I programmed a NRF52840 Dongle with the example light switch code having changed the channel to 14 which is what my coordinator is on.
I then programmed a NRF52840DK with the example switch code and adjusted the search to look specifically for the dongle with the endpoint at 10. All the other compatible devices in my Zigbee network have endpoints set to 1.
I programmed my Smartthings hub to recognise the Nordic dongle as a simple light bulb.
I put the hub in discover mode and fire up the dongle and the DK which both connect.
The Smartthings hub recognises the dongle as a light and I can turn it on and off from the Smartthings app on my phone.
The NRF52840DK switch also finds the dongle and I can control the light on the dongle using the two buttons on the DK board. The Smartthings hub DOES NOT see the updates to the dongle made from the DK switch unless I manually refresh it, but that is another issue.
Everything is fine for a random amount of time varying between a few minutes and several hours up to just over a day on one occasion. Then the light (dongle) simply stops responding. It no longer responds to the Smartthings hub nor to the DK board switch. If I restart the switch it fails to find the light. Only when I restart the light does it work again.
Does anyone have any idea why this should be happening? Can anyone suggest how I can debug this situation?
