How could I make a PWM on nRF51
FormerMember
FormerMember
I want to make a pulse for buzzer and led. I find a sample source(led.c) and the Nordic SDK. It is good enough in case posivie and negative duty is same. I need to set a differnt value for positive and negative duty. It is possible? If yes, please let me know.
The belows is my sample source.
#define BEEP_HW_OFF()																							\
		NRF_GPIOTE->CONFIG[GPIOTE_CHANNEL_NUMBER] = (GPIOTE_CONFIG_MODE_Disabled << GPIOTE_CONFIG_MODE_Pos);	\
		NRF_TIMER1->TASKS_STOP = 1;																				\
		nrf_gpio_pin_clear(BEEP_GPIO)
#define BEEP_HW_ON()									\
		nrf_gpio_cfg_output(BEEP_GPIO);					\
		beep_hw_init();									\
		NRF_TIMER1->TASKS_START = 1
static void beep_hw_init(void)
    uint32_t err_code;
    // Configure PPI channel 0 to toggle ADVERTISING_LED_PIN_NO on every TIMER1 COMPARE[0] match
    err_code = sd_ppi_channel_assign(PPI_CHAN0_TO_TOGGLE_BEEP,
                                     &(NRF_TIMER1->EVENTS_COMPARE[0]),
                                     &(NRF_GPIOTE->TASKS_OUT[GPIOTE_CHANNEL_NUMBER]));
    // Enable PPI channel 0
    err_code = sd_ppi_channel_enable_set(PPI_CHEN_CH0_Msk);
    // Configure timer
    NRF_TIMER1->MODE      = TIMER_MODE_MODE_Timer;
    NRF_TIMER1->BITMODE   = TIMER_BITMODE_BITMODE_16Bit;
    NRF_TIMER1->PRESCALER = TIMER_PRESCALER;
    // Clear the timer
    NRF_TIMER1->TASKS_CLEAR = 1;
    // Load the value to TIMER1 CC0 register. The following value is calculated to generate
    // a 2 Hz waveform that will serve as input to the LED
    NRF_TIMER1->CC[0] = BEEP_INTENSITY_HIGH;
    // Make the Capture Compare 0 event to clear the timer. This will restart the timer.
    NRF_TIMER1->SHORTS = TIMER_SHORTS_COMPARE0_CLEAR_Enabled << TIMER_SHORTS_COMPARE0_CLEAR_Pos;
    // There is no need to setup NRF_TIMER1->INTENSET register because the application do not need
    // to wake up the CPU on Timer interrupts.
    // Configure the GPIOTE Task to toggle the LED state.
    nrf_gpiote_task_config(GPIOTE_CHANNEL_NUMBER,
                           BEEP_GPIO,
                           NRF_GPIOTE_POLARITY_TOGGLE,
                           NRF_GPIOTE_INITIAL_VALUE_HIGH);
