NRF52832 BLE Scan
Hi
Can I get some idea on which functions to make changes to in order to scan and report(for example on uart) the number of ble devices present in NRF52832 kit range.
I know ble central uart example does the scan, but I don't seem to forward with which functions to start off with.
I am using NRF52832 micro devkit with softdevice s132.
  • ble_central_c actuall main.c reply base don this code.
  • this data i want to print seprately in putty via serial bus/uart p0.06,p0.08 uart bus or finally i want data extention via modbus .. Also guide how to add header file as app_uart.h in ble_central_c or any guide related to uart. please specifiy my pin. aslso for code ,reply as soon as possible. Above mentioned my code...???????
  • output
    code
    main.c
    ble_app_blinky_c
    ////////////////////////////////// RFID READER V1.0.0 2024 //////////////////////////
    /* R&D EMBEDDED TEAM */
    /* RFID PROJECT */
    /* ACTIVE RFID & ACTIVE TAG */
    /* CENTRAL */
    /* EMPLOYEE ID 013 */
    #include <stdint.h>
    #include <stdio.h>
    #include <string.h>
    #include "nrf_sdh.h"
    #include "nrf_sdh_ble.h"
    #include "nrf_sdh_soc.h"
    #include "nrf_pwr_mgmt.h"
    #include "app_timer.h"
    #include "boards.h"
    #include "bsp.h"
    #include "bsp_btn_ble.h"
    #include "ble.h"
    #include "ble_hci.h"
    #include "ble_advertising.h"
    #include "ble_conn_params.h"
    #include "ble_db_discovery.h"
    #include "ble_lbs_c.h"
    #include "nrf_ble_gatt.h"
    #include "nrf_ble_scan.h"
    #include "nrf_log.h"
    #include "nrf_log_ctrl.h"
    #define CENTRAL_SCANNING_LED BSP_BOARD_LED_0 /**< Scanning LED will be on when the device is scanning. */
    #define CENTRAL_CONNECTED_LED BSP_BOARD_LED_1 /**< Connected LED will be on when the device is connected. */
    #define LEDBUTTON_LED BSP_BOARD_LED_2 /**< LED to indicate a change of state of the the Button characteristic on the peer. */
    #define SCAN_INTERVAL 0x00A0 /**< Determines scan interval in units of 0.625 millisecond. */
    #define SCAN_WINDOW 0x0050 /**< Determines scan window in units of 0.625 millisecond. */
    #define SCAN_DURATION 0x0000 /**< Timout when scanning. 0x0000 disables timeout. */
    #define MIN_CONNECTION_INTERVAL MSEC_TO_UNITS(7.5, UNIT_1_25_MS) /**< Determines minimum connection interval in milliseconds. */
    #define MAX_CONNECTION_INTERVAL MSEC_TO_UNITS(30, UNIT_1_25_MS) /**< Determines maximum connection interval in milliseconds. */
    #define SLAVE_LATENCY 0 /**< Determines slave latency in terms of connection events. */
    #define SUPERVISION_TIMEOUT MSEC_TO_UNITS(4000, UNIT_10_MS) /**< Determines supervision time-out in units of 10 milliseconds. */
    #define LEDBUTTON_BUTTON_PIN BSP_BUTTON_0 /**< Button that will write to the LED characteristic of the peer */
    #define BUTTON_DETECTION_DELAY APP_TIMER_TICKS(50) /**< Delay from a GPIOTE event until a button is reported as pushed (in number of timer ticks). */
    #define APP_BLE_CONN_CFG_TAG 1 /**< A tag identifying the SoftDevice BLE configuration. */
    #define APP_BLE_OBSERVER_PRIO 3 /**< Application's BLE observer priority. You shouldn't need to modify this value. */
    NRF_BLE_SCAN_DEF(m_scan); /**< Scanning module instance. */
    BLE_LBS_C_DEF(m_ble_lbs_c); /**< Main structure used by the LBS client module. */
