ble_active_scanner Devzone example won't build
Hi all, I recently downloaded a custom built example project for Segger that simply scans for nearby Bluetooth devices and dumps the info to UART. However, even after putting the file into the SDK 15.2 examples section, the project fails to build as a number of the header files included simply aren't recognized. I attempted to remove and replace each of the specified files with no luck.
 * Copyright (c) 2016 - 2018, Nordic Semiconductor ASA
 * All rights reserved.
#include <stdio.h>
#include <stdint.h>
#include <stdbool.h>
#include "nordic_common.h"
#include "app_error.h"
#include "app_uart.h"
#include "ble_db_discovery.h"
#include "app_timer.h"
#include "app_util.h"
#include "bsp_btn_ble.h"
#include "ble.h"
#include "ble_gap.h"
#include "ble_hci.h"
#include "nrf_sdh.h"
#include "nrf_sdh_ble.h"
#include "nrf_sdh_soc.h"
#include "ble_advdata.h"
#include "nrf_ble_scan.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#define APP_BLE_CONN_CFG_TAG        1                                   /**< Tag that refers to the BLE stack configuration set with @ref sd_ble_cfg_set. The default tag is @ref BLE_CONN_CFG_TAG_DEFAULT. */
#define APP_BLE_OBSERVER_PRIO       3                                   /**< BLE observer priority of the application. There is no need to modify this value. */
#define SCAN_INTERVAL               0x00A0                              /**< Determines scan interval in units of 0.625 millisecond. */
#define SCAN_WINDOW                 0x0050                              /**< Determines scan window in units of 0.625 millisecond. */
#define SCAN_DURATION               0x0000                              /**< Duration of the scanning in units of 10 milliseconds. If set to 0x0000, scanning will continue until it is explicitly disabled. */
static ble_gap_scan_params_t m_scan_param;                                /**< Scan parameters requested for scanning and connection. */
static uint8_t               m_scan_buffer_data[BLE_GAP_SCAN_BUFFER_MIN]; /**< buffer where advertising reports will be stored by the SoftDevice. */
/**@brief Pointer to the buffer where advertising reports will be stored by the SoftDevice. */
static ble_data_t m_scan_buffer =
    m_scan_buffer_data,
/**@brief Function for handling asserts in the SoftDevice.
 * @details This function is called in case of an assert in the SoftDevice.
 * @warning This handler is only an example and is not meant for the final product. You need to analyze
 *          how your product is supposed to react in case of assert.
 * @param[in] line_num     Line number of the failing assert call.
 * @param[in] p_file_name  File name of the failing assert call.
    app_error_handler(0xDEADBEEF, line_num, p_file_name);
    ret_code_t            err_code;
    ble_gap_evt_adv_report_t const * p_adv_report = &p_ble_evt->evt.gap_evt.params.adv_report;
        case BLE_GAP_EVT_ADV_REPORT:
            if (p_adv_report->type.scan_response)
                if (p_adv_report->data.len > 0)
                    NRF_LOG_INFO("Scan response received:");
                    NRF_LOG_RAW_HEXDUMP_INFO(p_adv_report->data.p_data, p_adv_report->data.len);
                    NRF_LOG_INFO("Empty scan response received.");
                NRF_LOG_INFO("Advertising packet received:");
            // Continue scanning.
            sd_ble_gap_scan_start(NULL, &m_scan_buffer);
    uint32_t ram_start = 0;
    // Enable BLE stack.
/**@brief Function for initializing the nrf log module. */
static void log_init(void)
/**@brief Function to start scanning. */
static void scan_start(void)
    ret_code_t ret;
    m_scan_param.active         = 1;
    m_scan_param.interval       = SCAN_INTERVAL;
    m_scan_param.window         = SCAN_WINDOW;
    m_scan_param.timeout        = SCAN_DURATION;
    m_scan_param.scan_phys      = BLE_GAP_PHY_1MBPS;
    m_scan_param.filter_policy  = BLE_GAP_SCAN_FP_ACCEPT_ALL;
    ret = sd_ble_gap_scan_start(&m_scan_param, &m_scan_buffer);
    APP_ERROR_CHECK(ret);
    ret_code_t ret;
    // Initialize.
    log_init();
    ble_stack_init();
    // Start scanning.
    NRF_LOG_INFO("BLE active scanner started.");
    scan_start();
    // Enter main loop.
    for (;;)
        NRF_LOG_PROCESS();
sdk_config.h
The main problem appears to be that the project is looking for a folder that doesn't exist : libraries\experimental_log\src. I tried creating that folder and copying all of the necessary files into it but Segger still won't recognize them. Any ideas?
