nRF52832 Product Specification V1.4, page 344 lists predefined baud rates only.
Is it possible to use other values for custom baud rate, and if so, what is the relationship between the Value and the actual generated baud rate?
Such a good question, and highlights the fun the hardware design engineer must have been having that day .. this is what I use, inclusive of the rounding
// Baud rate calculation on nRF51 and nRF52832 // =========================================== // // Calculate BAUDRATE value settings for the black-magic 20-bit baud rate generator uint32_t CalculatedRegisterValue; uint64_t SystemClock = 16000000ULL; // Typically 16MHz uint64_t MagicScaler = 32; // Preserves bits on divisions, shift 32 bits // Baudrate generator for the UART is the top 20 bits of a 32-bit field; add in rounding 0.5 ls bit CalculatedRegisterValue = (uint32_t)((((uint64_t)RequiredBaudRate << MagicScaler) / SystemClock) + 0x800) & 0xFFFFF000;
So does it work? Well it doesn't exactly match the datasheet quoted values:
typedef struct {
uint32_t QuotedRegisterValue;
uint32_t RequiredBaudRate;
uint32_t QuotedActualBaudRate;
} BaudCheck_t;
// Quoted values from nRF52832 v1.4 datasheet
static BaudCheck_t BaudCheck[] = {
{0x0004F000, 1200, 1205},
{0x0009D000, 2400, 2396},
{0x0013B000, 4800, 4808},
{0x00275000, 9600, 9598},
{0x003AF000, 14400, 14401},
{0x004EA000, 19200, 19208},
{0x0075C000, 28800, 28777},
{0x009D0000, 38400, 38369},
{0x00EB0000, 57600, 57554},
{0x013A9000, 76800, 76923},
{0x01D60000, 115200, 115108},
{0x03B00000, 230400, 231884},
{0x04000000, 250000, 250000},
{0x07400000, 460800, 457143},
{0x0F000000, 921600, 941176},
{0x10000000, 1000000, 1000000}};
#define NUM_BAUD_TESTS (sizeof(BaudCheck)/sizeof(BaudCheck[0]))
static void BaudRateDivisorTest(void)
uint32_t OkCountRegister = 0, FailCountRegister = 0, CalculatedRegisterValue;
uint32_t OkCountActualBaud = 0, FailCountActualBaud = 0;
uint32_t BaudIndex, ActualBaudRate;
for (BaudIndex = 0; BaudIndex < NUM_BAUD_TESTS; BaudIndex++)
CalculatedRegisterValue = (uint32_t)((((uint64_t)BaudCheck[BaudIndex].RequiredBaudRate << MagicScaler) / SystemClock) + 0x800) & 0xFFFFF000;
if ( BaudCheck[BaudIndex].QuotedRegisterValue == CalculatedRegisterValue)
OkCountRegister++;
FailCountRegister++;
ActualBaudRate = (uint32_t)(((uint64_t)CalculatedRegisterValue * SystemClock) >> MagicScaler);
if ( BaudCheck[BaudIndex].QuotedActualBaudRate == ActualBaudRate)
OkCountActualBaud++;
FailCountActualBaud++;
while(1) ;
The values either exactly match the data sheet or are close; that may be a code issue or a datasheet issue, who knows but I think the h/w guy was teasing us..
Thanks for the info. Very helpful!