    NRF_BLE_GATT_DEF(m_gatt); /**< GATT module instance. */
    BLE_DB_DISCOVERY_DEF(m_db_disc); /**< DB discovery module instance. */
    static char const m_target_periph_name[] = "(NORDIC)"; /**< Name of the device we try to connect to. This name is searched in the scan report data*/
    #define SCAN_LIST_REFRESH_INTERVAL 10000 // 100 sec
    static uint32_t device_number;
    #define FOUND_DEVICE_REFRESH_TIME APP_TIMER_TICKS(SCAN_LIST_REFRESH_INTERVAL) /**< Time after which the device list is clean and refreshed. */
    #define DEVICE_NAME_MAX_SIZE 20
    #define DEVICE_TO_FIND_MAX 50
    typedef struct
    bool is_not_empty; /**< Indicates that the structure is not empty. */
    uint16_t size; /**< Size of manuf data. */
    uint8_t addr[BLE_GAP_ADDR_LEN]; /**< Device address. */
    char dev_name[DEVICE_NAME_MAX_SIZE]; /**< Device name. */
    uint8_t data_buffer[BLE_GAP_ADV_SET_DATA_SIZE_MAX]; /**< Buffer for storing an manuf data. */
    uint8_t rssi ;
    } scanned_device_t;
    void device_list_print(scanned_device_t * p_device);
    scanned_device_t m_device[DEVICE_TO_FIND_MAX]; /**< Stores device info from scan data. */
    void scan_device_info_clear(void)
    memset(m_device, 0, sizeof(m_device));
    device_number = 0;
    /**@brief Function for printing the devices.
    *@details Function print list of devices.
    * @param[in] device Pointer to the struct storing the scanned devices.
    // We could now clear the list:
    scan_device_info_clear();
    scanned_device_t * scan_device_info_get(void)
    return m_device;
    typedef struct
    uint8_t * p_data; /**< Pointer to data. */
    uint16_t data_len; /**< Length of data. */
    } data_t;
    static void device_to_list_add(ble_gap_evt_adv_report_t const * p_adv_report)
    uint8_t idx = 0;
    uint16_t dev_name_offset = 0;
    uint16_t field_len;
    int i = 0;
    data_t adv_data;
    // Initialize advertisement report for parsing
    adv_data.p_data = (uint8_t *)p_adv_report->data.p_data;
    adv_data.data_len = p_adv_report->data.len;
    for ( idx = 0; idx < DEVICE_TO_FIND_MAX; idx++)
    // If address is duplicated, then return.
    if (memcmp(p_adv_report->peer_addr.addr,
    m_device[idx].addr,
    sizeof(p_adv_report->peer_addr.addr)) == 0)
    return;
    // Device is not in the list.
    for (idx = 0; idx < DEVICE_TO_FIND_MAX; idx++)
    if (!m_device[idx].is_not_empty) // We find an empty entry
    device_number = device_number +1;
    m_device[idx].is_not_empty = true; //validating the list record
    memset(m_device[idx].addr,
    0,
    sizeof(p_adv_report->peer_addr.addr));
    memcpy(m_device[idx].addr,
    //###=========================================ADVERTIZED DATA SCAN SUCCESSFUL =######=========================================================###//
    /*88888888888888888888888888888888888888888888888 NAME OF DEVICE IN LITERAL 888888888888888888888888888888888888888888888888888*/
    //////////////////////////////////////////////////// TOTAL NO OF DEVICE //////////////////////////////////////////////////////////////
    NRF_LOG_INFO("[TOTAL NUM].DEVS:%d Count\r\n",device_number);
    printf("[TOTAL NUM].DEVS:%d Count\r\n",device_number);
    m_device[idx].rssi = p_adv_report->rssi;
    printf("[SIGNAL ].RSSI:%d dBm\r\n",m_device[idx].rssi);
