How to use BSP_BUTTON_ACTION_PUSH and BSP_BUTTON_ACTION_LONG_PUSH on the same button, with two different functions?
Hi, I have seen a few similar questions to this but the answers weren't too clear...I am trying to use both the long button push and the button push actions to generate separate events to be handled by the bsp_event_handler() but cannot seem to assign a new action to an event/button. How can i use the bsp_event_to_button_action_assign() to enable both a long push and a short push on a single button that call separate functions? I am also slightly confused as to which files are used to control the push buttons as there seem to be a few ways to control them depending on if BLE is used...I read on the online infocenter the buttons can be controlled using BSP, Button Handling Library, GPIOTE, and also the BLE files. Is there a common practice to getting the long push to work? I also saw in another thread that timers could be use to distinguish between a long and short push, however the bsp_board_button_state_get() function would always return true, even when the button wasn't pressed when the timer ended and the bsp_board_button_state_get() function was called. Am I closer to a long push with this approach? (I was able to get a "double" press effect, but it needs to be a long press)
What I am working with: Using nRF52840 and SDK 15.2.0 developing on Mac OS using Segger. The app uses the ble_app_template and has the following path:
nRF5_SDK_15.2.0_9412b96/examples/ble_peripheral/my_project_file_name/pca10056/s140/ses/ble_app_template_pca10056_s140.emProject
I included the path because I'm not sure if which example type it is included in affects which modules control the buttons.
Any help is greatly appreciated, Thanks!
    Button presses are detected at the HW level by the GPIOTE peripheral, regardless of what library you use on top. Both provide abstraction from the gpiote driver, but probably most importantly, use app timer to prevent debouncing from triggering multiple events for a single button press.
    I think the button handling can be a bit more flexible if you need a create custom events. The code below shows the changes I did to main.c for the ble_app_uart project in SDK 15.2.0 to enable these events for button 1 (change USE_BSP define at the top of main.c to switch between BSP and the button handling library). Hope it helps.
     * Copyright (c) 2014 - 2018, Nordic Semiconductor ASA
     * All rights reserved.
    /** @file
     * @defgroup ble_sdk_uart_over_ble_main main.c
     * @ingroup  ble_sdk_app_nus_eval
     * @brief    UART over BLE application main file.
     * This file contains the source code for a sample application that uses the Nordic UART service.
     * This application uses the @ref srvlib_conn_params module.
    #include <stdint.h>
    #include <string.h>
    #include "nordic_common.h"
    #include "nrf.h"
    #include "ble_hci.h"
    #include "ble_advdata.h"
    #include "ble_advertising.h"
    #include "ble_conn_params.h"
    #include "nrf_sdh.h"
    #include "nrf_sdh_soc.h"
    #include "nrf_sdh_ble.h"
    #include "nrf_ble_gatt.h"
    #include "nrf_ble_qwr.h"
    #include "app_timer.h"
    #include "ble_nus.h"
    #include "app_uart.h"
    #include "bsp_btn_ble.h"
    #include "nrf_pwr_mgmt.h"
    #include "app_button.h"
    #if defined (UART_PRESENT)
    #include "nrf_uart.h"
    #if defined (UARTE_PRESENT)
    #include "nrf_uarte.h"
    #include "nrf_log.h"
    #include "nrf_log_ctrl.h"
    #define USE_BSP 0
    #define APP_BLE_CONN_CFG_TAG            1                                           /**< A tag identifying the SoftDevice BLE configuration. */
    #define DEVICE_NAME                     "Nordic_UART"                               /**< Name of device. Will be included in the advertising data. */
    #define NUS_SERVICE_UUID_TYPE           BLE_UUID_TYPE_VENDOR_BEGIN                  /**< UUID type for the Nordic UART Service (vendor specific). */
    #define APP_BLE_OBSERVER_PRIO           3                                           /**< Application's BLE observer priority. You shouldn't need to modify this value. */
    #define APP_ADV_INTERVAL                64                                          /**< The advertising interval (in units of 0.625 ms. This value corresponds to 40 ms). */
    #define APP_ADV_DURATION                18000                                       /**< The advertising duration (180 seconds) in units of 10 milliseconds. */