You are welcome .. but in passing this has now become something of an issue as it turns out we have shipped product using incorrect values based on the manual; some of the differences are significant:
{0x0F000000, 921600, 941176, 0x0EBEE000, 921600, " -"}, // 14
All the quoted values are here:
#define RESULT_STRING_LENGTH 3 // "Yes" or " -"
typedef struct {
uint32_t CalculatedActualBaudRate;
char DoesRegisterMatch[RESULT_STRING_LENGTH];
} BaudCheck_t;
// -------Documentation--------- -------Calculated---------
// Register Required Actual Register Actual Ok? Index
{0x0004F000, 1200, 1205, 0x0004F000, 1205, " Ok"}, // 0
{0x0009D000, 2400, 2396, 0x0009D000, 2395, " Ok"}, // 1
{0x0013B000, 4800, 4808, 0x0013B000, 4806, " Ok"}, // 2
{0x00275000, 9600, 9598, 0x00275000, 9597, " Ok"}, // 3
{0x003AF000, 14400, 14401, 0x003B0000, 14404, " -"}, // 4
{0x004EA000, 19200, 19208, 0x004EA000, 19195, " Ok"}, // 5
{0x0075C000, 28800, 28777, 0x0075F000, 28793, " -"}, // 6
{0x009D0000, 38400, 38369, 0x009D5000, 38406, " -"}, // 7
{0x00EB0000, 57600, 57554, 0x00EBF000, 57601, " -"}, // 8
{0x013A9000, 76800, 76923, 0x013A9000, 76797, " Ok"}, // 9
{0x01D60000, 115200, 115108, 0x01D7E000, 115203, " -"}, // 10
{0x03B00000, 230400, 231884, 0x03AFB000, 230392, " -"}, // 11
{0x04000000, 250000, 250000, 0x04000000, 250000, " Ok"}, // 12
{0x07400000, 460800, 457143, 0x075F7000, 460800, " -"}, // 13
{0x10000000, 1000000, 1000000, 0x10000000, 1000000, " Ok"}}; // 15
I am hoping someone might critique this and reassure us that is not the case. This is the test code which backfills the table above:
BaudCheck[BaudIndex].CalculatedRegisterValue = CalculatedRegisterValue;
OkCountRegister++;
memcpy(BaudCheck[BaudIndex].DoesRegisterMatch, " Ok", RESULT_STRING_LENGTH);
BaudCheck[BaudIndex].CalculatedActualBaudRate = ActualBaudRate;
while(1) ;
I checked the nRF52840 Product Specification, and interestingly there have been some additions and corrections, but 10 of the 26 quoted values still seem incorrect, although now not by much. I'm also curious as to whether the baud rate generator is indeed only 20 bits, given that all 32 bits are writable .. I may test this if I get time.
// Quoted values from nRF52832 v1.4 datasheet - 16 correct, 10 incorrect
{0x10000000, 1000000, 1000000, 0x10000000, 1000000, " Ok"}, // 15
// Extra and changed values from nRF52840 Product Specification
{0x003B0000, 14400, 14414, 0x003B0000, 14404, " Ok"}, // 16
{0x0075F000, 28800, 28829, 0x0075F000, 28793, " Ok"}, // 17
{0x00800000, 31250, 31250, 0x00800000, 31250, " Ok"}, // 18
{0x009D5000, 38400, 38462, 0x003B0000, 38406, " Ok"}, // 19
{0x00E50000, 56000, 55944, 0x00E56000, 55999, " -"}, // 20
{0x00EBF000, 57600, 57762, 0x00EBF000, 57601, " Ok"}, // 21
{0x01D7E000, 115200, 115942, 0x01D7E000, 115203, " Ok"}, // 22
{0x03AFB000, 230400, 231884, 0x03AFB000, 230392, " Ok"}, // 23
{0x075F7000, 460800, 470588, 0x075F7000, 460800, " Ok"}, // 24
{0x0EBED000, 921600, 941176, 0x0EBEE000, 921600, " -"}}; // 25
I added rounding on the system clock, but that doesn't affect results:
// Baudrate generator for the UART is the top 20 bits of a 32-bit field; add in rounding 0.5 ls bit CalculatedRegisterValue = (uint32_t)(((((uint64_t)RequiredBaudRate << MagicScaler) + (SystemClock >> 1)) / SystemClock) + 0x800) & 0xFFFFF000;
nRF52832 (rev 2) NRF_UARTE0->BAUDRATE values and corresponding baud rates.
Bits 11-0 are not used.
nrf52832_uarte_baud_rates.txt
