AT Command interface hangs
without providing too much code right away, I would like to ask how I could circumvent AT command interface hangups. My current test application calls AT commands like
static const char cereg[] = "AT+CEREG?";
static const char cesq[] = "AT+CESQ";
static const char vbat[] = "AT%XVBAT";
I just modified lte_lc. for this
in the main loop with an interval of 10s by calling k_sleep(K_MSEC(10000)); in between. So the commands are sent to the modem via the socket, the results are received and evaluated and then sent to our cloud via UDP. Between each command passed to the modem lie 10 seconds.
What I would like to know is how I can prevent the AT command interface hangup, and if it happens anyway how can I reset the modem separately from the Cortex-M33.
Typically I can go through the above sequence 4 times and then the AT Command interface hangs. This is not acceptable, so I have to find a way to prevent this from happening.
Best Regards,
KT
  • Hi ,
    Could you share the changes that you've made in lte_lc.c/h and how you call the functions?
    It would also be good to know which versions of the SDK your working on, for example the latest commits of the -zephyr and -nrf repositories in particular, along with modem version. That way others can replicate what your setup and possibly provide better help.
    Jan Tore
  • Well the tags are:
    \zephyr>git log
    commit 82fe1f9dfcf0e100d6fc952c07cf63d63aa08a0e (HEAD, tag: v1.13.99-ncs2-rc2, tag: v1.13.99-ncs2)
    \nrf>git log
    commit 5ad94691363cb0832943d8cb759df7db982a2e63 (HEAD, tag: v0.3.0)
    \nrfxlib>git log
    commit 891c089577857d8a197b7360e007a0d84e6dbe54 (HEAD, tag: v0.3.0)
    any newer versions would be great to have, I just went through the Getting Started App for this.
    The modem firmware is:
    mfw_nb1_nrf9160_0.3.0-73.prealpha.zip
    The main change to lte_lc.c is:
    static int at_cmd_wret(int fd, const char *cmd, size_t size, char * const ret)
        int len;
        uint32_t retCount = 0;
        int fnc_return;
        u8_t buffer[LC_MAX_READ_LENGTH];
        char *pLine[2] =
        { NULL, NULL };
        LOG_DBG("send: %s", cmd);
        len = send(fd, cmd, size, 0);
        if (len != size)
            LOG_ERR("send: failed");
            return -EIO;
        len = recv(fd, buffer, LC_MAX_READ_LENGTH, 0);
        memset(ret,0,LC_MAX_READ_LENGTH);
        do
            if (len < AT_CMD_SIZE(success))
                LOG_ERR("recv: %s", buffer);
                fnc_return = -EIO;
                pLine[0] = buffer;
                pLine[1] = memchr(buffer, '\n', LC_MAX_READ_LENGTH);
                pLine[1][0]='\0';
                pLine[1]++;
                if (memcmp(success, &pLine[1][0], AT_CMD_SIZE(success)) == 0)
                    memmove(ret, pLine[0], strlen(pLine[0]));
                    fnc_return = 0L;
                    fnc_return = -EIO;
            printk("rx1: %s\n", pLine[0]);
            printk("rx2: %s\n", pLine[1]);
            printk("rx3: %s\n", ret);
            retCount++;
        while (retCount < 1U);
        return fnc_return;
    and to give an example of using this function:
    int exl_lte_lc_get_cereg(exl_lte_lc_cereg_t * const pCereg)
        int errVal;
        int at_socket_fd;
        at_socket_fd = socket(AF_LTE, 0, NPROTO_AT);
        if (at_socket_fd == -1)
            return -EFAULT;
        errVal = at_cmd_wret(at_socket_fd, cereg, AT_CMD_SIZE(cereg), buffer);
        if (errVal == 0L)
            // "+CEREG: 2,5,\"C76A\",\"01ACB906\",9"
            sscanf(&buffer[8], "%u,%u,\"%[^\"]\",\"%[^\"]\",%u", (unsigned int *)&pCereg->n, (unsigned int *)&pCereg->stat, pCereg->tac,
                    pCereg->ci, (unsigned int *)&pCereg->act);
            return errVal;
        close(at_socket_fd);
        return 0;
    The main loop looks like the following:
        int32_t s;
        char imei[16];
        uint8_t stage = 0U;
        char dgram[256];
        int32_t Rsrp;
        uint32_t uptime;
        uint32_t vbat;
        exl_lte_lc_cereg_t Cereg;
        printk("Application started\n");
        memset(dgram,0,sizeof(dgram));
        memset(&Rsrp,0,sizeof(Rsrp));
        memset(&uptime,0,sizeof(uptime));
        memset(&vbat,0,sizeof(vbat));
        memset(&Cereg,0,sizeof(Cereg));
        memset(imei,0,sizeof(imei));
        buttons_leds_init();
        work_init();
        modem_configure();
        s = udp_connect();
        if (IS_ENABLED(CONFIG_CLOUD_UA_CONSOLE))
            console_init();
        // get imei
        exl_lte_lc_get_imei(imei);
        while (true)
            if (s >= 0L)
                uint32_t slen;
                uptime = (uint32_t)(k_uptime_get() / 1000L);
                switch (stage)
                case 0:
                    stage=0U;
                case 1:
                    exl_lte_lc_get_cereg(&Cereg);
                    stage=2U;
                case 2:
                    exl_lte_lc_get_cesq(&Rsrp);
                    stage=0U;
                case 3:
                    exl_lte_lc_get_vbat(&vbat);
                    stage=0U;
                    stage=0U;
                sprintf(dgram, "%s?b=[s=\"Test\",c=%s,tc=%s,r=%.1f,ti=\"%u\",a=%u]", imei, Cereg.ci, Cereg.tac,
                        (float)1.0f * Rsrp, (unsigned int)uptime, (unsigned int)((100 * vbat) / 5000U));
                printk("%s", dgram);
                slen = nrf_strnlen(dgram, sizeof(dgram));
                if (send(s, dgram, slen, 0L) != slen)
                    printk("partial/failed write\n");
                    printk("Sent %u Bytes\n", (unsigned int)slen);
            /* if logging is enabled, sleep */
        return 0L;
    Should  I change the approach in exl_lte_lc_* I'll go with the one used in at_client. For now I don't need to use AT_commands in the main loop.
    KT
    I've never seen that. It's really curious.
    It would be very useful for both others and me to see a repository or something with your codebase so that we can reproduce locally and get to the bottom of this.
    One thing you could try just to eliminate one thing, is to include a k_sleep(100) or k_sleep(10) in the bsd_os_timedwait function i mentioned earlier. That might help narrow things down a bit.
    BR,
    Jan Tore
  • And then there's also a possibility that your seeing this error:
    https://www.nordicsemi.com/DocLib/Content/Errata/nRF9160_EngA/latest/ERR/nRF9160/EngineeringA/latest/anomaly_160_17
    You can apply the workaround described in the document and see if that helps with your issues.
  • I'm working towards getting you access to the repository, I'll have to recreate the EEEEEEEEE code since I scrapped it. I also have another issue now where a socket fails after 15 mins with "Operation not supported on socket" and then hours later the nRF91 resets itself.
    The sleep fix has been in my code since you first mentioned it.
    KT
  • I think it would be good if you created a new, private ticket her on DevZone, for these more complex issues so that the support engineers can provide the best help and you can keep your code confidential.