    #define MIN_CONN_INTERVAL               MSEC_TO_UNITS(20, UNIT_1_25_MS)             /**< Minimum acceptable connection interval (20 ms), Connection interval uses 1.25 ms units. */
    #define MAX_CONN_INTERVAL               MSEC_TO_UNITS(75, UNIT_1_25_MS)             /**< Maximum acceptable connection interval (75 ms), Connection interval uses 1.25 ms units. */
    #define SLAVE_LATENCY                   0                                           /**< Slave latency. */
    #define CONN_SUP_TIMEOUT                MSEC_TO_UNITS(4000, UNIT_10_MS)             /**< Connection supervisory timeout (4 seconds), Supervision Timeout uses 10 ms units. */
    #define FIRST_CONN_PARAMS_UPDATE_DELAY  APP_TIMER_TICKS(5000)                       /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
    #define NEXT_CONN_PARAMS_UPDATE_DELAY   APP_TIMER_TICKS(30000)                      /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
    #define MAX_CONN_PARAMS_UPDATE_COUNT    3                                           /**< Number of attempts before giving up the connection parameter negotiation. */
    #define DEAD_BEEF                       0xDEADBEEF                                  /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
    #define UART_TX_BUF_SIZE                256                                         /**< UART TX buffer size. */
    #define UART_RX_BUF_SIZE                256                                         /**< UART RX buffer size. */
    BLE_NUS_DEF(m_nus, NRF_SDH_BLE_TOTAL_LINK_COUNT);                                   /**< BLE NUS service instance. */
    NRF_BLE_GATT_DEF(m_gatt);                                                           /**< GATT module instance. */
    NRF_BLE_QWR_DEF(m_qwr);                                                             /**< Context for the Queued Write module.*/
    BLE_ADVERTISING_DEF(m_advertising);                                                 /**< Advertising module instance. */
    static uint16_t   m_conn_handle          = BLE_CONN_HANDLE_INVALID;                 /**< Handle of the current connection. */
    static uint16_t   m_ble_nus_max_data_len = BLE_GATT_ATT_MTU_DEFAULT - 3;            /**< Maximum length of data (in bytes) that can be transmitted to the peer by the Nordic UART service module. */
    static ble_uuid_t m_adv_uuids[]          =                                          /**< Universally unique service identifier. */
    /**@brief Function for assert macro callback.
     * @warning This handler is an example only and does not fit a final product. You need to analyse
     * @param[in] line_num    Line number of the failing ASSERT call.
     * @param[in] p_file_name File name of the failing ASSERT call.
    /**@brief Function for initializing the timer module.
    static void timers_init(void)
     *          the device. It also sets the permissions and appearance.
        uint32_t                err_code;
                                              strlen(DEVICE_NAME));
        APP_ERROR_HANDLER(nrf_error);
    /**@brief Function for handling the data from the Nordic UART Service.
     * @details This function will process the data received from the Nordic UART BLE Service and send
     *          it to the UART module.
     * @param[in] p_evt       Nordic UART Service event.
    /**@snippet [Handling the data received over BLE] */
            uint32_t err_code;
            for (uint32_t i = 0; i < p_evt->params.rx_data.length; i++)
                do
                    err_code = app_uart_put(p_evt->params.rx_data.p_data[i]);
                    if ((err_code != NRF_SUCCESS) && (err_code != NRF_ERROR_BUSY))
                        NRF_LOG_ERROR("Failed receiving NUS message. Error 0x%x. ", err_code);
                } while (err_code == NRF_ERROR_BUSY);
            if (p_evt->params.rx_data.p_data[p_evt->params.rx_data.length - 1] == '\r')
                while (app_uart_put('\n') == NRF_ERROR_BUSY);
        uint32_t           err_code;
        ble_nus_init_t     nus_init;
        // Initialize NUS.
    /**@brief Function for handling an event from the Connection Parameters Module.
     * @details This function will be called for all events in the Connection Parameters Module
     *          which are passed to the application.
     * @note All this function does is to disconnect. This could have been done by simply setting
     *       the disconnect_on_fail config parameter, but instead we use the event handler
     *       mechanism to demonstrate its use.
        uint32_t err_code;
    /**@brief Function for handling errors from the Connection Parameters module.
