TWI hanlder is not called
I use Twi for reading data from the lsm sensors. I want to use a twi_handler in which I will set the xfer_done_flag on the true and go off into a sleep mode until the flag is set to a false so that the sensors can successfully read the data. But the problem is that the TWI handler is not called. The problem is exactly in the software, as the example twi_sensor from sdk works.
twi initialization:
void twi_init(void) {
  const nrf_drv_twi_config_t twi_lsm330dlc_config = {
      .scl = SCL_,
      .sda = SDA_,
      .frequency = NRF_TWI_FREQ_400K,
      .interrupt_priority = APP_IRQ_PRIORITY_LOWEST,
      .clear_bus_init = true};
  ret_code_t error = nrf_drv_twi_init(&m_twi, &twi_lsm330dlc_config, twi_handler, NULL);
  APP_ERROR_CHECK(error);
  nrf_drv_twi_enable(&m_twi);
TWI handler:
void twi_handler(nrf_drv_twi_evt_t const * p_event, void * p_context)
    switch (p_event->type)
        case NRF_DRV_TWI_EVT_DONE:
            if (p_event->xfer_desc.type == NRF_DRV_TWI_XFER_RX)
                data_handler(m_sample);
            m_xfer_done = true;
sdk_config.h twi settings:
// <e> TWI_ENABLED - nrf_drv_twi - TWI/TWIM peripheral driver
#ifndef TWI_ENABLED
#define TWI_ENABLED 1
// <o> TWI_DEFAULT_CONFIG_FREQUENCY  - Frequency
// <26738688=> 100k
// <67108864=> 250k
// <104857600=> 400k
#ifndef TWI_DEFAULT_CONFIG_FREQUENCY
#define TWI_DEFAULT_CONFIG_FREQUENCY 104857600
// <q> TWI_DEFAULT_CONFIG_CLR_BUS_INIT  - Enables bus clearing procedure during init
#ifndef TWI_DEFAULT_CONFIG_CLR_BUS_INIT
#define TWI_DEFAULT_CONFIG_CLR_BUS_INIT 0
// <q> TWI_DEFAULT_CONFIG_HOLD_BUS_UNINIT  - Enables bus holding after uninit
#ifndef TWI_DEFAULT_CONFIG_HOLD_BUS_UNINIT
#define TWI_DEFAULT_CONFIG_HOLD_BUS_UNINIT 0
// <o> TWI_DEFAULT_CONFIG_IRQ_PRIORITY  - Interrupt priority
// <i> Priorities 0,2 (nRF51) and 0,1,4,5 (nRF52) are reserved for SoftDevice
// <0=> 0 (highest)
// <1=> 1
// <2=> 2
// <3=> 3
// <4=> 4
// <5=> 5
// <6=> 6
// <7=> 7
#ifndef TWI_DEFAULT_CONFIG_IRQ_PRIORITY
#define TWI_DEFAULT_CONFIG_IRQ_PRIORITY 7
// <e> TWI0_ENABLED - Enable TWI0 instance
#ifndef TWI0_ENABLED
#define TWI0_ENABLED 1
// <q> TWI0_USE_EASY_DMA  - Use EasyDMA (if present)
#ifndef TWI0_USE_EASY_DMA
#define TWI0_USE_EASY_DMA 1
// </e>
// <e> TWI1_ENABLED - Enable TWI1 instance
#ifndef TWI1_ENABLED
#define TWI1_ENABLED 0
// <q> TWI1_USE_EASY_DMA  - Use EasyDMA (if present)
#ifndef TWI1_USE_EASY_DMA
#define TWI1_USE_EASY_DMA 0
// </e>
// <q> TWIM_NRF52_ANOMALY_109_WORKAROUND_ENABLED  - Enables nRF52 anomaly 109 workaround for TWIM.
// <i> The workaround uses interrupts to wake up the CPU by catching
// <i> the start event of zero-frequency transmission, clear the
// <i> peripheral, set desired frequency, start the peripheral, and
// <i> the proper transmission. See more in the Errata document or
// <i> Anomaly 109 Addendum located at https://infocenter.nordicsemi.com/
#ifndef TWIM_NRF52_ANOMALY_109_WORKAROUND_ENABLED
#define TWIM_NRF52_ANOMALY_109_WORKAROUND_ENABLED 0
