No Output from SAADC to Uart over BLE
Im trying to combine the SAADC with the uart example and i have copied and modifed the saadc functions according to this post https://devzone.nordicsemi.com/f/nordic-q-a/32956/sending-adc-sampled-audio-data-over-ble and i am able to build and run the code but not able to get any output when running putty and im not able to see the bluetooth device either thnk i have kind of an idea as to where to problem might be as it worked with just uart until i added the saadc_init();, saadc_sampling_event_init(); and saadc_event_enable(); to the main loop but i just can't seem to figure it out so if anyone could help me it would be much appreciated. i have included the main.c code.
 * Copyright (c) 2014 - 2018, Nordic Semiconductor ASA
 * All rights reserved.
/** @file
 * @defgroup ble_sdk_uart_over_ble_main main.c
 * @ingroup  ble_sdk_app_nus_eval
 * @brief    UART over BLE application main file.
 * This file contains the source code for a sample application that uses the Nordic UART service.
 * This application uses the @ref srvlib_conn_params module.
#include "app_error.h"
#include "app_timer.h"
#include "app_uart.h"
#include "app_util.h"
#include "ble.h"
#include "ble_gap.h"
#include "ble_advdata.h"
#include "ble_advertising.h"
#include "ble_conn_params.h"
#include "ble_hci.h"
#include "ble_nus.h"
#include "boards.h"
#include "bsp_btn_ble.h"
#include "nordic_common.h"
#include "nrf.h"
#include "nrf_ble_gatt.h"
#include "nrf_ble_qwr.h"
#include "nrf_delay.h"
#include "nrf_drv_ppi.h"
#include "nrf_drv_timer.h"
#include "nrf_drv_saadc.h"
#include "nrf_pwr_mgmt.h"
#include "nrf_sdh.h"
#include "nrf_sdh_ble.h"
#include "nrf_sdh_soc.h"
#include <stdbool.h>
#include <stdint.h>
#include <stdio.h>
#include <string.h>
#if defined(UART_PRESENT)
#include "nrf_uart.h"
#if defined(UARTE_PRESENT)
#include "nrf_uarte.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#define SAMPLES_IN_BUFFER 5
volatile uint8_t state = 1;
#define APP_BLE_CONN_CFG_TAG 1 /**< A tag identifying the SoftDevice BLE configuration. */
#define DEVICE_NAME "Nordic_SAADC_UART"                        /**< Name of device. Will be included in the advertising data. */
#define NUS_SERVICE_UUID_TYPE BLE_UUID_TYPE_VENDOR_BEGIN /**< UUID type for the Nordic UART Service (vendor specific). */
#define APP_BLE_OBSERVER_PRIO 3 /**< Application's BLE observer priority. You shouldn't need to modify this value. */
#define APP_ADV_INTERVAL 64 /**< The advertising interval (in units of 0.625 ms. This value corresponds to 40 ms). */
#define APP_ADV_DURATION 18000 /**< The advertising duration (180 seconds) in units of 10 milliseconds. */
#define MIN_CONN_INTERVAL MSEC_TO_UNITS(20, UNIT_1_25_MS)    /**< Minimum acceptable connection interval (20 ms), Connection interval uses 1.25 ms units. */
#define MAX_CONN_INTERVAL MSEC_TO_UNITS(75, UNIT_1_25_MS)    /**< Maximum acceptable connection interval (75 ms), Connection interval uses 1.25 ms units. */
#define SLAVE_LATENCY 0                                      /**< Slave latency. */
#define CONN_SUP_TIMEOUT MSEC_TO_UNITS(4000, UNIT_10_MS)     /**< Connection supervisory timeout (4 seconds), Supervision Timeout uses 10 ms units. */
#define FIRST_CONN_PARAMS_UPDATE_DELAY APP_TIMER_TICKS(5000) /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
#define NEXT_CONN_PARAMS_UPDATE_DELAY APP_TIMER_TICKS(30000) /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
#define MAX_CONN_PARAMS_UPDATE_COUNT 3                       /**< Number of attempts before giving up the connection parameter negotiation. */
#define DEAD_BEEF 0xDEADBEEF /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
#define UART_TX_BUF_SIZE 256 /**< UART TX buffer size. */
#define UART_RX_BUF_SIZE 256 /**< UART RX buffer size. */
int queue_count = 0;
BLE_NUS_DEF(m_nus, NRF_SDH_BLE_TOTAL_LINK_COUNT); /**< BLE NUS service instance. */
NRF_BLE_GATT_DEF(m_gatt);                         /**< GATT module instance. */
NRF_BLE_QWR_DEF(m_qwr);                           /**< Context for the Queued Write module.*/
BLE_ADVERTISING_DEF(m_advertising);               /**< Advertising module instance. */
//uart constants
static uint16_t m_conn_handle = BLE_CONN_HANDLE_INVALID;               /**< Handle of the current connection. */
static uint16_t m_ble_nus_max_data_len = BLE_GATT_ATT_MTU_DEFAULT - 3; /**< Maximum length of data (in bytes) that can be transmitted to the peer by the Nordic UART service module. */
static ble_uuid_t m_adv_uuids[] =                                      /**< Universally unique service identifier. */
        {BLE_UUID_NUS_SERVICE, NUS_SERVICE_UUID_TYPE}};
//SAADc constants
static const nrf_drv_timer_t m_timer = NRF_DRV_TIMER_INSTANCE(0);
static nrf_saadc_value_t m_buffer_pool[2][SAMPLES_IN_BUFFER];
static nrf_ppi_channel_t m_ppi_channel;
static uint32_t m_adc_evt_counter;
/**@brief Function for assert macro callback.
