Wrong data in the receive buffer USB CDC
Hello!
I took the example of "usbd_cdc_acm" and added a receive and transmit buffer. The data from the receive buffer is sent back.
It turned out that the first byte is written to the end of the previous reception. How do I get the correct packet in the receive buffer?
I use nRF52840, SEGGER Embedded Studio for ARM Release 4.12 Build 2018112601.37855 Windows x64, nRF5_SDK_15.2.0,
debug board PCA10056 1.0.0. WINDOWS 10 x64.
Thank.
 * Copyright (c) 2017 - 2018, Nordic Semiconductor ASA
 * All rights reserved.
#include <stdint.h>
#include <stdbool.h>
#include <stddef.h>
#include <stdio.h>
#include "nrf.h"
#include "nrf_drv_usbd.h"
#include "nrf_drv_clock.h"
#include "nrf_gpio.h"
#include "nrf_delay.h"
#include "nrf_drv_power.h"
#include "app_error.h"
#include "app_util.h"
#include "app_usbd_core.h"
#include "app_usbd.h"
#include "app_usbd_string_desc.h"
#include "app_usbd_cdc_acm.h"
#include "app_usbd_serial_num.h"
#include "boards.h"
#include "bsp.h"
#include "bsp_cli.h"
#include "nrf_cli.h"
#include "nrf_cli_uart.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
 * @brief CLI interface over UART
NRF_CLI_UART_DEF(m_cli_uart_transport, 0, 64, 16);
NRF_CLI_DEF(m_cli_uart,
            "uart_cli:~$ ",
            &m_cli_uart_transport.transport,
            '\r',
            4);
/**@file
 * @defgroup usbd_cdc_acm_example main.c
 * @ingroup usbd_cdc_acm_example
 * @brief USBD CDC ACM example
#define LED_USB_RESUME      (BSP_BOARD_LED_0)
#define LED_CDC_ACM_OPEN    (BSP_BOARD_LED_1)
#define LED_CDC_ACM_RX      (BSP_BOARD_LED_2)
#define LED_CDC_ACM_TX      (BSP_BOARD_LED_3)
#define BTN_CDC_DATA_SEND       0
#define BTN_CDC_NOTIFY_SEND     1
#define BTN_CDC_DATA_KEY_RELEASE        (bsp_event_t)(BSP_EVENT_KEY_LAST + 1)
 * @brief Enable power USB detection
 * Configure if example supports USB port connection
#ifndef USBD_POWER_DETECTION
#define USBD_POWER_DETECTION true
static void cdc_acm_user_ev_handler(app_usbd_class_inst_t const * p_inst,
                                    app_usbd_cdc_acm_user_event_t event);
#define CDC_ACM_COMM_INTERFACE  0
#define CDC_ACM_COMM_EPIN       NRF_DRV_USBD_EPIN2
#define CDC_ACM_DATA_INTERFACE  1
#define CDC_ACM_DATA_EPIN       NRF_DRV_USBD_EPIN1
#define CDC_ACM_DATA_EPOUT      NRF_DRV_USBD_EPOUT1
 * @brief CDC_ACM class instance
APP_USBD_CDC_ACM_GLOBAL_DEF(m_app_cdc_acm,
                            cdc_acm_user_ev_handler,
                            CDC_ACM_COMM_INTERFACE,
                            CDC_ACM_DATA_INTERFACE,
                            CDC_ACM_COMM_EPIN,
                            CDC_ACM_DATA_EPIN,
                            CDC_ACM_DATA_EPOUT,
                            APP_USBD_CDC_COMM_PROTOCOL_AT_V250
#define READ_SIZE 1
static char m_rx_buffer[READ_SIZE];
static char m_tx_buffer[NRF_DRV_USBD_EPSIZE];
static bool m_send_flag = 0;
static uint8_t usb_rx_buffer[256];
volatile uint8_t usb_rx_length = 0;
static uint8_t usb_tx_buffer[256];
volatile uint8_t usb_tx_length = 0;
 * @brief User event handler @ref app_usbd_cdc_acm_user_ev_handler_t (headphones)
    app_usbd_cdc_acm_t const * p_cdc_acm = app_usbd_cdc_acm_class_get(p_inst);
    switch (event)
        case APP_USBD_CDC_ACM_USER_EVT_PORT_OPEN:
            bsp_board_led_on(LED_CDC_ACM_OPEN);
            /*Setup first transfer*/
            ret_code_t ret = app_usbd_cdc_acm_read(&m_app_cdc_acm,
                                                   usb_rx_buffer,
                                                   READ_SIZE);
