Technical question regarding UART baud rate generator (BAUDRATE register, offset 0x524)
nRF52832 Product Specification V1.4, page 344 lists predefined baud rates only.
Is it possible to use other values for custom baud rate, and if so, what is the relationship between the Value and the actual generated baud rate?
  • Helpful feedback, and I verified 1.5MHz. Following on, it looks like the receiver is using a 9-sample mechanism for voting on each received bit. MSP430 uses 3 samples, older uarts use 16 samples. For 9 samples, at least 5 high samples are required for deciding a '1', ditto 5 or more low for a '0'.  16MHz / 9 => 1.777778 MHz. Setting this value as the baud rate gives zero errors in 256-byte packets (8N1). I'll run a test with (say) 4 k packet sizes, but this is good news.
  • I spent a while longer on this, and have some helpful information.
    First the single UART/E on the nRF52832 and both the UART/Es on the nRF52840 can be used in loopback mode (with or without DMA) with a single pin and no jumper wires; this is useful for testing, 1-wire applications and RS485. Second the max value for large packets seems to be 1,777,760 baud register 1C71'B000 which I verified by loopback testing of 2048-byte packets on the nRF52840 and 128-byte packets on the nRF52832 and checking for framing and other errors.
    This is the bare-metal code in case it is useful to others:
    static void SetupUART(const uint32_t BaudRate);
    static void StartUART_Transmit(const uint8_t * const pMsg, const uint16_t MsgLength);
    static void DisableUART(void);
    static uint16_t SetupUART_Receive(uint8_t * const pMsg, const uint16_t MaxMsgLength);
    static uint16_t WaitUART_Receive(void);
    static NRF_UARTE_Type *pUART = NRF_UARTE0;
    #define PIN_UART_TX         PIN_FEATHER_TXD
    #define PIN_UART_RX         PIN_FEATHER_RXD
    #define MAX_TX_PACKET_SIZE  2048 // 16-bit on nRF52840, only 8-bit on nRF52832
    static uint8_t TxMsg[MAX_TX_PACKET_SIZE] = "Baudrate generator for the UART is the top 20 bits of a 32-bit field; add in rounding 0.5 ls bit";
    #define TX_PACKET_SIZE sizeof(TxMsg)
    #define RX_PACKET_SIZE (TX_PACKET_SIZE - 1)
    static uint8_t RxMsg[RX_PACKET_SIZE] = "";
    uint32_t RequiredBaudRate = 1000000UL;
    uint32_t MaxOkdBaudRate = 0UL;
    uint32_t CalculatedRegisterValue;
    uint32_t RegisterValueAtMaxBaud = 0;
    uint64_t SystemClock = 16000000ULL;    // Typically 16MHz
    uint64_t MagicScaler = 32;             // Preserves bits on divisions, shift 32 bits
    void UART_BaudTest(void)
       // Enable crystal osc
       for (RequiredBaudRate = 1000000; RequiredBaudRate < 8000000; )
          //  Baudrate generator for the UART is the top 20 bits of a 32-bit field; add in rounding 0.5 ls bit
          CalculatedRegisterValue = (uint32_t)(((((uint64_t)RequiredBaudRate << MagicScaler) + (SystemClock >> 1)) / SystemClock) + 0x800) & 0xFFFFF000;
          // Setup UART from scratch for each baud rate test
          SetupUART(CalculatedRegisterValue);
          SetupUART_Receive(RxMsg, sizeof(RxMsg));
          StartUART_Transmit(TxMsg, TX_PACKET_SIZE);
          WaitUART_Receive();
          DisableUART();
          if ((memcmp(TxMsg, RxMsg, RX_PACKET_SIZE) == 0) && (pUART->EVENTS_ERROR == 0) && (pUART->ERRORSRC == 0x0000))
             MaxOkdBaudRate = RequiredBaudRate;
             RegisterValueAtMaxBaud = CalculatedRegisterValue;
          RequiredBaudRate += 20;
       while (1)
       // Disable the UARTE
       pUART->ENABLE = 0;
       // Configure UARTE with no flow control, no parity bit and selected baud rate
       pUART->CONFIG = 0;
       pUART->BAUDRATE = BaudRate;
       // Select TX and RX pin default disconnected mode to avoid sending break indication on disabling uart
       nrf_gpio_cfg(PIN_UART_RX, NRF_GPIO_PIN_DIR_INPUT,  NRF_GPIO_PIN_INPUT_CONNECT, NRF_GPIO_PIN_PULLUP, NRF_GPIO_PIN_S0S1, NRF_GPIO_PIN_NOSENSE);
