Where did nrf_dfu_button_enter_check go?
I working on migrating my project from SDK 14.0 to 15.2 and are currently working on the secure_bootloader. In our current solution we use the __weak nrf_dfu_button_enter_check to poll the button for a while (long press -> DFU, short press -> just start the application). The button handling seems to be moved into nrf_bootloader though, without __weak declaration.
Am I missing something here, or do I have to modify the SDK for my use case to work?
BR Henrik
    You will need to modify the SDK unfortunately. The current implementation does not include an option to differentiate between long and short button press. The new nrf_dfu_button_enter_check implementation covers more methods than before and I guess that's why we thought it was ok to remove the weak declaration :
  • Ok, since I did the modifications yesterday anyways, I guess thats sort of good news. ;)
    If you take feature requests regarding this it would be nice to have a some kind of fully customisable check for this:
    __weak bool custom_user_enter_method();
    static bool dfu_enter_check(void)
        if (NRF_BL_DFU_ENTER_METHOD_CUSTOM && custom_user_enter_method())
            NRF_LOG_DEBUG("DFU mode requested via custom method.");
            return true;
    Another thing regarding the dfu_enter_check function, my guess is that its a bug on line 305.
        if (NRF_BL_DFU_ENTER_METHOD_GPREGRET &&
           (nrf_power_gpregret_get() & BOOTLOADER_DFU_START)) // Should be == and not &?
            NRF_LOG_DEBUG("DFU mode requested via GPREGRET.");
            return true;
    BR Henrik
  • Thanks for the feedback. I have created an internal ticket to log the feature request.
    I see your point. However, the reset value of GPREGRET is 0 so it will work as intended. It also allows you to use remaining bits for other purposes.
