802.15.4 Packet Size
I've been testing 802.15.4 single PHY (no softdevice) and analyzing packets on a TI CC2531, just to check interoperability. Things seem to work well when the packet size is at most 29 bytes. When I increase the packet size to 30 or more, the packet reception is poor (maybe some packets get through, many get CRC errors). I had thought that the limitation was 127 bytes for the 802.15.4 standard.
In a way, 29 bytes makes sense: considering the first byte (not in the packet) is the length, then the two auto-generated CRC bytes as the footer, we get the magic number of 32 bytes. Is that what's going on, 32 bytes is the actual limit?
Ted
    Can you post the code you use on the nRF side? The specifications have defined a maximum payload of 127, but the radio on either of the ends could limit this number.
    Jørgen
  • OK, this is the code which I modify for experimenting on the nRF side.
    #include <stdbool.h>
    #include <stddef.h>
    #include <stdint.h>
    #include "nrf_802154.h"
    #include "boards.h"
    #include "nrf_delay.h"
    #include "IEEE802154.h"
    #define MAX_MESSAGE_SIZE 29
    #define CHANNEL 26
    #define PACKET_MAX_PAYLOAD 18
    typedef uint16_t mac_addr_t;
    struct motepacket {
      uint8_t length;
      uint16_t fcf;
      uint8_t data_seq_no;
      mac_addr_t pan;
      mac_addr_t dest;
      mac_addr_t src;
      uint8_t iframe;    // field for 6lowpan, is 0x3f for TinyOS
      uint8_t type;
      uint8_t data[PACKET_MAX_PAYLOAD];
      uint8_t fcs[2];    // will become CRC, don't count this in length.
    typedef struct motepacket motepacket_t;
    static volatile bool m_tx_in_progress;
    static volatile bool m_tx_done;
    uint8_t seqno = 0;
    uint8_t buffer[sizeof(motepacket_t)];
    motepacket_t * p = (motepacket_t *)buffer;
    //int main(int argc, char *argv[])
        bsp_board_led_invert(0);
        p->fcf = 0x0000;
        // the following FCF lines are copied
        p->fcf &= 1 << IEEE154_FCF_ACK_REQ;
        p->fcf |= ( ( IEEE154_TYPE_DATA << IEEE154_FCF_FRAME_TYPE )
                      |  ( 1 << IEEE154_FCF_INTRAPAN )
                      |  ( IEEE154_ADDR_SHORT << IEEE154_FCF_DEST_ADDR_MODE )
                      |  ( IEEE154_ADDR_SHORT << IEEE154_FCF_SRC_ADDR_MODE ) );
        p->data_seq_no = 0;
        p->pan = 0x22;     //
        p->dest = 0xFFFF;  //
        p->src = 99;       //
        p->iframe = 0x3f;  //
        p->type = 0x37;    //
        //p->length =  offsetof(motepacket_t,data) + PACKET_MAX_PAYLOAD - 1;
        p->length = 29;
        m_tx_in_progress = false;
        m_tx_done        = false;
        nrf_802154_init();
        nrf_802154_channel_set(CHANNEL);
        nrf_802154_receive();
        while (1)
            p->data_seq_no = seqno++;
            for (int i=0; i<PACKET_MAX_PAYLOAD; i++) p->data[i] = seqno+i;
            // if (m_tx_done)
            //     m_tx_in_progress = false;
            //     m_tx_done        = false;
            // if (!m_tx_in_progress)
                //tx_buffer_fill(message, sizeof(message));
                //m_tx_in_progress = nrf_802154_transmit(message, sizeof(message), true);
                m_tx_in_progress = nrf_802154_transmit_raw(buffer, true);
                if (m_tx_in_progress) {
                    bsp_board_led_invert(1);
            printf("sent msg\n");
            nrf_delay_ms(3000);
        return 0;
    void nrf_802154_transmitted(const uint8_t * p_frame, uint8_t * p_ack, uint8_t length, int8_t power, int8_t lqi)
        (void) p_frame;
        (void) length;
        (void) power;
        (void) lqi;
        m_tx_done = true;
                 bsp_board_led_invert(2);
        if (p_ack != NULL)
            //nrf_802154_buffer_free(p_ack);
            nrf_802154_buffer_free_raw(p_ack);
  • The parameter MAX_PACKET_SIZE is set to 127 by default in the nRF IEEE 802.15.4. Radio Driver, and this is set in the radio peripheral during init procedure.
