spi_master vs spi_master_5w?
Folks,
In the latest SDK (6.1) for the nRF51822 I see two versions of SPI master code in the Source folder and examples: with and without "5W" appended to the filename.
Looks like the 5W version has more features (and complexity) and is designed for "serialization", I.e., the ability to put to sleep and awaken a running device state. Is that the correct interpretation? Is the 5W version ready for use (or just an intermediate development version)?
In either case, the SDK 6.1 online docs seem confused as to version. I would appreciate some advice on which version to use and documentation on same.
Also, looks like the (non-5W version of the) SPI Master driver assumes chip select is active low. I have a device that's active high and I can modify your driver code, but would prefer not to do that. How about adding chip select high vs. low to the configuration params for the SPI open call?
Mike
