Problem with ADC result.
So I'm using nrf52832 with sdk15.2 and I'm trying to connect a joystick to the adc pins and have the joystick to move the mouse instead of the buttons and having issues with that. I have successfully combined both SAADC and BLE_HIDS_MOUSE examples, created a global variables to store the adc values and used them to try changing the "case BSP_EVENT_KEY_1:" to them instead. first problem am having is that the "case" loop is not allowing an integer value to it so i tried a while loop and still am not able to see any changes in the mouse. So am not sure if I should change anything in the mouse_movement_send function or change anything in the hids_init function. I will attach the code.
So basically my problem is that am trying to have a joystick moving the mouse instead of buttons. and the joystick is connected to 4 ADC pins
 * Copyright (c) 2014 - 2018, Nordic Semiconductor ASA
 * All rights reserved.
/** @file
 * @defgroup ble_sdk_app_hids_mouse_main main.c
 * @ingroup ble_sdk_app_hids_mouse
 * @brief HID Mouse Sample Application main file.
 * This file contains is the source code for a sample application using the HID, Battery and Device
 * Information Service for implementing a simple mouse functionality. This application uses the
 * @ref app_scheduler.
 * Also it would accept pairing requests from any peer device. This implementation of the
 * application will not know whether a connected central is a known device or not.
#include <stdint.h>
#include <string.h>
#include "nordic_common.h"
#include "nrf.h"
#include "nrf_sdm.h"
#include "app_error.h"
#include "ble.h"
#include "ble_err.h"
#include "ble_hci.h"
#include "ble_srv_common.h"
#include "ble_advdata.h"
#include "ble_hids.h"
#include "ble_bas.h"
#include "ble_dis.h"
#include "ble_conn_params.h"
#include "sensorsim.h"
#include "bsp_btn_ble.h"
#include "app_scheduler.h"
#include "nrf_sdh.h"
#include "nrf_sdh_soc.h"
#include "nrf_sdh_ble.h"
#include "app_timer.h"
#include "peer_manager.h"
#include "ble_advertising.h"
#include "fds.h"
#include "ble_conn_state.h"
#include "nrf_ble_gatt.h"
#include "nrf_ble_qwr.h"
#include "nrf_pwr_mgmt.h"
#include "peer_manager_handler.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
// Added Headers
#include "nrf_drv_saadc.h"
#include "nrf_drv_ppi.h"
#include "nrf_drv_timer.h"
#include "boards.h"
#include "nrf_delay.h"
#include "nrf_gpio.h"
//#include "sdk_config.h"
#define SAMPLES_IN_BUFFER 4
// End of added headers
#define DEVICE_NAME                     "nRF5_Mouse"                                /**< Name of device. Will be included in the advertising data. */
#define MANUFACTURER_NAME               "NordicSemiconductor"                       /**< Manufacturer. Will be passed to Device Information Service. */
#define APP_BLE_OBSERVER_PRIO           3                                           /**< Application's BLE observer priority. You shouldn't need to modify this value. */
#define APP_BLE_CONN_CFG_TAG            1                                           /**< A tag identifying the SoftDevice BLE configuration. */
#define BATTERY_LEVEL_MEAS_INTERVAL     APP_TIMER_TICKS(2000)                       /**< Battery level measurement interval (ticks). */
#define MIN_BATTERY_LEVEL               81                                          /**< Minimum simulated battery level. */
#define MAX_BATTERY_LEVEL               100                                         /**< Maximum simulated battery level. */
#define BATTERY_LEVEL_INCREMENT         1                                           /**< Increment between each simulated battery level measurement. */
#define PNP_ID_VENDOR_ID_SOURCE         0x02                                        /**< Vendor ID Source. */
#define PNP_ID_VENDOR_ID                0x1915                                      /**< Vendor ID. */
#define PNP_ID_PRODUCT_ID               0xEEEE                                      /**< Product ID. */
#define PNP_ID_PRODUCT_VERSION          0x0001                                      /**< Product Version. */
/*lint -emacro(524, MIN_CONN_INTERVAL) // Loss of precision */
#define MIN_CONN_INTERVAL               MSEC_TO_UNITS(7.5, UNIT_1_25_MS)            /**< Minimum connection interval (7.5 ms). */
#define MAX_CONN_INTERVAL               MSEC_TO_UNITS(15, UNIT_1_25_MS)             /**< Maximum connection interval (15 ms). */
#define SLAVE_LATENCY                   20                                          /**< Slave latency. */
#define CONN_SUP_TIMEOUT                MSEC_TO_UNITS(3000, UNIT_10_MS)             /**< Connection supervisory timeout (3000 ms). */
#define FIRST_CONN_PARAMS_UPDATE_DELAY  APP_TIMER_TICKS(5000)                       /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
#define NEXT_CONN_PARAMS_UPDATE_DELAY   APP_TIMER_TICKS(30000)                      /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
#define MAX_CONN_PARAM_UPDATE_COUNT     3                                           /**< Number of attempts before giving up the connection parameter negotiation. */
#define SEC_PARAM_BOND                  1                                           /**< Perform bonding. */
#define SEC_PARAM_MITM                  0                                           /**< Man In The Middle protection not required. */
#define SEC_PARAM_LESC                  0                                           /**< LE Secure Connections not enabled. */
#define SEC_PARAM_KEYPRESS              0                                           /**< Keypress notifications not enabled. */
#define SEC_PARAM_IO_CAPABILITIES       BLE_GAP_IO_CAPS_NONE                        /**< No I/O capabilities. */
#define SEC_PARAM_OOB                   0                                           /**< Out Of Band data not available. */
#define SEC_PARAM_MIN_KEY_SIZE          7                                           /**< Minimum encryption key size. */
#define SEC_PARAM_MAX_KEY_SIZE          16                                          /**< Maximum encryption key size. */
#define SWIFT_PAIR_SUPPORTED            1                                           /**< Swift Pair feature is supported. */
#if SWIFT_PAIR_SUPPORTED == 1
#define MICROSOFT_VENDOR_ID             0x0006                                      /**< Microsoft Vendor ID.*/
#define MICROSOFT_BEACON_ID             0x03                                        /**< Microsoft Beacon ID, used to indicate that Swift Pair feature is supported. */
#define MICROSOFT_BEACON_SUB_SCENARIO   0x00                                        /**< Microsoft Beacon Sub Scenario, used to indicate how the peripheral will pair using Swift Pair feature. */
