if i disconnect slave a, slave b will auto disconnect also, and later slave b connect again.
dear
i am using this project as slave
\nRF5_SDK_14.2.0_17b948a\examples\ble_peripheral\ble_app_uart\
this project as central
\nRF5_SDK_14.2.0_17b948a\examples\ble_central\ble_app_uart_c\
i have two slave connected with the center.
i find a problem,
i doubt this maybe the softdevice's scheme ?
why is it designed like this ?
i think although slave a is disconnected, slave b should not be affected .....
  • Hi Lyman,
    As far as I know the ble_app_uart_c only connect to one board at a time. Did you modify the code to connect to multiple server ?
    Have you made sure you used the correct conn_handle when dealing with multiple servers/slaves ?
    How did you disconnect slave a ?
  • i define  more instance
    BLE_NUS_C_DEF(m_ble_nus_c); /**< BLE NUS service client instance. */
    BLE_NUS_C_DEF(m_ble_nus_c1);
    BLE_NUS_C_DEF(m_ble_nus_c2);
    BLE_NUS_C_DEF(m_ble_nus_c3);
    BLE_DB_DISCOVERY_DEF(m_db_disc);
    BLE_DB_DISCOVERY_DEF(m_db_disc1);
    BLE_DB_DISCOVERY_DEF(m_db_disc2);
    BLE_DB_DISCOVERY_DEF(m_db_disc3);
    in function static void ble_evt_handler(ble_evt_t const * p_ble_evt, void * p_context)
    i add the following code
    if(p_ble_evt->evt.gap_evt.conn_handle == 0)
    err_code = ble_nus_c_handles_assign(&m_ble_nus_c, p_ble_evt->evt.gap_evt.conn_handle, NULL);
    if(p_ble_evt->evt.gap_evt.conn_handle == 1)
    err_code = ble_nus_c_handles_assign(&m_ble_nus_c1, p_ble_evt->evt.gap_evt.conn_handle, NULL);
    if(p_ble_evt->evt.gap_evt.conn_handle == 2)
    err_code = ble_nus_c_handles_assign(&m_ble_nus_c2, p_ble_evt->evt.gap_evt.conn_handle, NULL);
    if(p_ble_evt->evt.gap_evt.conn_handle == 3)
    err_code = ble_nus_c_handles_assign(&m_ble_nus_c3, p_ble_evt->evt.gap_evt.conn_handle, NULL);
    err_code = ble_db_discovery_start(&m_db_disc, p_ble_evt->evt.gap_evt.conn_handle);
    err_code = ble_db_discovery_start(&m_db_disc1, p_ble_evt->evt.gap_evt.conn_handle);
    err_code = ble_db_discovery_start(&m_db_disc2, p_ble_evt->evt.gap_evt.conn_handle);
    err_code = ble_db_discovery_start(&m_db_disc3, p_ble_evt->evt.gap_evt.conn_handle);
    if (ble_conn_state_n_centrals() == NRF_SDH_BLE_CENTRAL_LINK_COUNT)
    scan_start();
    the config's following
    // <o> NRF_SDH_BLE_PERIPHERAL_LINK_COUNT - Maximum number of peripheral links.
    #ifndef NRF_SDH_BLE_PERIPHERAL_LINK_COUNT
    #define NRF_SDH_BLE_PERIPHERAL_LINK_COUNT 0
    // <o> NRF_SDH_BLE_CENTRAL_LINK_COUNT - Maximum number of central links.
    #ifndef NRF_SDH_BLE_CENTRAL_LINK_COUNT
    #define NRF_SDH_BLE_CENTRAL_LINK_COUNT 4
    // <o> NRF_SDH_BLE_TOTAL_LINK_COUNT - Maximum number of total concurrent connections using the default configuration.
    #ifndef NRF_SDH_BLE_TOTAL_LINK_COUNT
    #define NRF_SDH_BLE_TOTAL_LINK_COUNT 4
    // <o> NRF_SDH_BLE_GAP_EVENT_LENGTH - The time set aside for this connection on every connection interval in 1.25 ms units.
    #ifndef NRF_SDH_BLE_GAP_EVENT_LENGTH
    #define NRF_SDH_BLE_GAP_EVENT_LENGTH 3
    // <o> NRF_SDH_BLE_GATT_MAX_MTU_SIZE - Static maximum MTU size.
    #ifndef NRF_SDH_BLE_GATT_MAX_MTU_SIZE
    #define NRF_SDH_BLE_GATT_MAX_MTU_SIZE 247
    // <o> NRF_SDH_BLE_GATTS_ATTR_TAB_SIZE - Attribute Table size in bytes. The size must be a multiple of 4.
    #ifndef NRF_SDH_BLE_GATTS_ATTR_TAB_SIZE
    #define NRF_SDH_BLE_GATTS_ATTR_TAB_SIZE 1408
    // <o> NRF_SDH_BLE_VS_UUID_COUNT - The number of vendor-specific UUIDs.
    #ifndef NRF_SDH_BLE_VS_UUID_COUNT
    #define NRF_SDH_BLE_VS_UUID_COUNT 1
    // <q> NRF_SDH_BLE_SERVICE_CHANGED - Include the Service Changed characteristic in the Attribute Table.
    #ifndef NRF_SDH_BLE_SERVICE_CHANGED
    #define NRF_SDH_BLE_SERVICE_CHANGED 0
  • Please answer the question regarding on how you disconnect the slave ?
    Please post the code where you handle BLE_GAP_EVT_DISCONNECTED.
    I assume you have 4 different m_conn_handle ?
    On slave B, which disconnect reason do you get ?
    A sniffer trace on slave B connection could be useful to see why it get disconnected.