    ///////////////////////////////////////////// SIGNAL STRENGTH INDEX ////////////////////////////////////////////////////////////////////////
    /////////////////////////// APPLICATION RFID(CENTRAL) DETECTION DATA>> TAG(PHERIFERIAL) //////////////////////////////////////////////////////////////
    //uint8_t * full_name_data = ble_advdata_parse(m_device[idx].data_buffer, m_device[idx].size,BLE_GAP_AD_TYPE_COMPLETE_LOCAL_NAME);
    uint16_t len_full_name = ble_advdata_search(m_device[idx].data_buffer,m_device[idx].size, &dev_name_offset,BLE_GAP_AD_TYPE_COMPLETE_LOCAL_NAME);
    memset(m_device[idx].dev_name,
    0,
    len_full_name);
    memcpy(m_device[idx].dev_name,
    &m_device[idx].data_buffer[dev_name_offset],
    len_full_name);
    printf("[SIGNATURE].NAME:");
    for(i=0; i<len_full_name;i++)
    printf("%c",m_device[idx].data_buffer[dev_name_offset+i]);
    printf("\r\n");
    /*88888888888888888888888888888888888888888888888 NAME OF DEVICE IN HEX 88888888888888888888888888888888888888888888888*/
    printf("[HEX ID ].ADDR:");
    for(i=0; i< (uint16_t)(sizeof(p_adv_report->peer_addr.addr));i++)
    if(i==0)
    printf("%02X",m_device[idx].addr[i]);
    printf(":%02X",m_device[idx].addr[i]); //add colon in order to give format to address
    printf("\r\n");
    // ##### if you do not want to print adv data then comment #####////
    m_device[idx].size = p_adv_report->data.len;
    memset(m_device[idx].data_buffer,
    0,
    p_adv_report->data.len);
    memcpy(m_device[idx].data_buffer,
    p_adv_report->data.p_data,
    printf("[ADV DATA ].DATA:");
    for(i=0; i< p_adv_report->data.len;i++)
    printf("%x",m_device[idx].data_buffer[i]);
    printf("\r\n");
    /* DATA */
    uint8_t * aux = p_adv_report->data.p_data;
    uint16_t aux_len = p_adv_report->data.len;
    uint8_t aux_array[100] = {};
    memcpy(aux_array,aux,aux_len);
    printf("[ADV DATA ].DATA:%x\r\n",aux_array);
    return;
    app_error_handler(0xDEADBEEF, line_num, p_file_name);
    /**@brief Function for the LEDs initialization.
    * @details Initializes all LEDs used by the application.
    static void leds_init(void)
    /**@brief Function to start scanning.
    static void scan_start(void)
    ret_code_t err_code;
    err_code = nrf_ble_scan_start(&m_scan);
    bsp_board_led_off(CENTRAL_CONNECTED_LED);
    bsp_board_led_on(CENTRAL_SCANNING_LED);
    * @param[in] p_ble_evt Bluetooth stack event.
    * @param[in] p_context Unused.
    // For readability.
    ble_gap_evt_t const * p_gap_evt = &p_ble_evt->evt.gap_evt;
    // Upon connection, check which peripheral has connected (HR or RSC), initiate DB
    // discovery, update LEDs status and resume scanning if necessary. */
    case BLE_GAP_EVT_CONNECTED:
    NRF_LOG_INFO("Connected.");
    // err_code = ble_lbs_c_handles_assign(&m_ble_lbs_c, p_gap_evt->conn_handle, NULL);
    // APP_ERROR_CHECK(err_code);
    // err_code = ble_db_discovery_start(&m_db_disc, p_gap_evt->conn_handle);
    // Update LEDs status, and check if we should be looking for more
    // peripherals to connect to.
    bsp_board_led_on(CENTRAL_CONNECTED_LED);
    bsp_board_led_off(CENTRAL_SCANNING_LED);
    } break;
    // Upon disconnection, reset the connection handle of the peer which disconnected, update
    // the LEDs status and start scanning again.