        // Prepare wakeup buttons.
        uint32_t err_code;
        switch (ble_adv_evt)
            case BLE_ADV_EVT_FAST:
            case BLE_ADV_EVT_IDLE:
                sleep_mode_enter();
        uint32_t err_code;
            case BLE_GAP_EVT_CONNECTED:
                NRF_LOG_INFO("Connected");
                NRF_LOG_INFO("Disconnected");
                ble_gap_phys_t const phys =
                    .rx_phys = BLE_GAP_PHY_AUTO,
                    .tx_phys = BLE_GAP_PHY_AUTO,
            } break;
                // Pairing not supported
            case BLE_GATTC_EVT_TIMEOUT:
            case BLE_GATTS_EVT_TIMEOUT:
                // No implementation needed.
    /**@brief Function for the SoftDevice initialization.
     * @details This function initializes the SoftDevice and the BLE event interrupt.
        ret_code_t err_code;
        uint32_t ram_start = 0;
        // Enable BLE stack.
    /**@brief Function for handling events from the GATT library. */
    void gatt_evt_handler(nrf_ble_gatt_t * p_gatt, nrf_ble_gatt_evt_t const * p_evt)
        if ((m_conn_handle == p_evt->conn_handle) && (p_evt->evt_id == NRF_BLE_GATT_EVT_ATT_MTU_UPDATED))
            m_ble_nus_max_data_len = p_evt->params.att_mtu_effective - OPCODE_LENGTH - HANDLE_LENGTH;
            NRF_LOG_INFO("Data len is set to 0x%X(%d)", m_ble_nus_max_data_len, m_ble_nus_max_data_len);
        NRF_LOG_DEBUG("ATT MTU exchange completed. central 0x%x peripheral 0x%x",
                      p_gatt->att_mtu_desired_central,
                      p_gatt->att_mtu_desired_periph);
    /**@brief Function for initializing the GATT library. */
    void gatt_init(void)
        err_code = nrf_ble_gatt_init(&m_gatt, gatt_evt_handler);
        err_code = nrf_ble_gatt_att_mtu_periph_set(&m_gatt, NRF_SDH_BLE_GATT_MAX_MTU_SIZE);
    #define BT0_SHORT_PUSH BSP_EVENT_KEY_0
    #define BT0_LONG_PUSH  BSP_EVENT_KEY_1
     * @param[in]   event   Event generated by button press.
        uint32_t err_code;
        switch (event)
            case BT0_SHORT_PUSH:
                NRF_LOG_INFO("Short button press");
            case BT0_LONG_PUSH:
                NRF_LOG_INFO("Long button press");
     *          a string. The string will be be sent over BLE when the last character received was a
     *          'new line' '\n' (hex 0x0A) or if the string has reached the maximum data length.
    /**@snippet [Handling the data received over UART] */
        static uint8_t index = 0;
        uint32_t       err_code;
        switch (p_event->evt_type)
            case APP_UART_DATA_READY:
                index++;
                if ((data_array[index - 1] == '\n') ||
                    (data_array[index - 1] == '\r') ||
                    (index >= m_ble_nus_max_data_len))
                    if (index > 1)
                        do
                        } while (err_code == NRF_ERROR_RESOURCES);
                    index = 0;
            case APP_UART_FIFO_ERROR:
    /**@brief  Function for initializing the UART module.