#define RESERVED_RSSI_BYTE              0x80                                        /**< Reserved RSSI byte, used to maintain forwards and backwards compatibility. */
#define MOVEMENT_SPEED                  5                                           /**< Number of pixels by which the cursor is moved each time a button is pushed. */
#define INPUT_REPORT_COUNT              3                                           /**< Number of input reports in this application. */
#define INPUT_REP_BUTTONS_LEN           3                                           /**< Length of Mouse Input Report containing button data. */
#define INPUT_REP_MOVEMENT_LEN          3                                           /**< Length of Mouse Input Report containing movement data. */
#define INPUT_REP_MEDIA_PLAYER_LEN      1                                           /**< Length of Mouse Input Report containing media player data. */
#define INPUT_REP_BUTTONS_INDEX         0                                           /**< Index of Mouse Input Report containing button data. */
#define INPUT_REP_MOVEMENT_INDEX        1                                           /**< Index of Mouse Input Report containing movement data. */
#define INPUT_REP_MPLAYER_INDEX         2                                           /**< Index of Mouse Input Report containing media player data. */
#define INPUT_REP_REF_BUTTONS_ID        1                                           /**< Id of reference to Mouse Input Report containing button data. */
#define INPUT_REP_REF_MOVEMENT_ID       2                                           /**< Id of reference to Mouse Input Report containing movement data. */
#define INPUT_REP_REF_MPLAYER_ID        3                                           /**< Id of reference to Mouse Input Report containing media player data. */
#define BASE_USB_HID_SPEC_VERSION       0x0101                                      /**< Version number of base USB HID Specification implemented by this application. */
#define SCHED_MAX_EVENT_DATA_SIZE       APP_TIMER_SCHED_EVENT_DATA_SIZE             /**< Maximum size of scheduler events. */
#ifdef SVCALL_AS_NORMAL_FUNCTION
#define SCHED_QUEUE_SIZE                20                                          /**< Maximum number of events in the scheduler queue. More is needed in case of Serialization. */
#else
#define SCHED_QUEUE_SIZE                10                                          /**< Maximum number of events in the scheduler queue. */
#define DEAD_BEEF                       0xDEADBEEF                                  /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
#define APP_ADV_FAST_INTERVAL           0x0028                                      /**< Fast advertising interval (in units of 0.625 ms. This value corresponds to 25 ms.). */
#define APP_ADV_SLOW_INTERVAL           0x00A0                                      /**< Slow advertising interval (in units of 0.625 ms. This value corresponds to 100 ms.). */
#define APP_ADV_FAST_DURATION           3000                                        /**< The advertising duration of fast advertising in units of 10 milliseconds. */
#define APP_ADV_SLOW_DURATION           18000                                       /**< The advertising duration of slow advertising in units of 10 milliseconds. */
//typedef int16_t nrf_saadc_value_t;  ///< Type of a single ADC conversion result. //MAYBE NOT NEEDED
APP_TIMER_DEF(m_battery_timer_id);                                                  /**< Battery timer. */
BLE_BAS_DEF(m_bas);        /**< Battery service instance. */
BLE_HIDS_DEF(m_hids,        /**< HID service instance. */
             NRF_SDH_BLE_TOTAL_LINK_COUNT,
             INPUT_REP_BUTTONS_LEN,
             INPUT_REP_MOVEMENT_LEN,
             INPUT_REP_MEDIA_PLAYER_LEN);
NRF_BLE_GATT_DEF(m_gatt);                                                           /**< GATT module instance. */
NRF_BLE_QWR_DEF(m_qwr);                                                             /**< Context for the Queued Write module.*/
BLE_ADVERTISING_DEF(m_advertising);                                                 /**< Advertising module instance. */
//---- added def
volatile uint8_t state = 1;
//static nrf_adc_value_t adc_buffer[ADC_BUFFER_SIZE];
static const nrf_drv_timer_t m_timer = NRF_DRV_TIMER_INSTANCE(1);
static nrf_saadc_value_t     m_buffer_pool[4][SAMPLES_IN_BUFFER];
static nrf_ppi_channel_t     m_ppi_channel;
static uint32_t              m_adc_evt_counter;
volatile uint32_t              ADC_North;
volatile uint32_t              ADC_South;
volatile uint32_t              ADC_West;
volatile uint32_t              ADC_East;
//---- end of added def
static bool              m_in_boot_mode = false;                                    /**< Current protocol mode. */
static uint16_t          m_conn_handle  = BLE_CONN_HANDLE_INVALID;                  /**< Handle of the current connection. */
static pm_peer_id_t      m_peer_id;                                                 /**< Device reference handle to the current bonded central. */
static sensorsim_cfg_t   m_battery_sim_cfg;                                         /**< Battery Level sensor simulator configuration. */
static sensorsim_state_t m_battery_sim_state;                                       /**< Battery Level sensor simulator state. */
static ble_uuid_t        m_adv_uuids[] =                                            /**< Universally unique service identifiers. */
    {BLE_UUID_HUMAN_INTERFACE_DEVICE_SERVICE, BLE_UUID_TYPE_BLE}
static uint8_t m_sp_payload[] =                                                     /**< Payload of advertising data structure for Microsoft Swift Pair feature. */
    MICROSOFT_BEACON_ID,
    MICROSOFT_BEACON_SUB_SCENARIO,
    RESERVED_RSSI_BYTE
static ble_advdata_manuf_data_t m_sp_manuf_advdata =                                /**< Advertising data structure for Microsoft Swift Pair feature. */
    .company_identifier = MICROSOFT_VENDOR_ID,
    .data               =
        .size   = sizeof(m_sp_payload),
        .p_data = &m_sp_payload[0]
static uint8_t            m_sp_enc_advdata[BLE_GAP_ADV_SET_DATA_SIZE_MAX];          /**< Advertising data buffer. */
static ble_gap_adv_data_t m_sp_advdata_buf =                                        /**< Advertising data buffer descriptor. */
    .adv_data =
        .p_data = m_sp_enc_advdata,
        .len    = sizeof(m_sp_enc_advdata)
static void on_hids_evt(ble_hids_t * p_hids, ble_hids_evt_t * p_evt);
/**@brief Callback function for asserts in the SoftDevice.
