A question about the UUID & Characteristic ID
HI Sir:
 I have meet a strange question using the BLE_UART example.
The code as following:
static ble_uuid_t                       vive_adv_uuids[] = {{BLE_UUID_NUS_SERVICE, BLE_UUID_TYPE_BLE}};  /**< Universally unique service identifier. */
and the advertising_init as following:
  uint32_t   err_code;
  ble_advdata_t advdata;
  ble_advdata_manuf_data_t manuf_specific_data;
  manuf_specific_data.company_identifier = 0;
  manuf_specific_data.data.p_data = (uint8_t *) sn_number;
     manuf_specific_data.data.size   = 8;
  memset(&advdata, 0, sizeof(advdata));
  advdata.name_type     = BLE_ADVDATA_FULL_NAME;
  advdata.include_appearance = false;
  advdata.flags      = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE;
  advdata.uuids_complete.uuid_cnt = sizeof(vive_adv_uuids) / sizeof(vive_adv_uuids[0]);
      advdata.uuids_complete.p_uuids  = vive_adv_uuids;
  advdata.p_manuf_specific_data=&manuf_specific_data;
  ble_adv_modes_config_t options = {0};
  options.ble_adv_fast_enabled  = BLE_ADV_FAST_ENABLED;
  options.ble_adv_fast_interval = APP_ADV_INTERVAL;
  options.ble_adv_fast_timeout  = APP_ADV_TIMEOUT_IN_SECONDS;
  err_code = ble_advertising_init(&advdata, NULL, &options, on_adv_evt, NULL);
And modified the service_init as following :
uint32_t ble_nus_init(ble_nus_t * p_nus, const ble_nus_init_t * p_nus_init)
  uint32_t   err_code;
  ble_uuid_t   ble_uuid;
  VERIFY_PARAM_NOT_NULL(p_nus);
  VERIFY_PARAM_NOT_NULL(p_nus_init);
  // Initialize the service structure.
  p_nus->conn_handle      = BLE_CONN_HANDLE_INVALID;
  p_nus->data_handler      = p_nus_init->data_handler;
  p_nus->is_notification_enabled = false;
  // Add the service.
  BLE_UUID_BLE_ASSIGN(ble_uuid, BLE_UUID_NUS_SERVICE);
      err_code = sd_ble_gatts_service_add(BLE_GATTS_SRVC_TYPE_PRIMARY,&ble_uuid,&p_nus->service_handle);
  if (err_code != NRF_SUCCESS)
          return err_code;
  // Add the RX Characteristic.
  err_code = rx_char_add(p_nus, p_nus_init);
  VERIFY_SUCCESS(err_code);
  // Add the TX Characteristic.
  err_code = tx_char_add(p_nus, p_nus_init);
  return NRF_SUCCESS;
and the TX & RX added function as following :
static uint32_t rx_char_add(ble_nus_t * p_nus, const ble_nus_init_t * p_nus_init)
 /**@snippet [Adding proprietary characteristic to S110 SoftDevice] */
  ble_gatts_char_md_t char_md;
  ble_gatts_attr_md_t cccd_md;
  ble_gatts_attr_t attr_char_value;
  ble_gatts_attr_md_t attr_md;
  memset(&cccd_md, 0, sizeof(cccd_md));
  BLE_GAP_CONN_SEC_MODE_SET_OPEN(&cccd_md.read_perm);
  BLE_GAP_CONN_SEC_MODE_SET_OPEN(&cccd_md.write_perm);
  cccd_md.vloc = BLE_GATTS_VLOC_STACK;
  memset(&char_md, 0, sizeof(char_md));
  char_md.char_props.notify = 1;
  char_md.p_char_user_desc  = NULL;
  char_md.p_char_pf    = NULL;
  char_md.p_user_desc_md   = NULL;
  char_md.p_cccd_md    = &cccd_md;
  char_md.p_sccd_md    = NULL;
  BLE_UUID_BLE_ASSIGN(ble_uuid, BLE_UUID_NUS_RX_CHARACTERISTIC);
  memset(&attr_md, 0, sizeof(attr_md));
  BLE_GAP_CONN_SEC_MODE_SET_OPEN(&attr_md.read_perm);
  BLE_GAP_CONN_SEC_MODE_SET_OPEN(&attr_md.write_perm);
  attr_md.vloc     = BLE_GATTS_VLOC_STACK;
  attr_md.rd_auth     = 0;
  attr_md.wr_auth     = 0;
  attr_md.vlen     = 1;
  memset(&attr_char_value, 0, sizeof(attr_char_value));
  attr_char_value.p_uuid   = &ble_uuid;