    NRF_LOG_INFO("Disconnected.");
    scan_start();
    } break;
    case BLE_GAP_EVT_TIMEOUT:
    // We have not specified a timeout for scanning, so only connection attemps can timeout.
    if (p_gap_evt->params.timeout.src == BLE_GAP_TIMEOUT_SRC_CONN)
    NRF_LOG_DEBUG("Connection request timed out.");
    } break;
    case BLE_GAP_EVT_CONN_PARAM_UPDATE_REQUEST:
    // Accept parameters requested by peer.
    err_code = sd_ble_gap_conn_param_update(p_gap_evt->conn_handle,
    &p_gap_evt->params.conn_param_update_request.conn_params);
    } break;
    ble_gap_phys_t const phys =
    .rx_phys = BLE_GAP_PHY_AUTO,
    .tx_phys = BLE_GAP_PHY_AUTO,
    } break;
    case BLE_GATTC_EVT_TIMEOUT:
    } break;
    case BLE_GATTS_EVT_TIMEOUT:
    } break;
    // No implementation needed.
    * @details Initializes the SoftDevice and the BLE event interrupts.
    uint32_t ram_start = 0;
    // Enable BLE stack.
    /**@brief Function for handling events from the button handler module.
    * @param[in] pin_no The pin that the event applies to.
    * @param[in] button_action The button action (press/release).
    static void button_event_handler(uint8_t pin_no, uint8_t button_action)
    switch (pin_no)
    case LEDBUTTON_BUTTON_PIN:
    //APP_ERROR_HANDLER(pin_no);
    /**@brief Function for handling Scaning events.
    * @param[in] p_scan_evt Scanning event.
    static void scan_evt_handler(scan_evt_t const * p_scan_evt)
    switch(p_scan_evt->scan_evt_id)
    case NRF_BLE_SCAN_EVT_CONNECTING_ERROR:
    err_code = p_scan_evt->params.connecting_err.err_code;
    case NRF_BLE_SCAN_EVT_NOT_FOUND:
    device_to_list_add(p_scan_evt->params.p_not_found);
    /**@brief Function for initializing the button handler module.
    static void buttons_init(void)
    //The array must be static because a pointer to it will be saved in the button handler module.
    static app_button_cfg_t buttons[] =
    {LEDBUTTON_BUTTON_PIN, false, BUTTON_PULL, button_event_handler}
    err_code = app_button_init(buttons, ARRAY_SIZE(buttons),
    BUTTON_DETECTION_DELAY);
    /**@brief Function for initializing the log.
    static void log_init(void)
    /**@brief Function for handling the list_timer event,
    static void adv_list_timer_handle(void * p_context)
    // Print devices
    scanned_device_t * p_device_list = scan_device_info_get();
    device_list_print(p_device_list);
    //scan_device_info_clear();
    /**@brief Function for initializing the timer.
    static void timer_init(void)
    // Timer for refreshing scanned devices data.
    APP_TIMER_DEF(adv_list_timer);
    err_code = app_timer_create(&adv_list_timer, APP_TIMER_MODE_REPEATED, adv_list_timer_handle);
    err_code = app_timer_start(adv_list_timer, FOUND_DEVICE_REFRESH_TIME, NULL);
    /**@brief Function for initializing the Power manager. */
    static void scan_init(void)
    nrf_ble_scan_init_t init_scan;
    memset(&init_scan, 0, sizeof(init_scan));
    init_scan.connect_if_match = false;
    init_scan.conn_cfg_tag = APP_BLE_CONN_CFG_TAG;
    err_code = nrf_ble_scan_init(&m_scan, &init_scan, scan_evt_handler);
    // // Setting filters for scanning.