 * @param[in]   line_num   Line number of the failing ASSERT call.
 * @param[in]   file_name  File name of the failing ASSERT call.
/**@brief Function for setting filtered whitelist.
 * @param[in] skip  Filter passed to @ref pm_peer_id_list.
static void whitelist_set(pm_peer_id_list_skip_t skip)
    pm_peer_id_t peer_ids[BLE_GAP_WHITELIST_ADDR_MAX_COUNT];
    uint32_t     peer_id_count = BLE_GAP_WHITELIST_ADDR_MAX_COUNT;
    ret_code_t err_code = pm_peer_id_list(peer_ids, &peer_id_count, PM_PEER_ID_INVALID, skip);
    NRF_LOG_INFO("\tm_whitelist_peer_cnt %d, MAX_PEERS_WLIST %d",
                   peer_id_count + 1,
                   BLE_GAP_WHITELIST_ADDR_MAX_COUNT);
    err_code = pm_whitelist_set(peer_ids, peer_id_count);
/**@brief Function for setting filtered device identities.
static void identities_set(pm_peer_id_list_skip_t skip)
    pm_peer_id_t peer_ids[BLE_GAP_DEVICE_IDENTITIES_MAX_COUNT];
    uint32_t     peer_id_count = BLE_GAP_DEVICE_IDENTITIES_MAX_COUNT;
    err_code = pm_device_identities_list_set(peer_ids, peer_id_count);
/**@brief Clear bond information from persistent storage.
static void delete_bonds(void)
    ret_code_t err_code;
    NRF_LOG_INFO("Erase bonds!");
    err_code = pm_peers_delete();
static void advertising_start(bool erase_bonds)
    if (erase_bonds == true)
        delete_bonds();
        // Advertising is started by PM_EVT_PEERS_DELETE_SUCCEEDED event.
        whitelist_set(PM_PEER_ID_LIST_SKIP_NO_ID_ADDR);
        ret_code_t ret = ble_advertising_start(&m_advertising, BLE_ADV_MODE_FAST);
        APP_ERROR_CHECK(ret);
/**@brief Function for handling Peer Manager events.
 * @param[in] p_evt  Peer Manager event.
static void pm_evt_handler(pm_evt_t const * p_evt)
    pm_handler_on_pm_evt(p_evt);
    pm_handler_flash_clean(p_evt);
    switch (p_evt->evt_id)
            advertising_start(false);
        case PM_EVT_PEER_DATA_UPDATE_SUCCEEDED:
            if (     p_evt->params.peer_data_update_succeeded.flash_changed
                 && (p_evt->params.peer_data_update_succeeded.data_id == PM_PEER_DATA_ID_BONDING))
                NRF_LOG_INFO("New Bond, add the peer to the whitelist if possible");
                // Note: You should check on what kind of white list policy your application should use.
/**@brief Function for handling Service errors.
static void service_error_handler(uint32_t nrf_error)
    APP_ERROR_HANDLER(nrf_error);
/**@brief Function for handling advertising errors.
static void ble_advertising_error_handler(uint32_t nrf_error)
/**@brief Function for performing a battery measurement, and update the Battery Level characteristic in the Battery Service.
static void battery_level_update(void)
    uint8_t  battery_level;
    battery_level = (uint8_t)sensorsim_measure(&m_battery_sim_state, &m_battery_sim_cfg);
    err_code = ble_bas_battery_level_update(&m_bas, battery_level, BLE_CONN_HANDLE_ALL);
    if ((err_code != NRF_SUCCESS) &&
        (err_code != NRF_ERROR_BUSY) &&
        (err_code != NRF_ERROR_FORBIDDEN) &&
        (err_code != NRF_ERROR_INVALID_STATE) &&
        (err_code != BLE_ERROR_GATTS_SYS_ATTR_MISSING)
        APP_ERROR_HANDLER(err_code);
/**@brief Function for handling the Battery measurement timer timeout.
 * @details This function will be called each time the battery level measurement timer expires.
 * @param[in]   p_context   Pointer used for passing some arbitrary information (context) from the
 *                          app_start_timer() call to the timeout handler.
static void battery_level_meas_timeout_handler(void * p_context)
    UNUSED_PARAMETER(p_context);
    battery_level_update();
/**@brief Function for the Timer initialization.
 * @details Initializes the timer module.
static void timers_init(void)
    err_code = app_timer_init();
    // Create battery timer.
    err_code = app_timer_create(&m_battery_timer_id,
                                APP_TIMER_MODE_REPEATED,
                                battery_level_meas_timeout_handler);
 * @details This function sets up all the necessary GAP (Generic Access Profile) parameters of the
 *          device including the device name, appearance, and the preferred connection parameters.