 * @warning This handler is an example only and does not fit a final product. You need to analyse
 * @param[in] line_num    Line number of the failing ASSERT call.
 * @param[in] p_file_name File name of the failing ASSERT call.
void assert_nrf_callback(uint16_t line_num, const uint8_t *p_file_name) {
/**@brief Function for initializing the timer module.
static void timers_init(void) {
void timer_handler(nrf_timer_event_t event_type, void *p_context) {
//SAADC functions
void saadc_sampling_event_init(void) {
  ret_code_t err_code;
  /* setup m_timer for compare event every 400ms */
  uint32_t ticks = nrf_drv_timer_ms_to_ticks(&m_timer, 400);
      NRF_TIMER_CC_CHANNEL0,
      ticks,
      NRF_TIMER_SHORT_COMPARE0_CLEAR_MASK,
      false);
  uint32_t timer_compare_event_addr = nrf_drv_timer_compare_event_address_get(&m_timer,
      NRF_TIMER_CC_CHANNEL0);
  uint32_t saadc_sample_task_addr = nrf_drv_saadc_sample_task_get();
  /* setup ppi channel so that timer compare event is triggering sample task in saadc */
      timer_compare_event_addr,
      saadc_sample_task_addr);
void saadc_sampling_event_enable(void) {
void saadc_callback(nrf_drv_saadc_evt_t const *p_event) {
  if (p_event->type == NRF_DRV_SAADC_EVT_DONE) {
    err_code = nrf_drv_saadc_buffer_convert(p_event->data.done.p_buffer, SAMPLES_IN_BUFFER);
    uint16_t length = SAMPLES_IN_BUFFER;
    uint8_t transfer_buffer[SAMPLES_IN_BUFFER];
    for (uint8_t i = 0; i < p_event->data.done.size; i++) {
      //transfer_buffer[i] = p_event->data.done.p_buffer[i];
      transfer_buffer[(i*2)] = p_event->data.done.p_buffer[i] >> 8; //in 10bit to 16bit case
      //transfer_buffer[(i*2)+1] = p_event->data.done.p_buffer[i];    //in 10bit to 16bit case
    do {
      err_code = ble_nus_data_send(&m_nus, transfer_buffer, &length, m_conn_handle);
      if (err_code == NRF_SUCCESS) {
        queue_count--;
        NRF_LOG_INFO("queue count: %d", queue_count);
      } else {
        if ((err_code != NRF_ERROR_INVALID_STATE) && (err_code != NRF_ERROR_BUSY) &&
            (err_code != NRF_ERROR_NOT_FOUND)) {
    } while (err_code == NRF_ERROR_BUSY);
    NRF_LOG_INFO("ADC event number: %d", (int)m_adc_evt_counter);
    m_adc_evt_counter++;
void saadc_init(void) {
  nrf_saadc_channel_config_t channel_config =
      NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(NRF_SAADC_INPUT_AIN0);
  err_code = nrf_drv_saadc_init(NULL, saadc_callback);
  err_code = nrf_drv_saadc_buffer_convert(m_buffer_pool[0], SAMPLES_IN_BUFFER);
  err_code = nrf_drv_saadc_buffer_convert(m_buffer_pool[1], SAMPLES_IN_BUFFER);
// end of SAADC functions
 *          the device. It also sets the permissions and appearance.
static void gap_params_init(void) {
  uint32_t err_code;
  ble_gap_conn_params_t gap_conn_params;
      (const uint8_t *)DEVICE_NAME,
      strlen(DEVICE_NAME));
  gap_conn_params.slave_latency = SLAVE_LATENCY;
  gap_conn_params.conn_sup_timeout = CONN_SUP_TIMEOUT;
static void nrf_qwr_error_handler(uint32_t nrf_error) {
  APP_ERROR_HANDLER(nrf_error);
/**@brief Function for handling the data from the Nordic UART Service.