    // err_code = nrf_ble_scan_filters_enable(&m_scan, NRF_BLE_SCAN_NAME_FILTER, false);
    err_code = nrf_ble_scan_filter_set(&m_scan, SCAN_NAME_FILTER, m_target_periph_name);
    /**@brief Function for initializing the GATT module.
    static void gatt_init(void)
    ret_code_t err_code = nrf_ble_gatt_init(&m_gatt, NULL);
    * @details Handle any pending log operation(s), then sleep until the next event occurs.
    NRF_LOG_FLUSH();
    nrf_pwr_mgmt_run();
    // Initialize.
    log_init();
    timer_init();
    leds_init();
    buttons_init();
    power_management_init();
    ble_stack_init();
    scan_init();
    gatt_init();
    // Start execution.
    NRF_LOG_INFO("[[BLE [RFID V1.0.0] Scanner Started]] Total: %d seconds",SCAN_LIST_REFRESH_INTERVAL/1000);
    scan_start();
    // Turn on the LED to signal scanning.
    // Enter main loop.
    for (;;)
    idle_state_handle();
  • [#BASIC PROBLEM 1]: GUIDE  I NEED TO PRINT SAME OUTPUT IN PUTTY PLEASE REPLY //NORDIC NRF52832 DK BOARD SDK15.3.0           PCA10040V 3.0.0
    C:\nRF5_SDK_15.3.0_59ac345\examples\New folder\ble_app_blinky_c_SCANNER\pca10040\s132\ses
    DOING PROGRAMMING IN SEGGER EMBEDDED STUDIO PLATFORM
    REPLY TO SOVE MY #BASIC PROBLEM
    THANKS IN ADV..
  • ble_app_pheferal // how to advatize uuid and custom device name
    how to modify existing main.c code for tag /ibeacon [#basic problem 2]
    /* RFID PROJECT 20/04/2024 - V1.0.0 ACTIVE TAG
    * Copyright (c) 2014 - 2019, Nordic Semiconductor ASA
    * All rights reserved.
    /** @file
    * @defgroup ble_sdk_app_beacon_main main.c
    * @ingroup ble_sdk_app_beacon
    * @brief Beacon Transmitter Sample Application main file.
    * This file contains the source code for an Beacon transmitter sample application.
    #include <stdbool.h>
    #include <stdint.h>
    #include "nordic_common.h"
    #include "bsp.h"
    #include "nrf_soc.h"
    #include "ble_advdata.h"
    #define DEVICE_NAME "SIT-BEACON_1"
    #define NON_CONNECTABLE_ADV_INTERVAL MSEC_TO_UNITS(100, UNIT_0_625_MS) /**< The advertising interval for non-connectable advertisement (100 ms). This value can vary between 100ms to 10.24s). */
    #define APP_BEACON_INFO_LENGTH 0x17 /**< Total length of information advertised by the Beacon. */
    #define APP_ADV_DATA_LENGTH 0x15 /**< Length of manufacturer specific data in the advertisement. */
    #define APP_DEVICE_TYPE 0x02 /**< 0x02 refers to Beacon. */
    #define APP_MEASURED_RSSI 0xC3 /**< The Beacon's measured RSSI at 1 meter distance in dBm. */
    #define APP_COMPANY_IDENTIFIER 0x0059 /**< Company identifier for Nordic Semiconductor ASA. as per www.bluetooth.org. */
    #define APP_MAJOR_VALUE 0x01, 0x02 /**< Major value used to identify Beacons. */
    #define APP_MINOR_VALUE 0x03, 0x04 /**< Minor value used to identify Beacons. */
    //USER DEFINE >> UUID ONLINE GENERATOR>> 90edf9ce-5c1b-4b0c-8e15-872ea3ebcac7
    #define APP_BEACON_UUID 0x90, 0xed, 0xf9, 0xce, \
    0x5c, 0x1b, 0x4b, 0x0c, \
    0x8e, 0x15, 0x87, 0x2e, \
    0xa3, 0xeb, 0xca, 0xc7 /**< Proprietary UUID for Beacon. */
    #define DEAD_BEEF 0xDEADBEEF /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
    #if defined(USE_UICR_FOR_MAJ_MIN_VALUES)
    #define MAJ_VAL_OFFSET_IN_BEACON_INFO 18 /**< Position of the MSB of the Major Value in m_beacon_info array. */
