OPEN). If you want the characteristics to be secure, you might want to set mitm option in security params to 1. and also change NUS read and write characteristics security access like this:
    add_char_params.read_access  = SEC_MITM;
    add_char_params.write_access = SEC_MITM;
    This way only paired devices would be able to use your NUS characteristics
  • pm_conn_secure basically works in our peripheral device, provided the connecting central device is not already bonded.
    <info> app: Multiperipheral example started.
    <info> app: Client requested that all bonds be deleted
    <debug> nrf_ble_gatt: Requesting to update ATT MTU to 82 bytes on connection 0x0.
    <debug> nrf_ble_gatt: Updating data length to 83 on connection 0x0.
    <debug> nrf_ble_gatt: ATT MTU updated to 82 bytes on connection 0x0 (response).
    <info> app: Data len is set to 0x4F(79)
    <debug> app: ATT MTU exchange completed. central 0x52 peripheral 0x52
    <debug> nrf_ble_gatt: Data length updated to 83 on connection 0x0.
    <debug> nrf_ble_gatt: max_rx_octets: 83
    <debug> nrf_ble_gatt: max_tx_octets: 83
    <debug> nrf_ble_gatt: max_rx_time: 1096
    <debug> nrf_ble_gatt: max_tx_time: 1096
    <debug> app: BLE_GAP_EVT_SEC_PARAMS_REQUEST
    <info> peer_manager_handler: Connection secured: role: Peripheral, conn_handle: 0, procedure: Bonding
    <info> app: Connection with link 0x0 established.
    <info> app: BLE_GAP_EVT_AUTH_STATUS: status=0x0 bond=0x1 lv4: 0 kdist_own:0x3 kdist_peer:0x3
    If the central device disconnects and connects again, pm_conn_secure is executed again an an error occurs:
    <debug> nrf_ble_gatt: Requesting to update ATT MTU to 82 bytes on connection 0x1.
    <debug> nrf_ble_gatt: Updating data length to 83 on connection 0x1.
    <info> app: PM_EVT_BONDED_PEER_CONNECTED
    <error> app: ERROR 17 [NRF_ERROR_BUSY] at .//main.c:993
    PC at: 0x0002DC97
    <error> app: End of error report
    Line 993 in main.c is the result of APP_ERROR_CHECK after executing pm_conn_secure.
    My question: How can we check if the connecting device is already bonded before executing pm_conn_secure in case BLE_GAP_EVT_CONNECTED)?
    Usually it's not suggested to call pm_conn_secure() when you are a peripheral (Apple BLE guideline doesn't suggest this, same on Android). If you are a peripheral, usually you let the central device to trigger pairing and re-pairing.
    If you still want to trigger pairing from the peripheral side, you can add code to skip calling pm_conn_secure() if PM_EVT_BONDED_PEER_CONNECTED is received.