 * @details This function will process the data received from the Nordic UART BLE Service and send
 *          it to the UART module.
 * @param[in] p_evt       Nordic UART Service event.
/**@snippet [Handling the data received over BLE] */
static void nus_data_handler(ble_nus_evt_t *p_evt) {
  if (p_evt->type == BLE_NUS_EVT_RX_DATA) {
    uint32_t err_code;
    for (uint32_t i = 0; i < p_evt->params.rx_data.length; i++) {
      do {
        err_code = app_uart_put(p_evt->params.rx_data.p_data[i]);
        if ((err_code != NRF_SUCCESS) && (err_code != NRF_ERROR_BUSY)) {
          NRF_LOG_ERROR("Failed receiving NUS message. Error 0x%x. ", err_code);
    if (p_evt->params.rx_data.p_data[p_evt->params.rx_data.length - 1] == '\r') {
      while (app_uart_put('\n') == NRF_ERROR_BUSY)
static void services_init(void) {
  uint32_t err_code;
  ble_nus_init_t nus_init;
  // Initialize NUS.
/**@brief Function for handling an event from the Connection Parameters Module.
 * @details This function will be called for all events in the Connection Parameters Module
 *          which are passed to the application.
 * @note All this function does is to disconnect. This could have been done by simply setting
 *       the disconnect_on_fail config parameter, but instead we use the event handler
 *       mechanism to demonstrate its use.
static void on_conn_params_evt(ble_conn_params_evt_t *p_evt) {
  uint32_t err_code;
  if (p_evt->evt_type == BLE_CONN_PARAMS_EVT_FAILED) {
/**@brief Function for handling errors from the Connection Parameters module.
static void conn_params_error_handler(uint32_t nrf_error) {
static void conn_params_init(void) {
  uint32_t err_code;
  cp_init.p_conn_params = NULL;
  cp_init.next_conn_params_update_delay = NEXT_CONN_PARAMS_UPDATE_DELAY;
  cp_init.max_conn_params_update_count = MAX_CONN_PARAMS_UPDATE_COUNT;
  cp_init.start_on_notify_cccd_handle = BLE_GATT_HANDLE_INVALID;
  cp_init.disconnect_on_fail = false;
  cp_init.evt_handler = on_conn_params_evt;
  cp_init.error_handler = conn_params_error_handler;
static void sleep_mode_enter(void) {
  // Prepare wakeup buttons.
static void on_adv_evt(ble_adv_evt_t ble_adv_evt) {
  uint32_t err_code;
  switch (ble_adv_evt) {
  case BLE_ADV_EVT_FAST:
  case BLE_ADV_EVT_IDLE:
    sleep_mode_enter();
static void ble_evt_handler(ble_evt_t const *p_ble_evt, void *p_context) {
  uint32_t err_code;
  switch (p_ble_evt->header.evt_id) {
  case BLE_GAP_EVT_CONNECTED:
    NRF_LOG_INFO("Connected");
    NRF_LOG_INFO("Disconnected");
  case BLE_GAP_EVT_PHY_UPDATE_REQUEST: {
    ble_gap_phys_t const phys =
            .rx_phys = BLE_GAP_PHY_AUTO,
            .tx_phys = BLE_GAP_PHY_AUTO,
  } break;
    // Pairing not supported
  case BLE_GATTC_EVT_TIMEOUT:
  case BLE_GATTS_EVT_TIMEOUT:
    // No implementation needed.
/**@brief Function for the SoftDevice initialization.
 * @details This function initializes the SoftDevice and the BLE event interrupt.
static void ble_stack_init(void) {
  uint32_t ram_start = 0;
  // Enable BLE stack.