                                          (const uint8_t *)DEVICE_NAME,
                                          strlen(DEVICE_NAME));
    err_code = sd_ble_gap_appearance_set(BLE_APPEARANCE_HID_MOUSE);
/**@brief Function for initializing the GATT module.
static void gatt_init(void)
    ret_code_t err_code = nrf_ble_gatt_init(&m_gatt, NULL);
/**@brief Function for initializing the Queued Write Module.
static void qwr_init(void)
    nrf_ble_qwr_init_t qwr_init_obj = {0};
    qwr_init_obj.error_handler = nrf_qwr_error_handler;
    err_code = nrf_ble_qwr_init(&m_qwr, &qwr_init_obj);
/**@brief Function for initializing Device Information Service.
static void dis_init(void)
    ble_dis_init_t   dis_init_obj;
    ble_dis_pnp_id_t pnp_id;
    pnp_id.vendor_id_source = PNP_ID_VENDOR_ID_SOURCE;
    pnp_id.vendor_id        = PNP_ID_VENDOR_ID;
    pnp_id.product_id       = PNP_ID_PRODUCT_ID;
    pnp_id.product_version  = PNP_ID_PRODUCT_VERSION;
    memset(&dis_init_obj, 0, sizeof(dis_init_obj));
    ble_srv_ascii_to_utf8(&dis_init_obj.manufact_name_str, MANUFACTURER_NAME);
    dis_init_obj.p_pnp_id = &pnp_id;
    dis_init_obj.dis_char_rd_sec = SEC_JUST_WORKS;
    err_code = ble_dis_init(&dis_init_obj);
/**@brief Function for initializing Battery Service.
static void bas_init(void)
    ble_bas_init_t bas_init_obj;
    memset(&bas_init_obj, 0, sizeof(bas_init_obj));
    bas_init_obj.evt_handler          = NULL;
    bas_init_obj.support_notification = true;
    bas_init_obj.p_report_ref         = NULL;
    bas_init_obj.initial_batt_level   = 100;
    bas_init_obj.bl_rd_sec        = SEC_JUST_WORKS;
    bas_init_obj.bl_cccd_wr_sec   = SEC_JUST_WORKS;
    bas_init_obj.bl_report_rd_sec = SEC_JUST_WORKS;
    err_code = ble_bas_init(&m_bas, &bas_init_obj);
/**@brief Function for initializing HID Service.
static void hids_init(void)
    ble_hids_init_t           hids_init_obj;
    ble_hids_inp_rep_init_t * p_input_report;
    uint8_t                   hid_info_flags;
    static ble_hids_inp_rep_init_t inp_rep_array[INPUT_REPORT_COUNT];
    static uint8_t rep_map_data[] =
        0x05, 0x01, // Usage Page (Generic Desktop)
        0x09, 0x02, // Usage (Mouse)
        0xA1, 0x01, // Collection (Application)
        // Report ID 1: Mouse buttons + scroll/pan
        0x85, 0x01,       // Report Id 1
        0x09, 0x01,       // Usage (Pointer)
        0xA1, 0x00,       // Collection (Physical)
        0x95, 0x05,       // Report Count (3)
        0x75, 0x01,       // Report Size (1)
        0x05, 0x09,       // Usage Page (Buttons)
        0x19, 0x01,       // Usage Minimum (01)
        0x29, 0x05,       // Usage Maximum (05)
        0x15, 0x00,       // Logical Minimum (0)
        0x25, 0x01,       // Logical Maximum (1)
        0x81, 0x02,       // Input (Data, Variable, Absolute)
        0x95, 0x01,       // Report Count (1)
        0x75, 0x03,       // Report Size (3)
        0x81, 0x01,       // Input (Constant) for padding
        0x75, 0x08,       // Report Size (8)
        0x09, 0x38,       // Usage (Wheel)
        0x15, 0x81,       // Logical Minimum (-127)
        0x25, 0x7F,       // Logical Maximum (127)
        0x81, 0x06,       // Input (Data, Variable, Relative)
        0x05, 0x0C,       // Usage Page (Consumer)
        0x0A, 0x38, 0x02, // Usage (AC Pan)
        0x81, 0x06,       // Input (Data,Value,Relative,Bit Field)
        0xC0,             // End Collection (Physical)
        // Report ID 2: Mouse motion
        0x85, 0x02,       // Report Id 2
        0x75, 0x0C,       // Report Size (12)
        0x95, 0x02,       // Report Count (2)
        0x09, 0x30,       // Usage (X)
        0x09, 0x31,       // Usage (Y)
        0x16, 0x01, 0xF8, // Logical maximum (2047)
        0x26, 0xFF, 0x07, // Logical minimum (-2047)
        0xC0,             // End Collection (Application)
        // Report ID 3: Advanced buttons
        0x09, 0x01,       // Usage (Consumer Control)
        0x85, 0x03,       // Report Id (3)
        0x15, 0x00,       // Logical minimum (0)
        0x25, 0x01,       // Logical maximum (1)
        0x09, 0xCD,       // Usage (Play/Pause)
        0x0A, 0x83, 0x01, // Usage (AL Consumer Control Configuration)
        0x09, 0xB5,       // Usage (Scan Next Track)
        0x09, 0xB6,       // Usage (Scan Previous Track)
        0x09, 0xEA,       // Usage (Volume Down)
        0x09, 0xE9,       // Usage (Volume Up)
        0x0A, 0x25, 0x02, // Usage (AC Forward)
        0x0A, 0x24, 0x02, // Usage (AC Back)
        0xC0              // End Collection
    memset(inp_rep_array, 0, sizeof(inp_rep_array));
    // Initialize HID Service.
