NRF_EVT_FLASH_OPERATION_SUCCESS event callback is not triggered for every sd_flash function called
I am experimenting with calling sd_flash_write with waiting, if it returns NRF_ERROR_BUSY, just try again, and then return either success fail
void flashWrite( uint8_t *addr, uint16_t len, uint8_t *buf )
	uint32_t error_code;	uint32_t word_len;
	uint32_t * buffer_ptr = NULL;
	// buf address could be not WORD-aligned need to create a buffer for it
	if (len ==0){
		Display(("write len = 0\r\n"));
		return;
	if ( (len & 0x3) == 0){
		word_len = len >> 2; // len is times of 4
	}else{
		word_len = (len >> 2) + 1;
	if (( buffer_ptr = (uint32_t*)malloc(word_len<<2) ) ) {
		memcpy(buffer_ptr, buf, word_len<<2);
		while (( error_code = sd_flash_write( (uint32_t*) addr, buffer_ptr, word_len)) == NRF_ERROR_BUSY);
		if ( (error_code )  != NRF_SUCCESS){
			Display(("sd_flash_write()      error code 0x%x addr=0x%x len=0x%x wordlen=0x%x srcaddr=0x%x\r\n", error_code, addr, len, word_len, buf));
			Display(("sd_flash_write()      OK addr=0x%x len=0x%x wordlen=0x%x\r\n", addr, len, word_len));
		free(buffer_ptr);
	}else{
		Display(("flashWrite malloc error\r\n"));
/**@brief Function for dispatching a system event to interested modules.
 * @details This function is called from the System event interrupt handler after a system
 *          event has been received.
 * @param[in]   sys_evt   System stack event.
void sys_evt_dispatch(uint32_t sys_evt)
    if (sys_evt == NRF_EVT_FLASH_OPERATION_SUCCESS){
    	Display(("Flash Op is Done\r\n"));
    }else{
    	LOG_DEBUG(" sys_evt_dispatch code 0x%x", sys_evt);
main()
    // init staff, erase flash ...
    flashWrite(...);
    flashWrite(...);
    flashWrite(...);
If I called several sd_flash_write in such manner back to back, I can only receive one NRF_EVT_FLASH_OPERATION_SUCCESS callback ( "Flash Op is Done" is only printed once")
I checked flash memory content all write operation did succeed.
So it seems NRF_EVT_FLASH_OPERATION_SUCCESS more like "the last flash operation is successful and flash is idle now", it is not like every flash operation will trigger one NRF_EVT_FLASH_OPERATION_SUCCESS , but a series of flash operation trigger one NRF_EVT_FLASH_OPERATION_SUCCESS
Is SoftDevice designed to be so?
  • The general rule is that you should only send one write/erase operation at each time, meaning that if you do one write/erase operation, you must wait for the callback before performing another write/erase operation. If you use Pstorage (persistent storage) module however, then the Pstorage module handles this waiting for you, so you can send multiple erase/write operations one after another. Pstorage will queue up the erase/write requests and feed the softdevice with requests as the associated callback events arrive. I have attached a pstorage example on this thread.
