ble_active_scanner Devzone example won't build
Hi all, I recently downloaded a custom built example project for Segger that simply scans for nearby Bluetooth devices and dumps the info to UART. However, even after putting the file into the SDK 15.2 examples section, the project fails to build as a number of the header files included simply aren't recognized. I attempted to remove and replace each of the specified files with no luck.
 * Copyright (c) 2016 - 2018, Nordic Semiconductor ASA
 * All rights reserved.
#include <stdio.h>
#include <stdint.h>
#include <stdbool.h>
#include "nordic_common.h"
#include "app_error.h"
#include "app_uart.h"
#include "ble_db_discovery.h"
#include "app_timer.h"
#include "app_util.h"
#include "bsp_btn_ble.h"
#include "ble.h"
#include "ble_gap.h"
#include "ble_hci.h"
#include "nrf_sdh.h"
#include "nrf_sdh_ble.h"
#include "nrf_sdh_soc.h"
#include "ble_advdata.h"
#include "nrf_ble_scan.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#define APP_BLE_CONN_CFG_TAG        1                                   /**< Tag that refers to the BLE stack configuration set with @ref sd_ble_cfg_set. The default tag is @ref BLE_CONN_CFG_TAG_DEFAULT. */
#define APP_BLE_OBSERVER_PRIO       3                                   /**< BLE observer priority of the application. There is no need to modify this value. */
#define SCAN_INTERVAL               0x00A0                              /**< Determines scan interval in units of 0.625 millisecond. */
#define SCAN_WINDOW                 0x0050                              /**< Determines scan window in units of 0.625 millisecond. */
#define SCAN_DURATION               0x0000                              /**< Duration of the scanning in units of 10 milliseconds. If set to 0x0000, scanning will continue until it is explicitly disabled. */
static ble_gap_scan_params_t m_scan_param;                                /**< Scan parameters requested for scanning and connection. */
static uint8_t               m_scan_buffer_data[BLE_GAP_SCAN_BUFFER_MIN]; /**< buffer where advertising reports will be stored by the SoftDevice. */
/**@brief Pointer to the buffer where advertising reports will be stored by the SoftDevice. */
static ble_data_t m_scan_buffer =
    m_scan_buffer_data,
/**@brief Function for handling asserts in the SoftDevice.
 * @details This function is called in case of an assert in the SoftDevice.
 * @warning This handler is only an example and is not meant for the final product. You need to analyze
 *          how your product is supposed to react in case of assert.
 * @param[in] line_num     Line number of the failing assert call.
 * @param[in] p_file_name  File name of the failing assert call.
    app_error_handler(0xDEADBEEF, line_num, p_file_name);
    ret_code_t            err_code;
    ble_gap_evt_adv_report_t const * p_adv_report = &p_ble_evt->evt.gap_evt.params.adv_report;
        case BLE_GAP_EVT_ADV_REPORT:
            if (p_adv_report->type.scan_response)
                if (p_adv_report->data.len > 0)
                    NRF_LOG_INFO("Scan response received:");
                    NRF_LOG_RAW_HEXDUMP_INFO(p_adv_report->data.p_data, p_adv_report->data.len);
                    NRF_LOG_INFO("Empty scan response received.");
                NRF_LOG_INFO("Advertising packet received:");
            // Continue scanning.
            sd_ble_gap_scan_start(NULL, &m_scan_buffer);
    uint32_t ram_start = 0;
    // Enable BLE stack.
/**@brief Function for initializing the nrf log module. */
static void log_init(void)
/**@brief Function to start scanning. */
static void scan_start(void)
    ret_code_t ret;
    m_scan_param.active         = 1;
    m_scan_param.interval       = SCAN_INTERVAL;
    m_scan_param.window         = SCAN_WINDOW;
    m_scan_param.timeout        = SCAN_DURATION;
    m_scan_param.scan_phys      = BLE_GAP_PHY_1MBPS;
    m_scan_param.filter_policy  = BLE_GAP_SCAN_FP_ACCEPT_ALL;
    ret = sd_ble_gap_scan_start(&m_scan_param, &m_scan_buffer);
    APP_ERROR_CHECK(ret);
    ret_code_t ret;
    // Initialize.
    log_init();
    ble_stack_init();
    // Start scanning.
    NRF_LOG_INFO("BLE active scanner started.");
    scan_start();
    // Enter main loop.
    for (;;)
        NRF_LOG_PROCESS();
sdk_config.h
The main problem appears to be that the project is looking for a folder that doesn't exist : libraries\experimental_log\src. I tried creating that folder and copying all of the necessary files into it but Segger still won't recognize them. Any ideas?
  • So, I've had a little more success. I copied the main.c file over into one of the default 15.2 examples and added full paths to the few header files it couldn't recognize and got it to work. However, now I want to add filters to the scanner so that I can look for a specific device, which requires a scanning module instance. I tried adding "nrf_ble_scan.h", but when it tries to build I get this error:
    I'm not quite sure what to make of it. Oh, and if this should be a separate post just let me know.
  • Hi.
    Where did you download this project?
     The experimental_log library is not found in SDK 15.2, you can find it in SDK versions before 15.2, for example SDK 15.0.
    Andreas
  • Thanks, Andreas. I actually downloaded it off of the Devzone here. It was an older post but the Dev made two versions, and the second was for 15.2. However, I managed to get around that error by including the proper paths to the files. It's the second error that really has me confused.
  • Hi.
    I've looked at your sdk_config.h file, and the reason you get the error "NRF_BLE_SCAN_BUFFER undeclared here", is because it is not defined in your sdk_config.h file.
