Interrupt not Registering Using app_gpiote
I am having an issue with pin changes triggering interrupts using app_gpiote. I've set up app_gpiote to watch pin 30 and trigger an interrupt on low-to-high or high-to-low. I've followed the example code closely, but the pin change (up or down) does not cause the interrupt handler to start. I am certain the pin change is occurring because I am monitoring it with a logic analyzer. Here is my code.
    static void event_handler_int(uint32_t event_pins_low_to_high, uint32_t event_pins_high_to_low)
    {nrf_gpio_pin_toggle(LED_0);}
    static bool gpiote_init(void)
        uint32_t retval;
        nrf_gpio_cfg_output(LED_0);
        nrf_gpio_cfg_output(LED_1);
        APP_GPIOTE_INIT(APP_GPIOTE_MAX_USERS);
        retval = app_gpiote_user_register(&my_user_id,
                                1 << 30,
                                1 << 30,
                                event_handler_int);
       if(retval != NRF_SUCCESS)
	        return false;
       retval = app_gpiote_user_enable(my_user_id);
	       return false;
      return true;
The gpiote_init function returns true, so it seems that the various initialization calls to app_gpiote are functioning properly. Any idea what is going on here?
P.S. Apologies for the messed up code formatting, can't seem to figure out the issue with it...
