Mesh SDK v3.1.0 with Buttonless DFU example.
Hi guys, hope all is well. I was hoping someone could help me out with this particular issue. Maybe someone on here has tried to do the same thing.
Just some background about my test setup:
  • Using 2x nRF52840's, custom hardware.
  • One is the client, the other is the server (running the Light Switch example from Mesh SDK v3.1.0)
  • Using SDK v15.2, and my code is based off the examples in there.
  • Using s140 v6.1.0.
I am trying to use the Buttonless DFU example with my code (both light switch server and client), and have had limited success. When performing a DFU via the Buttonless DFU service, all works well and as expected.
My Issue arises when I try and provision a node. It looks like during the provisioning process, the code gets to this point (in mesh_provisionee.c):
static void sd_state_evt_handler(nrf_sdh_state_evt_t state, void * p_context)
    (void) p_context;
    if (!m_doing_gatt_reset)
        return;
    switch (state)
        case NRF_SDH_EVT_STATE_DISABLED: /* Gets to this handler */
            uint32_t err_code = nrf_sdh_enable_request();
But in the buttonless dfu code, there is the same handler:
static void buttonless_dfu_sdh_state_observer(nrf_sdh_state_evt_t state, void * p_context)
    if (state == NRF_SDH_EVT_STATE_DISABLED)
        // Softdevice was disabled before going into reset. Inform bootloader to skip CRC on next boot.
        nrf_power_gpregret2_set(BOOTLOADER_DFU_SKIP_CRC);
        //Go to system off.
        nrf_pwr_mgmt_shutdown(NRF_PWR_MGMT_SHUTDOWN_GOTO_SYSOFF);
I have run the debugger, and it looks like this code gets executed as well, which powers down the device.  This appears to be the root cause of the problem. I have tried to get around it by doing the following:
        if(MeshServer_ProvisioningStarted()|| MeshClient_ProvisioningStarted())
            bDeviceProvisioning = true;
            bDeviceProvisioning = false;
        __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "[DEBUG] bDeviceProvisioning = %d\n", (int)bDeviceProvisioning);
        if(!bDeviceProvisioning){
            //Go to system off.
I check when the device is provisioning, and when it is - I block out this bit of code. It is a bit dirty, and I was wondering if there was a nicer way of doing it. I am aware that there exists built in DFU facilities in the mesh stack. Could I maybe use the Mesh DFU like you would use the Buttonless DFU, ie with a bootloader?
Gord
