(Mesh_v2.11, SDK_15.0.0, NRF52832)
I wonder if a device can relay DFU packets even though mesh_relay is disabled by nrf_mesh_opt_set(NRF_MESH_OPT_NET_RELAY_ENABLE, ~~)?
Thank you for your prompt answer in advance.
Charlie.
Charlie.
Hi Charlie.
Yes. As long as the node has DFU support it will relay DFU packets. It is not affected by "nrf_mesh_opt_set(NRF_MESH_OPT_NET_RELAY_ENABLE, ~~)".
The bootloader uses broadcast mesh.
I believe that there is a way to disable relaying, but I'm not sure how it's done. I can find out if you need to do it.
Joakim