       nrf_gpio_cfg(PIN_UART_TX, NRF_GPIO_PIN_DIR_OUTPUT, NRF_GPIO_PIN_INPUT_CONNECT, NRF_GPIO_PIN_PULLUP, NRF_GPIO_PIN_H0H1, NRF_GPIO_PIN_NOSENSE);
       // Select TX and RX pins; note for Loopback testing or 1-wire or RS485 a single pin can be used for both Rx and Tx
       pUART->PSEL.TXD = PIN_UART_TX;
       pUART->PSEL.RXD = PIN_UART_RX;  // For single pin loopback use PIN_UART_TX here
       // Disable all interrupts and clear events
       pUART->INTENCLR = 0xFFFFFFFFUL;
       pUART->EVENTS_TXSTARTED = 0;
       pUART->EVENTS_TXSTOPPED = 0;
       pUART->EVENTS_RXSTARTED = 0;
       pUART->EVENTS_ERROR = 0;
       pUART->ERRORSRC = 0x000F;    // Write '1's to clear any errors left set
       pUART->EVENTS_ENDTX = 0;
       pUART->EVENTS_ENDRX = 0;
       // Enable the UART, note 0x04 for UART and 0x08 for UARTE with DMA
       pUART->ENABLE = 0x08;
    STATIC_ASSERT (UARTE_ENABLE_ENABLE_Enabled == 0x08, "UARTE_ENABLE_ENABLE_Enabled == 0x08 Failed");
       // Configure transmit buffer and start the transfer
       pUART->TXD.MAXCNT = MsgLength;
       pUART->TXD.PTR    = (uint32_t)pMsg;
       pUART->TASKS_STARTTX = 1;
       __DSB();
       // Wait until the transfer start event is indicated
       while (pUART->EVENTS_TXSTARTED == 0) ;
       // Wait until the transfer is complete
       while (pUART->EVENTS_ENDTX == 0) ;
       // Stop the UART TX
       pUART->TASKS_STOPTX = 1;
       __DSB();
       // Wait until we receive the stopped event
       while (pUART->EVENTS_TXSTOPPED == 0) ;
       pUART->ENABLE = 0;
       // De-Select TX and RX pins
       pUART->PSEL.TXD = 0x80000000;
       pUART->PSEL.RXD = 0x80000000;
       volatile uint32_t Timeout;
       // Clear receive buffer
       memcpy(pMsg, "-----------------", MaxMsgLength);
       // Configure receive buffer and start reception
       pUART->RXD.MAXCNT = MaxMsgLength;
       pUART->RXD.PTR    = (uint32_t)pMsg;
       pUART->TASKS_STARTRX = 1;
       __DSB();
       while (pUART->EVENTS_RXSTARTED == 0) ;
       return 0;
       //while (pUART->EVENTS_ENDRX == 0) ; //add timeout here if using this during tests
       // just delay .. not actually required but helps with testing
       nrf_delay_ms(1);
       // Stop the UART RX
       pUART->TASKS_STOPRX = 1;
       __DSB();
       // Flush fifo
       //pUART->TASKS_FLUSHRX = 1;
       // Return packet when postLastRxByteTime indicates end-of-packet timeout
       return 0;
  • Good Job!  The mechanism for receiver to identify the first byte seems more complicated, need more efforts to understand it, we'll do more test in future.
  • Hello, may I ask how this corresponding table was calculated or from which document you obtained it? Thank you!
  • No document, I'm afraid, but here is the code I wrote to generate the table.
    #define RESULT_STRING_LENGTH 3   // "Yes" or "  -"
    typedef struct {
       uint32_t QuotedRegisterValue;
       uint32_t RequiredBaudRate;
       uint32_t QuotedActualBaudRate;
       uint32_t CalculatedActualBaudRate;
       char     DoesRegisterMatch[RESULT_STRING_LENGTH];
    } BaudCheck_t;
    // Quoted values from nRF52832 v1.4 datasheet - 16 correct, 10 incorrect
    static BaudCheck_t BaudCheck[] = {
    //  -------Documentation---------   -------Calculated---------
    //  Register    Required   Actual    Register    Actual    Ok?      Index
       {0x0004F000,     1200,    1205,  0x0004F000,    1205, " Ok"},  //  0
       {0x0009D000,     2400,    2396,  0x0009D000,    2395, " Ok"},  //  1
       {0x0013B000,     4800,    4808,  0x0013B000,    4806, " Ok"},  //  2
       {0x00275000,     9600,    9598,  0x00275000,    9597, " Ok"},  //  3
       {0x003AF000,    14400,   14401,  0x003B0000,   14404, "  -"},  //  4
       {0x004EA000,    19200,   19208,  0x004EA000,   19195, " Ok"},  //  5
       {0x0075C000,    28800,   28777,  0x0075F000,   28793, "  -"},  //  6
       {0x009D0000,    38400,   38369,  0x009D5000,   38406, "  -"},  //  7
       {0x00EB0000,    57600,   57554,  0x00EBF000,   57601, "  -"},  //  8