    /**@snippet [UART Initialization] */
    static void uart_init(void)
            .rx_pin_no    = RX_PIN_NUMBER,
            .tx_pin_no    = TX_PIN_NUMBER,
            .use_parity   = false,
            .baud_rate    = NRF_UART_BAUDRATE_115200
    #else
            .baud_rate    = NRF_UARTE_BAUDRATE_115200
                           UART_RX_BUF_SIZE,
                           UART_TX_BUF_SIZE,
                           uart_event_handle,
                           APP_IRQ_PRIORITY_LOWEST,
                           err_code);
        ble_advertising_init_t init;
        init.advdata.name_type          = BLE_ADVDATA_FULL_NAME;
        init.advdata.flags              = BLE_GAP_ADV_FLAGS_LE_ONLY_LIMITED_DISC_MODE;
        init.srdata.uuids_complete.p_uuids  = m_adv_uuids;
        bsp_event_t startup_event;
        uint32_t err_code = bsp_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS, bsp_event_handler);
        err_code = bsp_event_to_button_action_assign(BSP_BOARD_BUTTON_0, BSP_BUTTON_ACTION_PUSH, BT0_SHORT_PUSH);
        err_code = bsp_event_to_button_action_assign(BSP_BOARD_BUTTON_0, BSP_BUTTON_ACTION_LONG_PUSH, BT0_LONG_PUSH);
        /*err_code = bsp_btn_ble_init(NULL, &startup_event);
        *p_erase_bonds = (startup_event == BSP_EVENT_CLEAR_BONDING_DATA);*/
    static void log_init(void)
        UNUSED_RETURN_VALUE(NRF_LOG_PROCESS());
        nrf_pwr_mgmt_run();
    #if USE_BSP == 0
    #define PIN_0 0
    APP_TIMER_DEF(m_button_action);
    #define BUTTON_STATE_POLL_INTERVAL_MS  100UL
    #define LONG_PRESS(MS)    (uint32_t)(MS)/BUTTON_STATE_POLL_INTERVAL_MS
    void button_timeout_handler(void * p_context)
         uint32_t err_code;
         static uint32_t cnt;
         if (app_button_is_pushed(0))
             cnt++;
             if ( cnt >= LONG_PRESS(10000))
                 cnt = 0;
                 NRF_LOG_INFO("Long Button press");
                  err_code = app_timer_start(m_button_action,
                                             APP_TIMER_TICKS(BUTTON_STATE_POLL_INTERVAL_MS),
                                             NULL);
              cnt = 0; // reset counter variable
    void button_callback(uint8_t pin_no, uint8_t button_action)
          uint32_t err_code;
          if ((pin_no == BUTTON_1) && (button_action == APP_BUTTON_PUSH))
                                         NULL);
    static void buttons_init()
          uint32_t err_code;
          static app_button_cfg_t  button_cfg;
          button_cfg.pin_no         = BUTTON_1;
          button_cfg.button_handler = button_callback;
          button_cfg.pull_cfg       = NRF_GPIO_PIN_PULLUP;
          button_cfg.active_state   = APP_BUTTON_ACTIVE_LOW;
          err_code = app_button_init(&button_cfg, 1, 100);
          err_code = app_button_enable();
          /*Enable an app timer instance to detect long button press*/
          err_code = app_timer_create(&m_button_action, APP_TIMER_MODE_SINGLE_SHOT, button_timeout_handler);
    #endif //USE_BSP
    /**@brief Application main function.
        bool erase_bonds;
        // Initialize.
        uart_init();
        log_init();
        timers_init();
    #if USE_BSP == 0
        buttons_init();
    #else
        power_management_init();
        ble_stack_init();
        gap_params_init();
        gatt_init();
        services_init();
        advertising_init();
        conn_params_init();
        // Start execution.
        advertising_start();
        // Enter main loop.
        for (;;)
            idle_state_handle();
    Edit: Forgot to clear the counter variable in the button timeout handler. Have updated the code above.
    Thanks for the quick response! Unfortunately I have not set up RTT or the NRF_LOG so I have been using the LEDs and  DMM to see if my program is working (the function calls to toggle the LEDs were placed where the NRF_LOG_INFO() functions were). I was able to get a long push and short push event with the BSP library, but the long push event appears to be called twice as the LED turns on with the short push event and then off after a second of being held down. I read on another thread that this issue can be resolved by using a push_release event, could you explain how to correct the long press being called twice? As far as the button handling library goes, I wasn't able to see any effects, however I noticed that without BSP, buttons_init() is used instead of buttons_leds_init(), could this be why I never saw any changes?
    Because my program currently uses the BSP library, and it seem to be the library I have made more progress on, I am not as concerned with troubleshooting the use of the button handling library.
    thanks again
    Could you try the button handling library again? It should work if you comment out the function that initializes BSP and use buttons_init() instead. I get the same problem as you did with BSP, and don't see any easy way to fix that.
  • Hi please can you explain how you were able to get  a double press effect? If possible can you share your code ?
    Thanks
    Regards
    Joseph Ayuk
  • Hi Joseph
    To get a double press effect I created a 1 second timer that would be started when the button is pressed. The button also added 1 to a counter whenever it was pressed. When the timer timed out, a series of if-else statements were used to compare the value of the counter to decide which action to execute. An additional case switch was used within one of the if-else statements to allow for a list of options to select. Below is the code in the timeout handler and the bsp_event_handler() used by the double press. There are a few more steps to implements a timer, but this is done like any other timer.
    Hope this helps,
    Jack