//            ret_code_t ret = app_usbd_cdc_acm_read(&m_app_cdc_acm,
//                                                   m_rx_buffer,
//                                                   READ_SIZE);
            UNUSED_VARIABLE(ret);
        case APP_USBD_CDC_ACM_USER_EVT_PORT_CLOSE:
            bsp_board_led_off(LED_CDC_ACM_OPEN);
        case APP_USBD_CDC_ACM_USER_EVT_TX_DONE:
            bsp_board_led_invert(LED_CDC_ACM_TX);
        case APP_USBD_CDC_ACM_USER_EVT_RX_DONE:
            ret_code_t ret;
            NRF_LOG_INFO("Bytes waiting: %d", app_usbd_cdc_acm_bytes_stored(p_cdc_acm));
            do
                /*Get amount of data transfered*/
                size_t size = app_usbd_cdc_acm_rx_size(p_cdc_acm);
                NRF_LOG_INFO("RX: size: %lu char: %c", size, m_rx_buffer[0]);
                /* Fetch data until internal buffer is empty */
//                ret = app_usbd_cdc_acm_read(&m_app_cdc_acm,
//                                            m_rx_buffer,
//                                            READ_SIZE);
                                            &usb_rx_buffer[usb_rx_length],
                                            size);
//                //usb_rx_buffer[usb_rx_length] = m_rx_buffer[0];
                usb_rx_length+=size;
            } while (ret == NRF_SUCCESS);
            if ((usb_rx_length>1) && (usb_rx_buffer[usb_rx_length-1]==10)
                 && (usb_rx_buffer[usb_rx_length-2]==13)){
              m_send_flag = 1;
            bsp_board_led_invert(LED_CDC_ACM_RX);
static void usbd_user_ev_handler(app_usbd_event_type_t event)
    switch (event)
        case APP_USBD_EVT_DRV_SUSPEND:
            bsp_board_led_off(LED_USB_RESUME);
        case APP_USBD_EVT_DRV_RESUME:
            bsp_board_led_on(LED_USB_RESUME);
        case APP_USBD_EVT_STARTED:
        case APP_USBD_EVT_STOPPED:
            app_usbd_disable();
            bsp_board_leds_off();
        case APP_USBD_EVT_POWER_DETECTED:
            NRF_LOG_INFO("USB power detected");
            if (!nrf_drv_usbd_is_enabled())
                app_usbd_enable();
        case APP_USBD_EVT_POWER_REMOVED:
            NRF_LOG_INFO("USB power removed");
            app_usbd_stop();
        case APP_USBD_EVT_POWER_READY:
            NRF_LOG_INFO("USB ready");
            app_usbd_start();
static void bsp_event_callback(bsp_event_t ev)
    ret_code_t ret;
    switch ((unsigned int)ev)
        case CONCAT_2(BSP_EVENT_KEY_, BTN_CDC_DATA_SEND):
            m_send_flag = 1;
        case BTN_CDC_DATA_KEY_RELEASE :
            m_send_flag = 0;
        case CONCAT_2(BSP_EVENT_KEY_, BTN_CDC_NOTIFY_SEND):
            ret = app_usbd_cdc_acm_serial_state_notify(&m_app_cdc_acm,
                                                       APP_USBD_CDC_ACM_SERIAL_STATE_BREAK,
                                                       false);
            return; // no implementation needed
static void init_bsp(void)
    ret_code_t ret;
    ret = bsp_init(BSP_INIT_BUTTONS, bsp_event_callback);
    APP_ERROR_CHECK(ret);
    UNUSED_RETURN_VALUE(bsp_event_to_button_action_assign(BTN_CDC_DATA_SEND,
                                                          BSP_BUTTON_ACTION_RELEASE,
                                                          BTN_CDC_DATA_KEY_RELEASE));
    /* Configure LEDs */
static void init_cli(void)
    ret_code_t ret;
    ret = bsp_cli_init(bsp_event_callback);
    nrf_drv_uart_config_t uart_config = NRF_DRV_UART_DEFAULT_CONFIG;
    uart_config.pseltxd = TX_PIN_NUMBER;
    uart_config.pselrxd = RX_PIN_NUMBER;