/**@brief Function for handling events from the GATT library. */
void gatt_evt_handler(nrf_ble_gatt_t *p_gatt, nrf_ble_gatt_evt_t const *p_evt) {
  if ((m_conn_handle == p_evt->conn_handle) && (p_evt->evt_id == NRF_BLE_GATT_EVT_ATT_MTU_UPDATED)) {
    m_ble_nus_max_data_len = p_evt->params.att_mtu_effective - OPCODE_LENGTH - HANDLE_LENGTH;
    NRF_LOG_INFO("Data len is set to 0x%X(%d)", m_ble_nus_max_data_len, m_ble_nus_max_data_len);
  NRF_LOG_DEBUG("ATT MTU exchange completed. central 0x%x peripheral 0x%x",
      p_gatt->att_mtu_desired_central,
      p_gatt->att_mtu_desired_periph);
/**@brief Function for initializing the GATT library. */
void gatt_init(void) {
  err_code = nrf_ble_gatt_init(&m_gatt, gatt_evt_handler);
  err_code = nrf_ble_gatt_att_mtu_periph_set(&m_gatt, NRF_SDH_BLE_GATT_MAX_MTU_SIZE);
 * @param[in]   event   Event generated by button press.
void bsp_event_handler(bsp_event_t event) {
  uint32_t err_code;
  switch (event) {
  case BSP_EVENT_SLEEP:
    sleep_mode_enter();
  case BSP_EVENT_DISCONNECT:
    err_code = sd_ble_gap_disconnect(m_conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION);
    if (err_code != NRF_ERROR_INVALID_STATE) {
  case BSP_EVENT_WHITELIST_OFF:
    if (m_conn_handle == BLE_CONN_HANDLE_INVALID) {
 *          a string. The string will be be sent over BLE when the last character received was a
 *          'new line' '\n' (hex 0x0A) or if the string has reached the maximum data length.
/**@snippet [Handling the data received over UART] */
void uart_event_handle(app_uart_evt_t *p_event) {
  static uint8_t index = 0;
  uint32_t err_code;
  switch (p_event->evt_type) {
  case APP_UART_DATA_READY:
    index++;
    if ((data_array[index - 1] == '\n') ||
        (data_array[index - 1] == '\r') ||
        (index >= m_ble_nus_max_data_len)) {
      if (index > 1) {
        do {
        } while (err_code == NRF_ERROR_RESOURCES);
      index = 0;
  case APP_UART_FIFO_ERROR:
/**@brief  Function for initializing the UART module.
/**@snippet [UART Initialization] */
static void uart_init(void) {
  uint32_t err_code;
    .rx_pin_no = RX_PIN_NUMBER,
    .tx_pin_no = TX_PIN_NUMBER,
    .rts_pin_no = RTS_PIN_NUMBER,
    .cts_pin_no = CTS_PIN_NUMBER,
    .use_parity = false,
    .baud_rate = NRF_UART_BAUDRATE_115200
#else
    .baud_rate = NRF_UARTE_BAUDRATE_115200
      UART_RX_BUF_SIZE,
      UART_TX_BUF_SIZE,
      uart_event_handle,
      APP_IRQ_PRIORITY_LOWEST,
      err_code);
static void advertising_init(void) {
  uint32_t err_code;
  ble_advertising_init_t init;
  init.advdata.name_type = BLE_ADVDATA_FULL_NAME;
  init.advdata.flags = BLE_GAP_ADV_FLAGS_LE_ONLY_LIMITED_DISC_MODE;
  init.srdata.uuids_complete.p_uuids = m_adv_uuids;
  init.config.ble_adv_fast_enabled = true;
  init.config.ble_adv_fast_timeout = APP_ADV_DURATION;
static void buttons_leds_init(bool *p_erase_bonds) {
  bsp_event_t startup_event;
  uint32_t err_code = bsp_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS, bsp_event_handler);
static void log_init(void) {
static void power_management_init(void) {
static void idle_state_handle(void) {
  UNUSED_RETURN_VALUE(NRF_LOG_PROCESS());
  nrf_pwr_mgmt_run();
static void advertising_start(void) {
/**@brief Application main function.
int main(void) {
  bool erase_bonds;
  // Initialize uart code
  uart_init();
  log_init();
  timers_init();
  power_management_init();
  ble_stack_init();
  gap_params_init();
  gatt_init();
  services_init();
  advertising_init();
  conn_params_init();
  // Start execution.
  printf("\r\nSAADC UART APP started.\r\n");
  saadc_init();
  advertising_start();
  // Enter main loop.
  for (;;) {
    idle_state_handle();