    p_input_report                      = &inp_rep_array[INPUT_REP_BUTTONS_INDEX];
    p_input_report->max_len             = INPUT_REP_BUTTONS_LEN;
    p_input_report->rep_ref.report_id   = INPUT_REP_REF_BUTTONS_ID;
    p_input_report->rep_ref.report_type = BLE_HIDS_REP_TYPE_INPUT;
    p_input_report->sec.cccd_wr = SEC_JUST_WORKS;
    p_input_report->sec.wr      = SEC_JUST_WORKS;
    p_input_report->sec.rd      = SEC_JUST_WORKS;
    p_input_report                      = &inp_rep_array[INPUT_REP_MOVEMENT_INDEX];
    p_input_report->max_len             = INPUT_REP_MOVEMENT_LEN;
    p_input_report->rep_ref.report_id   = INPUT_REP_REF_MOVEMENT_ID;
    p_input_report                      = &inp_rep_array[INPUT_REP_MPLAYER_INDEX];
    p_input_report->max_len             = INPUT_REP_MEDIA_PLAYER_LEN;
    p_input_report->rep_ref.report_id   = INPUT_REP_REF_MPLAYER_ID;
    hid_info_flags = HID_INFO_FLAG_REMOTE_WAKE_MSK | HID_INFO_FLAG_NORMALLY_CONNECTABLE_MSK;
    memset(&hids_init_obj, 0, sizeof(hids_init_obj));
    hids_init_obj.evt_handler                    = on_hids_evt;
    hids_init_obj.error_handler                  = service_error_handler;
    hids_init_obj.is_kb                          = false;
    hids_init_obj.is_mouse                       = true;
    hids_init_obj.inp_rep_count                  = INPUT_REPORT_COUNT;
    hids_init_obj.p_inp_rep_array                = inp_rep_array;
    hids_init_obj.outp_rep_count                 = 0;
    hids_init_obj.p_outp_rep_array               = NULL;
    hids_init_obj.feature_rep_count              = 0;
    hids_init_obj.p_feature_rep_array            = NULL;
    hids_init_obj.rep_map.data_len               = sizeof(rep_map_data);
    hids_init_obj.rep_map.p_data                 = rep_map_data;
    hids_init_obj.hid_information.bcd_hid        = BASE_USB_HID_SPEC_VERSION;
    hids_init_obj.hid_information.b_country_code = 0;
    hids_init_obj.hid_information.flags          = hid_info_flags;
    hids_init_obj.included_services_count        = 0;
    hids_init_obj.p_included_services_array      = NULL;
    hids_init_obj.rep_map.rd_sec         = SEC_JUST_WORKS;
    hids_init_obj.hid_information.rd_sec = SEC_JUST_WORKS;
    hids_init_obj.boot_mouse_inp_rep_sec.cccd_wr = SEC_JUST_WORKS;
    hids_init_obj.boot_mouse_inp_rep_sec.wr      = SEC_JUST_WORKS;
    hids_init_obj.boot_mouse_inp_rep_sec.rd      = SEC_JUST_WORKS;
    hids_init_obj.protocol_mode_rd_sec = SEC_JUST_WORKS;
    hids_init_obj.protocol_mode_wr_sec = SEC_JUST_WORKS;
    hids_init_obj.ctrl_point_wr_sec    = SEC_JUST_WORKS;
    err_code = ble_hids_init(&m_hids, &hids_init_obj);
    qwr_init();
    dis_init();
    bas_init();
    hids_init();
/**@brief Function for initializing the battery sensor simulator.
static void sensor_simulator_init(void)
    m_battery_sim_cfg.min          = MIN_BATTERY_LEVEL;
    m_battery_sim_cfg.max          = MAX_BATTERY_LEVEL;
    m_battery_sim_cfg.incr         = BATTERY_LEVEL_INCREMENT;
    m_battery_sim_cfg.start_at_max = true;
    sensorsim_init(&m_battery_sim_state, &m_battery_sim_cfg);
/**@brief Function for handling a Connection Parameters error.
    cp_init.max_conn_params_update_count   = MAX_CONN_PARAM_UPDATE_COUNT;
    cp_init.evt_handler                    = NULL;
/**@brief Function for starting timers.
static void timers_start(void)
    err_code = app_timer_start(m_battery_timer_id, BATTERY_LEVEL_MEAS_INTERVAL, NULL);
    // Prepare wakeup buttons.
/**@brief Function for handling HID events.
 * @details This function will be called for all HID events which are passed to the application.
 * @param[in]   p_hids  HID service structure.
 * @param[in]   p_evt   Event received from the HID service.
    switch (p_evt->evt_type)
        case BLE_HIDS_EVT_BOOT_MODE_ENTERED:
            m_in_boot_mode = true;
        case BLE_HIDS_EVT_REPORT_MODE_ENTERED:
        case BLE_HIDS_EVT_NOTIF_ENABLED:
            // No implementation needed.
    switch (ble_adv_evt)
        case BLE_ADV_EVT_DIRECTED_HIGH_DUTY:
            NRF_LOG_INFO("Directed advertising.");
            err_code = bsp_indication_set(BSP_INDICATE_ADVERTISING_DIRECTED);
        case BLE_ADV_EVT_FAST:
            NRF_LOG_INFO("Fast advertising.");
            err_code = ble_advertising_advdata_update(&m_advertising, &m_sp_advdata_buf, false);
        case BLE_ADV_EVT_SLOW:
            NRF_LOG_INFO("Slow advertising.");
            err_code = bsp_indication_set(BSP_INDICATE_ADVERTISING_SLOW);
        case BLE_ADV_EVT_FAST_WHITELIST:
            NRF_LOG_INFO("Fast advertising with whitelist.");
            err_code = bsp_indication_set(BSP_INDICATE_ADVERTISING_WHITELIST);
        case BLE_ADV_EVT_SLOW_WHITELIST:
            NRF_LOG_INFO("Slow advertising with whitelist.");
        case BLE_ADV_EVT_IDLE:
            sleep_mode_enter();
        case BLE_ADV_EVT_WHITELIST_REQUEST:
            ble_gap_addr_t whitelist_addrs[BLE_GAP_WHITELIST_ADDR_MAX_COUNT];
            ble_gap_irk_t  whitelist_irks[BLE_GAP_WHITELIST_ADDR_MAX_COUNT];
            uint32_t       addr_cnt = BLE_GAP_WHITELIST_ADDR_MAX_COUNT;
            uint32_t       irk_cnt  = BLE_GAP_WHITELIST_ADDR_MAX_COUNT;
            err_code = pm_whitelist_get(whitelist_addrs, &addr_cnt,
                                        whitelist_irks,  &irk_cnt);
            NRF_LOG_DEBUG("pm_whitelist_get returns %d addr in whitelist and %d irk whitelist",
                           addr_cnt,
                           irk_cnt);
            // Set the correct identities list (no excluding peers with no Central Address Resolution).