    uart_config.hwfc    = NRF_UART_HWFC_DISABLED;
    ret = nrf_cli_init(&m_cli_uart, &uart_config, true, true, NRF_LOG_SEVERITY_INFO);
    ret = nrf_cli_start(&m_cli_uart);
    ret_code_t ret;
    static const app_usbd_config_t usbd_config = {
        .ev_state_proc = usbd_user_ev_handler
    ret = NRF_LOG_INIT(NULL);
    ret = nrf_drv_clock_init();
    while(!nrf_drv_clock_lfclk_is_running())
        /* Just waiting */
    ret = app_timer_init();
    init_bsp();
    init_cli();
    app_usbd_serial_num_generate();
    ret = app_usbd_init(&usbd_config);
    NRF_LOG_INFO("USBD CDC ACM example started.");
    app_usbd_class_inst_t const * class_cdc_acm = app_usbd_cdc_acm_class_inst_get(&m_app_cdc_acm);
    ret = app_usbd_class_append(class_cdc_acm);
    if (USBD_POWER_DETECTION)
        ret = app_usbd_power_events_enable();
        NRF_LOG_INFO("No USB power detection enabled\r\nStarting USB now");
        app_usbd_enable();
        app_usbd_start();
    while (true)
        while (app_usbd_event_queue_process())
            /* Nothing to do */
        if(m_send_flag)
            static int  frame_counter;
            usb_tx_length = sprintf((char*)usb_tx_buffer,
               "USB rx: '%s' len=%u. Cnt=%u\r\n", usb_rx_buffer, usb_rx_length, frame_counter);
//            size_t size = sprintf(m_tx_buffer, "Hello USB CDC FA demo: %u\r\n", frame_counter);
//            ret = app_usbd_cdc_acm_write(&m_app_cdc_acm, m_tx_buffer, size);
            ret = app_usbd_cdc_acm_write(&m_app_cdc_acm, usb_tx_buffer, usb_tx_length);
            if (ret == NRF_SUCCESS)
                ++frame_counter;
           m_send_flag = 0;
           memset(usb_rx_buffer, 0, 256);
           usb_rx_length = 0;
        nrf_cli_process(&m_cli_uart);
        UNUSED_RETURN_VALUE(NRF_LOG_PROCESS());
        /* Sleep CPU only if there was no interrupt since last loop processing */
        __WFE();
    You should take a look at how we do the RX buffer handling in the usbd_ble_uart example. But instead of sending the data over BLE as done in that example, you send it back over USB using app_usbd_cdc_acm_write().
    Snippet:
    static char m_cdc_data_array[256];
    #define ENDLINE_STRING "\r\n"
    In your cdc_acm_user_ev_handler:
                ret_code_t ret;
                static uint8_t index = 0;
                index++;
                do
                    if ((m_cdc_data_array[index - 1] == '\n') ||
                        (m_cdc_data_array[index - 1] == '\r') ||
                        (index >= (255)))
                        if (index > 1)
                            NRF_LOG_DEBUG("Ready to send data");
                            NRF_LOG_HEXDUMP_DEBUG(m_cdc_data_array, index);
                                if (length + sizeof(ENDLINE_STRING) < 255)
                                    memcpy(m_cdc_data_array + length, ENDLINE_STRING, sizeof(ENDLINE_STRING));
                                    length += sizeof(ENDLINE_STRING);
                                 ret = app_usbd_cdc_acm_write(&m_app_cdc_acm, m_cdc_data_array, length);
                        index = 0;
                    /*Get amount of data transferred*/
                    NRF_LOG_DEBUG("RX: size: %lu char: %c", size, m_cdc_data_array[index - 1]);
                                                &m_cdc_data_array[index],
                                                1);
                        index++;
  • I dealt with this question, I made same "usbd_ble_uart_freertos" example. Thank you very much!