    If you take a look at for example the examples\ble_central\ble_app_blinky_c folder, and its sdk_config.h file:
    // <e> NRF_BLE_SCAN_ENABLED - nrf_ble_scan - Scanning Module
    #ifndef NRF_BLE_SCAN_ENABLED
    #define NRF_BLE_SCAN_ENABLED 1
    // <o> NRF_BLE_SCAN_BUFFER - Data length for an advertising set.
    #ifndef NRF_BLE_SCAN_BUFFER
    #define NRF_BLE_SCAN_BUFFER 31
    // <o> NRF_BLE_SCAN_NAME_MAX_LEN - Maximum size for the name to search in the advertisement report.
    #ifndef NRF_BLE_SCAN_NAME_MAX_LEN
    #define NRF_BLE_SCAN_NAME_MAX_LEN 32
    // <o> NRF_BLE_SCAN_SHORT_NAME_MAX_LEN - Maximum size of the short name to search for in the advertisement report.
    #ifndef NRF_BLE_SCAN_SHORT_NAME_MAX_LEN
    #define NRF_BLE_SCAN_SHORT_NAME_MAX_LEN 32
    // <o> NRF_BLE_SCAN_SCAN_INTERVAL - Scanning interval. Determines the scan interval in units of 0.625 millisecond.
    #ifndef NRF_BLE_SCAN_SCAN_INTERVAL
    #define NRF_BLE_SCAN_SCAN_INTERVAL 160
    // <o> NRF_BLE_SCAN_SCAN_DURATION - Duration of a scanning session in units of 10 ms. Range: 0x0001 - 0xFFFF (10 ms to 10.9225 ms). If set to 0x0000, the scanning continues until it is explicitly disabled.
    #ifndef NRF_BLE_SCAN_SCAN_DURATION
    #define NRF_BLE_SCAN_SCAN_DURATION 0
    // <o> NRF_BLE_SCAN_SCAN_WINDOW - Scanning window. Determines the scanning window in units of 0.625 millisecond.
    #ifndef NRF_BLE_SCAN_SCAN_WINDOW
    #define NRF_BLE_SCAN_SCAN_WINDOW 80
    // <o> NRF_BLE_SCAN_MIN_CONNECTION_INTERVAL - Determines minimum connection interval in milliseconds.
    #ifndef NRF_BLE_SCAN_MIN_CONNECTION_INTERVAL
    #define NRF_BLE_SCAN_MIN_CONNECTION_INTERVAL 7.5
    // <o> NRF_BLE_SCAN_MAX_CONNECTION_INTERVAL - Determines maximum connection interval in milliseconds.
    #ifndef NRF_BLE_SCAN_MAX_CONNECTION_INTERVAL
    #define NRF_BLE_SCAN_MAX_CONNECTION_INTERVAL 30
    // <o> NRF_BLE_SCAN_SLAVE_LATENCY - Determines the slave latency in counts of connection events.
    #ifndef NRF_BLE_SCAN_SLAVE_LATENCY
    #define NRF_BLE_SCAN_SLAVE_LATENCY 0
    // <o> NRF_BLE_SCAN_SUPERVISION_TIMEOUT - Determines the supervision time-out in units of 10 millisecond.
    #ifndef NRF_BLE_SCAN_SUPERVISION_TIMEOUT
    #define NRF_BLE_SCAN_SUPERVISION_TIMEOUT 4000
    // <o> NRF_BLE_SCAN_SCAN_PHY  - PHY to scan on.
    // <0=> BLE_GAP_PHY_AUTO
    // <1=> BLE_GAP_PHY_1MBPS
    // <2=> BLE_GAP_PHY_2MBPS
    // <4=> BLE_GAP_PHY_CODED
    // <255=> BLE_GAP_PHY_NOT_SET
    #ifndef NRF_BLE_SCAN_SCAN_PHY
    #define NRF_BLE_SCAN_SCAN_PHY 1
    // <e> NRF_BLE_SCAN_FILTER_ENABLE - Enabling filters for the Scanning Module.
    #ifndef NRF_BLE_SCAN_FILTER_ENABLE
    #define NRF_BLE_SCAN_FILTER_ENABLE 1
    // <o> NRF_BLE_SCAN_UUID_CNT - Number of filters for UUIDs.
    #ifndef NRF_BLE_SCAN_UUID_CNT
    #define NRF_BLE_SCAN_UUID_CNT 0
    // <o> NRF_BLE_SCAN_NAME_CNT - Number of name filters.
    #ifndef NRF_BLE_SCAN_NAME_CNT
    #define NRF_BLE_SCAN_NAME_CNT 1
    // <o> NRF_BLE_SCAN_SHORT_NAME_CNT - Number of short name filters.
    #ifndef NRF_BLE_SCAN_SHORT_NAME_CNT
    #define NRF_BLE_SCAN_SHORT_NAME_CNT 0
    // <o> NRF_BLE_SCAN_ADDRESS_CNT - Number of address filters.
    #ifndef NRF_BLE_SCAN_ADDRESS_CNT
    #define NRF_BLE_SCAN_ADDRESS_CNT 0
    // <o> NRF_BLE_SCAN_APPEARANCE_CNT - Number of appearance filters.
    #ifndef NRF_BLE_SCAN_APPEARANCE_CNT
    #define NRF_BLE_SCAN_APPEARANCE_CNT 0
    // </e>
    // </e>
    There are several defines needed for a central.
    Andreas
  • Thanks, Andreas. I went ahead and moved that section of code into my sdk_config.h. However, I now get an even more confusing error.
    I'm not familiar with object files all that much unfortunately.
