I'm having a weird issue that I don't really understand.
I am currently replacing an old timer-based time-keeping implementation for a new RTC-based implementation.
After changing the lowering the frequency of the RTC from 1024 to 32 Hz, the program started getting "stuck" on boot. If I halt the program with JLink I can see that the IPSR is set to 00B (DebugMonitor). If I resume the program again with the run command in JLink, it runs fine, and if I halt it again the IPSR is set to 000 (NoException).
However, if I halt the program once more, I always get a HardFaultMemManage in the ISPR.
Why could the DebugMonitor thing be stopping my program?
EDIT:
I found the cause of my problem not to be the RTC frequency, but another piece of my code that's dependent on the RTC clock.
I have a function that's called like this: while(stm_reset() != NRF_SUCCESS);.
This function basically resets a second STM processor in the same board when the NRF52 boots. That function pulls down the reset pin in the STM, waits 1 ms and pulls it back up. The way I check the time is by using a global timekeeping module that keeps track of the ms passed since boot. Before, I had the timekeeping module running on the app_simple_timer module ticking once every millisecond. Now with the RTC, the module "ticks" every 31.25 ms and I increase the global ms variable accordingly.
When I had the simple timer-based module running at 1 KHz I never had any problems whatsoever. Now I get that DebugMonitor problem. Any ideas?
Btw, if I comment out the reset while loop, everything works fine.
Below is the code for the stm_reset() function for reference.
ret_code_t stm_reset() {
static uint32_t reset_timestamp = 0;
if (reset_timestamp == 0) {
// Pull the reset pin down, should generate a reset in the STM
nrf_gpio_pin_write(pins.stm.reset, 0);
reset_timestamp = clock_get_ms();
// The STM needs a reset pulse of at least 20 us, we wait ~1 ms
if (clock_get_ms_since(reset_timestamp) > 1) {
// Pull the reset pin up, should finalize the reset sequence
nrf_gpio_pin_write(pins.stm.reset, 1);
// Reset the time for a future reset
return NRF_SUCCESS;
} else {
return NRF_ERROR_BUSY;
