Hi
I want to generate two PWM signals that are phase shifted with 90 degree, with similar duty cycle. I have the following pwm configuration, but I don't know how to proceed further. I would be more than happy if someone could give me some help. I would appreciate if someone could send me a link to an example, if exists.
nrf_drv_pwm_config_t const pwm_cfg =
.output_pins =
9, // channel 0
10, // channel 1
NRF_DRV_PWM_PIN_NOT_USED, // channel 2
NRF_DRV_PWM_PIN_NOT_USED, // channel 3
.irq_priority = APP_IRQ_PRIORITY_LOWEST,
.base_clock = NRF_PWM_CLK_1MHz,
.count_mode = NRF_PWM_MODE_UP,
.top_value = 100,
.load_mode = NRF_PWM_LOAD_INDIVIDUAL,
.step_mode = NRF_PWM_STEP_AUTO
APP_ERROR_CHECK(nrf_drv_pwm_init(&m_pwm0, &pwm_cfg, NULL));
// This array cannot be allocated on stack (hence "static") and it must
// be in RAM (hence no "const", though its content is not changed).
static nrf_pwm_values_individual_t seq_values[] = {25, 25, 0, 0};
nrf_pwm_sequence_t const seq =
.values.p_individual = seq_values,
.length = NRF_PWM_VALUES_LENGTH(seq_values),
.repeats = 0,
.end_delay = 0
nrf_drv_pwm_simple_playback(&m_pwm0, &seq, 5, NRF_DRV_PWM_FLAG_STOP);
p.s I am using sdk.v14
Thanks in advance
