without providing too much code right away, I would like to ask how I could circumvent AT command interface hangups. My current test application calls AT commands like
static const char cereg[] = "AT+CEREG?";
static const char cesq[] = "AT+CESQ";
static const char vbat[] = "AT%XVBAT";
I just modified lte_lc. for this
in the main loop with an interval of 10s by calling k_sleep(K_MSEC(10000)); in between. So the commands are sent to the modem via the socket, the results are received and evaluated and then sent to our cloud via UDP. Between each command passed to the modem lie 10 seconds.
What I would like to know is how I can prevent the AT command interface hangup, and if it happens anyway how can I reset the modem separately from the Cortex-M33.
Typically I can go through the above sequence 4 times and then the AT Command interface hangs. This is not acceptable, so I have to find a way to prevent this from happening.
Best Regards,
KT