  attr_char_value.p_attr_md = &attr_md;
  attr_char_value.init_len  = sizeof(uint8_t);
  attr_char_value.init_offs = 0;
  attr_char_value.max_len   = BLE_NUS_MAX_RX_CHAR_LEN;
  return sd_ble_gatts_characteristic_add(p_nus->service_handle,&char_md,&attr_char_value,&p_nus->rx_handles);
static uint32_t tx_char_add(ble_nus_t * p_nus, const ble_nus_init_t * p_nus_init)
   char_md.char_props.write     = 1;
   char_md.char_props.write_wo_resp   = 1;
   char_md.p_cccd_md       = NULL;
   BLE_UUID_BLE_ASSIGN(ble_uuid, BLE_UUID_NUS_TX_CHARACTERISTIC);
   attr_md.vlen        = 1;
   attr_char_value.init_len     = 1;
   attr_char_value.max_len     = BLE_NUS_MAX_TX_CHAR_LEN;
   return sd_ble_gatts_characteristic_add(p_nus->service_handle,&char_md,&attr_char_value,&p_nus->tx_handles);
The question is very strange ,we using nrfconnect app on iphone and android mobile (MI Note3) to scan the device:
1.The UUID is the same in two mobile phone(using the nrfconnect to test)
 iphone will display 0xFFF0,and android will display the uuid is :
0x0000FFF0-0000-1000-8000-00805F9B34FB.
2.And the RX & TX Characteristic
There is a very strange, the iphone will display the TX &RX Characteristic ID:
 {{0x9E, 0xCA, 0xDC, 0x24, 0x0E, 0xE5, 0xA9, 0xE0, 0x93, 0xF3, 0xA3, 0xB5, 0xF6, 0xFF, 0x40, 0x6E}}
But the Android phone display the RX &TX Characteristic ID As following :
0x0000FFF6-0000-1000-8000-00805F9B34FB.
Why ,How can i modify it ?
And how to do to realize only 16bits Id will be dislplay?
  • HI Lee,
    Which SDK version are you using? SDK v12.3.0?
    The Nordic UART Service(NUS) is a Vendor Specific Bluetooth Service, not a Bluetooth SIG Service. So you need to make the following changes:
    1. Setting the UUIDs to advertise
    must be changed to
    static ble_uuid_t vive_adv_uuids[] = {{BLE_UUID_NUS_SERVICE, BLE_UUID_TYPE_VENDOR_BEGIN}}; /**< Universally unique service identifier. */
    2. Adding the Vendor Specific UUID
    // Add the service.
        return err_code;
    must be changed to the following
    ble_uuid128_t         nus_base_uuid = NUS_BASE_UUID;
    /**@snippet [Adding proprietary Service to the SoftDevice] */
    // Add a custom base UUID.
    err_code = sd_ble_uuid_vs_add(&nus_base_uuid, &p_nus->uuid_type);
    ble_uuid.type = p_nus->uuid_type;
    ble_uuid.uuid = BLE_UUID_NUS_SERVICE;
    // Add the service.
                                        &ble_uuid,
    3. Set the correct UUID type when adding the RX and TX characteristics
    The following macros,
    must be replaced with
    ble_uuid.uuid = BLE_UUID_NUS_TX_CHARACTERISTIC;
    ble_uuid.uuid = BLE_UUID_NUS_RX_CHARACTERISTIC;
    as shown in the snippet below
    /**@brief Function for adding RX characteristic.
     * @param[in] p_nus       Nordic UART Service structure.
     * @param[in] p_nus_init  Information needed to initialize the service.
     * @return NRF_SUCCESS on success, otherwise an error code.
        attr_md.vlen    = 1;
                                               &char_md,
                                               &attr_char_value,
    /**@brief Function for adding TX characteristic.
        attr_md.vlen    = 1;
                                               &char_md,
                                               &attr_char_value,
    Best regards
    Bjørn