            identities_set(PM_PEER_ID_LIST_SKIP_NO_IRK);
            // Apply the whitelist.
            err_code = ble_advertising_whitelist_reply(&m_advertising,
                                                       whitelist_addrs,
                                                       addr_cnt,
                                                       whitelist_irks,
                                                       irk_cnt);
        case BLE_ADV_EVT_PEER_ADDR_REQUEST:
            pm_peer_data_bonding_t peer_bonding_data;
            // Only Give peer address if we have a handle to the bonded peer.
            if (m_peer_id != PM_PEER_ID_INVALID)
                err_code = pm_peer_data_bonding_load(m_peer_id, &peer_bonding_data);
                if (err_code != NRF_ERROR_NOT_FOUND)
                    // Manipulate identities to exclude peers with no Central Address Resolution.
                    identities_set(PM_PEER_ID_LIST_SKIP_ALL);
                    ble_gap_addr_t * p_peer_addr = &(peer_bonding_data.peer_ble_id.id_addr_info);
                    err_code = ble_advertising_peer_addr_reply(&m_advertising, p_peer_addr);
        case BLE_GAP_EVT_CONNECTED:
            NRF_LOG_INFO("Connected");
            NRF_LOG_INFO("Disconnected");
            ble_gap_phys_t const phys =
                .rx_phys = BLE_GAP_PHY_AUTO,
                .tx_phys = BLE_GAP_PHY_AUTO,
        } break;
        case BLE_GATTC_EVT_TIMEOUT:
        case BLE_GATTS_EVT_TIMEOUT:
    uint32_t ram_start = 0;
    // Enable BLE stack.
/**@brief Function for the Peer Manager initialization.
static void peer_manager_init(void)
    err_code = pm_init();
    sec_param.bond           = SEC_PARAM_BOND;
    sec_param.mitm           = SEC_PARAM_MITM;
    sec_param.lesc           = SEC_PARAM_LESC;
    sec_param.keypress       = SEC_PARAM_KEYPRESS;
    sec_param.io_caps        = SEC_PARAM_IO_CAPABILITIES;
    sec_param.oob            = SEC_PARAM_OOB;
    sec_param.min_key_size   = SEC_PARAM_MIN_KEY_SIZE;
    sec_param.max_key_size   = SEC_PARAM_MAX_KEY_SIZE;
    sec_param.kdist_own.enc  = 1;
    sec_param.kdist_own.id   = 1;
    sec_param.kdist_peer.enc = 1;
    sec_param.kdist_peer.id  = 1;
/**@brief Function for encoding Swift Pair advertising data set, which should be used in Swift Pair
 *        mode.
 * @param[in]   p_new_advdata      Pointer to the structure which specifies content of encoded data.
 * @param[out]  p_new_advdata_buf  Pointer to the buffer where encoded data will be stored.
static void sp_advdata_prepare(ble_advdata_t const * const p_new_advdata,
                               ble_gap_adv_data_t  * const p_new_advdata_buf)
    ret_code_t ret = ble_advdata_encode(p_new_advdata,
                                        p_new_advdata_buf->adv_data.p_data,
                                        &p_new_advdata_buf->adv_data.len);
    if (p_new_advdata_buf->scan_rsp_data.p_data != NULL)
                                 p_new_advdata_buf->scan_rsp_data.p_data,
                                 &p_new_advdata_buf->scan_rsp_data.len);
    uint8_t                adv_flags;
    ble_advertising_init_t init;
    adv_flags                            = BLE_GAP_ADV_FLAGS_LE_ONLY_LIMITED_DISC_MODE;
    init.advdata.name_type               = BLE_ADVDATA_FULL_NAME;
    init.advdata.include_appearance      = true;
    init.advdata.flags                   = adv_flags;
    init.advdata.uuids_complete.uuid_cnt = sizeof(m_adv_uuids) / sizeof(m_adv_uuids[0]);
    init.advdata.uuids_complete.p_uuids  = m_adv_uuids;
    init.config.ble_adv_whitelist_enabled          = true;
    init.config.ble_adv_directed_high_duty_enabled = true;
    init.config.ble_adv_directed_enabled           = false;
    init.config.ble_adv_directed_interval          = 0;
    init.config.ble_adv_directed_timeout           = 0;
    init.config.ble_adv_fast_enabled               = true;
    init.config.ble_adv_fast_interval              = APP_ADV_FAST_INTERVAL;
    init.config.ble_adv_fast_timeout               = APP_ADV_FAST_DURATION;
    init.config.ble_adv_slow_enabled               = true;
    init.config.ble_adv_slow_interval              = APP_ADV_SLOW_INTERVAL;
    init.config.ble_adv_slow_timeout               = APP_ADV_SLOW_DURATION;
    init.evt_handler   = on_adv_evt;
    init.error_handler = ble_advertising_error_handler;
    init.advdata.p_manuf_specific_data = &m_sp_manuf_advdata;
    sp_advdata_prepare(&init.advdata, &m_sp_advdata_buf);
/**@brief Function for the Event Scheduler initialization.
static void scheduler_init(void)
    APP_SCHED_INIT(SCHED_MAX_EVENT_DATA_SIZE, SCHED_QUEUE_SIZE);
/**@brief Function for sending a Mouse Movement.
 * @param[in]   x_delta   Horizontal movement.