       {0x013A9000,    76800,   76923,  0x013A9000,   76797, " Ok"},  //  9
       {0x01D60000,   115200,  115108,  0x01D7E000,  115203, "  -"},  // 10
       {0x03B00000,   230400,  231884,  0x03AFB000,  230392, "  -"},  // 11
       {0x04000000,   250000,  250000,  0x04000000,  250000, " Ok"},  // 12
       {0x07400000,   460800,  457143,  0x075F7000,  460800, "  -"},  // 13
       {0x0F000000,   921600,  941176,  0x0EBEE000,  921600, "  -"},  // 14
       {0x10000000,  1000000, 1000000,  0x10000000, 1000000, " Ok"},  // 15
    // Extra and changed values from nRF52840 Product Specification
       {0x003B0000,    14400,   14414,  0x003B0000,   14404, " Ok"},  // 16
       {0x0075F000,    28800,   28829,  0x0075F000,   28793, " Ok"},  // 17
       {0x00800000,    31250,   31250,  0x00800000,   31250, " Ok"},  // 18
       {0x009D5000,    38400,   38462,  0x003B0000,   38406, " Ok"},  // 19
       {0x00E50000,    56000,   55944,  0x00E56000,   55999, "  -"},  // 20
       {0x00EBF000,    57600,   57762,  0x00EBF000,   57601, " Ok"},  // 21
       {0x01D7E000,   115200,  115942,  0x01D7E000,  115203, " Ok"},  // 22
       {0x03AFB000,   230400,  231884,  0x03AFB000,  230392, " Ok"},  // 23
       {0x075F7000,   460800,  470588,  0x075F7000,  460800, " Ok"},  // 24
       {0x0EBED000,   921600,  941176,  0x0EBEE000,  921600, "  -"}}; // 25
    #define NUM_BAUD_TESTS (sizeof(BaudCheck)/sizeof(BaudCheck[0]))
    static void BaudRateDivisorTest(void)
       // Baud rate calculation on nRF51 and nRF52832
       // Calculate BAUDRATE value settings for the black-magic 20-bit baud rate generator
       uint32_t OkCountRegister = 0, FailCountRegister = 0, CalculatedRegisterValue;
       uint32_t OkCountActualBaud = 0, FailCountActualBaud = 0;
       uint32_t BaudIndex, ActualBaudRate;
       for (BaudIndex = 0; BaudIndex < NUM_BAUD_TESTS; BaudIndex++)
          CalculatedRegisterValue = (uint32_t)(((((uint64_t)BaudCheck[BaudIndex].RequiredBaudRate << MagicScaler) + (SystemClock>>1)) / SystemClock) + 0x800) & 0xFFFFF000;
          BaudCheck[BaudIndex].CalculatedRegisterValue = CalculatedRegisterValue;
          if ( BaudCheck[BaudIndex].QuotedRegisterValue == CalculatedRegisterValue)
             OkCountRegister++;
             memcpy(BaudCheck[BaudIndex].DoesRegisterMatch, " Ok", RESULT_STRING_LENGTH);
             FailCountRegister++;
          ActualBaudRate = (uint32_t)(((uint64_t)CalculatedRegisterValue * SystemClock) >> MagicScaler);
          BaudCheck[BaudIndex].CalculatedActualBaudRate = ActualBaudRate;
          if ( BaudCheck[BaudIndex].QuotedActualBaudRate == ActualBaudRate)
             OkCountActualBaud++;
             FailCountActualBaud++;
       while(1) ;
    #define PIN_UART_TX         PIN_FEATHER_TXD // P0.25
    #define PIN_UART_RX         PIN_FEATHER_RXD // P0.24
    #define MAX_TX_PACKET_SIZE  128 //2048  nRF52832 8-bit, nRF52840 16-bit
       for (RequiredBaudRate = 1000000; RequiredBaudRate < 2000000; )
          SetupUART(CalculatedRegisterValue); // NRF_UART_BAUDRATE_230400);
          WaitUART_Receive();
          DisableUART();
             //break;
       while (1)
       pUART->ENABLE = 0;
       pUART->CONFIG = 0;
       // Select TX and RX pin default disconnected mode to avoid sending break indication on disabling uart ie NRF_GPIO_PIN_INPUT_DISCONNECT on Rx
       // Select TX and RX pins; not for Loopback testing or 1-wire or RS485 a single pin can be used for both Rx and Tx
       pUART->PSEL.RXD = PIN_UART_RX;  // For single pin loopback use PIN_UART_TX here, normal uart use PIN_UART_RX
       __DSB();
       while (pUART->EVENTS_ENDTX == 0) ; //add timeout here also add LEDs blinking during tests
       // Stop the UART TX
       __DSB();
       pUART->ENABLE = 0;
       __DSB();
       return 0;
       //while (pUART->EVENTS_ENDRX == 0) ; //add timeout here also add LEDs blinking during tests
       // or just delay ..
       nrf_delay_ms(1);
       // Stop the UART RX
       __DSB();
       return 0;