    Is the nRF only transmitting, or also receiving? Is it reception on the TI side that is poor when payload is high? Could you provide a sniffer trace of what is happening on-air with larger payloads? You can use our 802.15.4 sniffer solution if you do not have specialized equipment for this.
  • I ran such an experiment earlier, but to be certain I will run another one later and post the code and results; if I recall correctly, the direction external 802.15.4 -> nRF was flawless for larger packet sizes. I also updated the code/experiment in the nRF -> cc2531 direction with a larger packet, shown below (this one implements the transmitted_raw callback, after I read the raw transmission is preferred now). Each transmit from the nRF does trigger the SFD event on the cc2531, so at least each start-of-frame is detected. Some percent of the larger packets are fully and correctly (passing CRC tests) received on the cc2531, perhaps around 25% or so.
    #include <stddef.h>
    #include <stdint.h>
    #include "boards.h"
    #define MAX_MESSAGE_SIZE 37
    #define CHANNEL 26
    #define PACKET_MAX_PAYLOAD 26
    struct motepacket {
      uint8_t length;
      uint16_t fcf;
      mac_addr_t pan;
      mac_addr_t dest;
      mac_addr_t src;
      uint8_t type;
    uint8_t seqno = 0;
        p->fcf = 0x0000;
        // the following FCF lines are copied from TinyOS CC2420 driver
        p->data_seq_no = 0;
        p->pan = 0x22;     // GROUP
        p->dest = 0xFFFF;  // BCAST_ADDR
        p->src = 99;       // ID of sender
        p->iframe = 0x3f;  // 6LowPan designator
        p->type = 0x37;    // (bogus for now, could have meaning later)
        // -1 for length, +2 for unknown reason - seems to sort of work,
        // perhaps because of the CRC bytes in the fcs?
        p->length =  offsetof(motepacket_t,data) + 2 + PACKET_MAX_PAYLOAD - 1;
        m_tx_done        = true;
        nrf_802154_init();
        while (1) {
    	if (!m_tx_done || m_tx_in_progress) {
    	  nrf_delay_ms(3000);
    	  continue;
            if (!m_tx_in_progress) {
        return 0;
    void nrf_802154_transmitted_raw(const uint8_t * p_frame, uint8_t * p_ack, int8_t power, uint8_t lqi) {
        (void) p_frame;
        (void) power;
        (void) lqi;
        m_tx_done = true;
        if (p_ack != NULL) {
  • I was unable to get the standard rx example to work, using the 802.15.4 git repo (https://github.com/NordicSemiconductor/nRF-IEEE-802.15.4-radio-driver) of  Tue Feb 12 2019 (c0114b43bb222f55c5d4b22d4d144210df4cb1cc). However I was able to run the rx example using an early version of the same repo, from commit d049e668a055d114f956fd389349cd3f16b99399, Date: Wed Nov 14 2018. Here is sample output below. Two packets are shown, one from the Nordix tx demo, the other from a cc2531 device, and the total packet length exceeds 32 - so I think this is working properly. I am uncertain why, with the newest version of the 802.15.4 driver, that the rx program does not work. I had to make some minimal changes in the Makefile due to changes in the stack, otherwise it seems the same.
    <info> app: Packet
    <info> app:  27 41 88 35 22 00 FF FF|'A.5"...
    <info> app:  01 00 3F 06 02 02 03 04|..?.....
    <info> app:  05 06 07 08 09 0A 0B 0C|........
    <info> app:  0D 0E 0F 10 11 12 13 14|........
    <info> app:  15 16 17 18 19 1A 41 00|......A.
    <info> app:  00 00 00 00            |....
    <info> app: Packet
    <info> app:  1D 41 98 31 32 33 34 35|.A.12345
    <info> app:  36 37 38 39 3A 3B 3C 3D|6789:;<=
    <info> app:  3E 3F 40 41 42 43 44 45|>?@ABCDE
    <info> app:  46 47 48 49 23 00 00 00|FGHI#...
    <info> app:  00 00 00 00 00 00 00 00|........