 * @param[in]   y_delta   Vertical movement.
static void mouse_movement_send(int16_t x_delta, int16_t y_delta)
    if (m_in_boot_mode)
        x_delta = MIN(x_delta, 0x00ff);
        y_delta = MIN(y_delta, 0x00ff);
        err_code = ble_hids_boot_mouse_inp_rep_send(&m_hids,
                                                    0x00,
                                                    (int8_t)x_delta,
                                                    (int8_t)y_delta,
                                                    0,
                                                    NULL,
                                                    m_conn_handle);
        uint8_t buffer[INPUT_REP_MOVEMENT_LEN];
        APP_ERROR_CHECK_BOOL(INPUT_REP_MOVEMENT_LEN == 3);
        x_delta = MIN(x_delta, 0x0fff);
        y_delta = MIN(y_delta, 0x0fff);
        buffer[0] = x_delta & 0x00ff;
        buffer[1] = ((y_delta & 0x000f) << 4) | ((x_delta & 0x0f00) >> 8);
        buffer[2] = (y_delta & 0x0ff0) >> 4;
        err_code = ble_hids_inp_rep_send(&m_hids,
                                         INPUT_REP_MOVEMENT_INDEX,
                                         buffer,
                                         m_conn_handle);
/**@brief Function for handling events from the module.
 * @param[in]   event   Event generated by button press.
static void bsp_event_handler(bsp_event_t event)
    switch (event)
        case BSP_EVENT_SLEEP:
            sleep_mode_enter();
        case BSP_EVENT_DISCONNECT:
            err_code = sd_ble_gap_disconnect(m_conn_handle,
        case BSP_EVENT_WHITELIST_OFF:
            // Added stuff
            if (m_conn_handle != BLE_CONN_HANDLE_INVALID)
                mouse_movement_send(0, -MOVEMENT_SPEED);
         while  (ADC_North > 10)
                mouse_movement_send(-MOVEMENT_SPEED, 0);
         case  ADC_North > 1:
        case NRF_SAADC_INPUT_AIN5 < 3:
        case NRF_SAADC_INPUT_AIN6 < -3:
                mouse_movement_send(MOVEMENT_SPEED, 0);
        case NRF_SAADC_INPUT_AIN7 < -10:
                mouse_movement_send(0,MOVEMENT_SPEED);
            break;*/
//} // end of added stuff
        case BSP_EVENT_KEY_0:
        case BSP_EVENT_KEY_2:
        case BSP_EVENT_KEY_3:
                mouse_movement_send(0, MOVEMENT_SPEED);
    bsp_event_t startup_event;
    err_code = bsp_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS, bsp_event_handler);
static void log_init(void)
  // NRF_LOG_DEFAULT_BACKENDS_INIT();
    app_sched_execute();
        nrf_pwr_mgmt_run();
//--------------- added functions for adc -----------
void timer_handler(nrf_timer_event_t event_type, void * p_context)
    /* setup m_timer for compare event every 400ms */
    uint32_t ticks = nrf_drv_timer_ms_to_ticks(&m_timer, 400);
                                   NRF_TIMER_CC_CHANNEL0,
                                   ticks,
                                   NRF_TIMER_SHORT_COMPARE0_CLEAR_MASK,
                                   false);
    uint32_t timer_compare_event_addr = nrf_drv_timer_compare_event_address_get(&m_timer,
        NRF_TIMER_CC_CHANNEL0);
                                          timer_compare_event_addr,
                                          saadc_sample_task_addr);
        err_code = nrf_drv_saadc_buffer_convert(p_event->data.done.p_buffer, SAMPLES_IN_BUFFER);
        int i;
        NRF_LOG_INFO("ADC event number: %d", (int)m_adc_evt_counter);
        for (i = 0; i < SAMPLES_IN_BUFFER; i++)
            NRF_LOG_INFO("%d", p_event->data.done.p_buffer[i]);
        m_adc_evt_counter++;
        //added
        uint16_t adc_value;
        uint8_t value[SAMPLES_IN_BUFFER*2];
        // end of added
        ADC_North =  p_event->data.done.p_buffer[0];
        //Added stuff
         while (p_event->data.done.p_buffer[0] > 10)
        while (p_event->data.done.p_buffer[1] > 10)
        case p_event->data.done.p_buffer[2] > 10:
        case p_event->data.done.p_buffer[3] > 10:
            while (m_conn_handle != BLE_CONN_HANDLE_INVALID)
            if (p_event->data.done.p_buffer[0] > 1)
            if (p_event->data.done.p_buffer[1] > 1)
            if (p_event->data.done.p_buffer[2] > 1)
            if (p_event->data.done.p_buffer[3] > 1)
            // End of added stuff
            for (int i = 0; i < SAMPLES_IN_BUFFER; i++)
            printf("%d\r\n", p_event->data.done.p_buffer[i]);
            adc_value = p_event->data.done.p_buffer[i];
            value[i*2] = adc_value;
            value[(i*2)+1] = adc_value >> 8;
        int i;
        NRF_LOG_INFO("North: \t\t%d", adc_value);
        NRF_LOG_INFO("East:  \t\t%d", NRF_SAADC_INPUT_AIN5);
        NRF_LOG_INFO("South: \t\t%d", NRF_SAADC_INPUT_AIN6);
        NRF_LOG_INFO("West:  \t\t%d", NRF_SAADC_INPUT_AIN7);
        NRF_LOG_INFO("North: \t\t%d", ADC_North);
        NRF_LOG_INFO("East:  \t\t%d", p_event->data.done.p_buffer[1]);
        NRF_LOG_INFO("South: \t\t%d", p_event->data.done.p_buffer[2]);
        NRF_LOG_INFO("West:  \t\t%d", p_event->data.done.p_buffer[3]);
            NRF_LOG_INFO("North is: %d", p_event->data.done.p_buffer[i]);
        m_adc_evt_counter++;*/
void saadc_init(void)
    nrf_saadc_channel_config_t channel_config =
        NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(NRF_SAADC_INPUT_AIN4);
    err_code = nrf_drv_saadc_init(NULL, saadc_callback);
    err_code = nrf_drv_saadc_channel_init(0, &channel_config);
    channel_config.pin_p = NRF_SAADC_INPUT_AIN4;
    channel_config.pin_p = NRF_SAADC_INPUT_AIN5;
    err_code = nrf_drv_saadc_channel_init(1, &channel_config);
    channel_config.pin_p = NRF_SAADC_INPUT_AIN6;
    err_code = nrf_drv_saadc_channel_init(2, &channel_config);
     channel_config.pin_p = NRF_SAADC_INPUT_AIN7;
    err_code = nrf_drv_saadc_channel_init(3, &channel_config);
    err_code = nrf_drv_saadc_buffer_convert(m_buffer_pool[0], SAMPLES_IN_BUFFER);
 //   err_code = nrf_drv_saadc_buffer_convert(m_buffer_pool[1], SAMPLES_IN_BUFFER);
 //   APP_ERROR_CHECK(err_code);
    nrf_drv_saadc_config_t saadc_config = NRF_DRV_SAADC_DEFAULT_CONFIG;
    saadc_config.resolution = NRF_SAADC_RESOLUTION_12BIT;
    nrf_saadc_channel_config_t channel_0_config =
        NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(NRF_SAADC_INPUT_AIN0);
    channel_0_config.gain = NRF_SAADC_GAIN1_4;
    channel_0_config.reference = NRF_SAADC_REFERENCE_VDD4;
    nrf_saadc_channel_config_t channel_1_config =
        NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(NRF_SAADC_INPUT_AIN1);
    channel_1_config.gain = NRF_SAADC_GAIN1_4;
    channel_1_config.reference = NRF_SAADC_REFERENCE_VDD4;
    nrf_saadc_channel_config_t channel_2_config =
        NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(NRF_SAADC_INPUT_AIN2);
    channel_2_config.gain = NRF_SAADC_GAIN1_4;
    channel_2_config.reference = NRF_SAADC_REFERENCE_VDD4;
    nrf_saadc_channel_config_t channel_3_config =
        NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(NRF_SAADC_INPUT_AIN3);
    channel_3_config.gain = NRF_SAADC_GAIN1_4;
    channel_3_config.reference = NRF_SAADC_REFERENCE_VDD4;
    err_code = nrf_drv_saadc_init(&saadc_config, saadc_callback);
    err_code = nrf_drv_saadc_channel_init(0, &channel_0_config);
    err_code = nrf_drv_saadc_channel_init(1, &channel_1_config);
    err_code = nrf_drv_saadc_channel_init(2, &channel_2_config);
    err_code = nrf_drv_saadc_channel_init(3, &channel_3_config);
// -------------- end of added functions for adc ----
// ---------------- New GPIO Code --------------
nrf_gpio_cfg_output(13);// Set LED PIN pin as output
To set the pin to High , use
nrf_gpio_pin_set(13);
to set the pin to low, use
nrf_gpio_pin_clear(LED_PIN);
to toggle the pin use
nrf_gpio_pin_toggle(LED_PIN);
// ---------------- End of GPIO ----------------
/**@brief Function for application main entry.
//nrf_gpio_pin_set(pin_number); // new
//  nrf_gpio_cfg_output(12);
  nrf_gpio_cfg_output(12);// Set LED PIN pin as output
//To set the pin to High , use
nrf_gpio_pin_set(12);
    bool erase_bonds;
    uint32_t err_code = NRF_LOG_INIT(NULL);
    ret_code_t ret_code = nrf_pwr_mgmt_init();
    APP_ERROR_CHECK(ret_code);
    // Initialize.
    // --- New to main (from SAADC)---
   saadc_init();
    saadc_sampling_event_init();
  //  NRF_LOG_INFO("SAADC HAL simple example started.");
    log_init();
    timers_init();
    // saadc_init();
    power_management_init();
    ble_stack_init();
    scheduler_init();
    gap_params_init();
    gatt_init();
    advertising_init();
    services_init();
    sensor_simulator_init();
    conn_params_init();
    peer_manager_init();
// TEST
// END TEST
    // Start execution.
    NRF_LOG_INFO("HID Mouse example started.");
    timers_start();
    advertising_start(erase_bonds);
    // Enter main loop.
    for (;;)
        idle_state_handle();
    while (1)
        nrf_pwr_mgmt_run();
        NRF_LOG_FLUSH();
I'm using 'p_event->data.done.p_buffer[0], [1], [2], [3]' as the output of the adc and storing them in volatile integer 'ADC_North, west...', each direction is connected to a different adc pin and the values shows in the terminal (PuTTY) are correct to my need. I now want to have the mouse move in accordance to the joystick, by having conditions like of when the value of the ADC_North > 10 the mouse moves north. This is happening in 'bsp_event_handler' function.
Note: parts of the code are commented out for testing purposes.
    A few comments to your code. You may already be aware of this, but I want to check.
    This part in the end of your main() before the loop main-loop.
    // TEST
    // END TEST
    Will not do anything, because you probably haven't received any saadc callbacks yet, so your ADC_North is probably still 0.
    I see in your saadc callback function, you call the mouse_movement_send() function, and you don't use the global variables, ADC_North, west, ...
    Also, I see that you have two while loops in main. Reduce this to one.
    But can you try to do the following instead of your while loops in this function:
    as you already have. Skip all while loops and their content in this function.
    Then add the following in your main-loop (the one containing idle_state_handle(). The other one is never reached)
    for (;;)
        run_mouse();
    Then add this function something like this:
    static run_mouse(void)
        if(ADC_North > 10)
    If this doesn't work, I see that you don't check your return values. Try to print their values to see what they return.
    Edvin
  • It worked. your suggestion was the solution to my problem.
    Much appreciated Edvin,