    #define UICR_ADDRESS 0x10001080 /**< Address of the UICR register used by this example. The major and minor versions to be encoded into the advertising data will be picked up from this location. */
    static ble_gap_adv_params_t m_adv_params; /**< Parameters to be passed to the stack when starting advertising. */
    static uint8_t m_adv_handle = BLE_GAP_ADV_SET_HANDLE_NOT_SET; /**< Advertising handle used to identify an advertising set. */
    static uint8_t m_enc_advdata[BLE_GAP_ADV_SET_DATA_SIZE_MAX]; /**< Buffer for storing an encoded advertising set. */
    /**@brief Struct that contains pointers to the encoded advertising data. */
    static ble_gap_adv_data_t m_adv_data =
    .adv_data =
    .p_data = m_enc_advdata,
    .len = BLE_GAP_ADV_SET_DATA_SIZE_MAX
    .scan_rsp_data =
    .p_data = NULL,
    .len = 0
    static uint8_t m_beacon_info[APP_BEACON_INFO_LENGTH] = /**< Information advertised by the Beacon. */
    APP_DEVICE_TYPE, // Manufacturer specific information. Specifies the device type in this
    // implementation.
    APP_ADV_DATA_LENGTH, // Manufacturer specific information. Specifies the length of the
    // manufacturer specific data in this implementation.
    APP_BEACON_UUID, // 128 bit UUID value.
    APP_MAJOR_VALUE, // Major arbitrary value that can be used to distinguish between Beacons.
    APP_MINOR_VALUE, // Minor arbitrary value that can be used to distinguish between Beacons.
    APP_MEASURED_RSSI, // Manufacturer specific information. The Beacon's measured TX power in
    // this implementation.
    /**@brief Callback function for asserts in the SoftDevice.
    * how your product is supposed to react in case of Assert.
    * @param[in] line_num Line number of the failing ASSERT call.
    * @param[in] file_name File name of the failing ASSERT call.
    * @details Encodes the required advertising data and passes it to the stack.
    * Also builds a structure to be passed to the stack when starting advertising.
    uint32_t err_code;
    ble_advdata_t advdata;
    uint8_t flags = BLE_GAP_ADV_FLAG_BR_EDR_NOT_SUPPORTED;
    ble_advdata_manuf_data_t manuf_specific_data;
    manuf_specific_data.company_identifier = APP_COMPANY_IDENTIFIER;
    // If USE_UICR_FOR_MAJ_MIN_VALUES is defined, the major and minor values will be read from the
    // UICR instead of using the default values. The major and minor values obtained from the UICR
    // are encoded into advertising data in big endian order (MSB First).
    // To set the UICR used by this example to a desired value, write to the address 0x10001080
    // using the nrfjprog tool. The command to be used is as follows.
    // nrfjprog --snr <Segger-chip-Serial-Number> --memwr 0x10001080 --val <your major/minor value>
    // For example, for a major value and minor value of 0xabcd and 0x0102 respectively, the
    // the following command should be used.
    // nrfjprog --snr <Segger-chip-Serial-Number> --memwr 0x10001080 --val 0xabcd0102
    uint16_t major_value = ((*(uint32_t *)UICR_ADDRESS) & 0xFFFF0000) >> 16;
    uint16_t minor_value = ((*(uint32_t *)UICR_ADDRESS) & 0x0000FFFF);
    uint8_t index = MAJ_VAL_OFFSET_IN_BEACON_INFO;
    m_beacon_info[index++] = MSB_16(major_value);
    m_beacon_info[index++] = LSB_16(major_value);
    m_beacon_info[index++] = MSB_16(minor_value);
    m_beacon_info[index++] = LSB_16(minor_value);
    manuf_specific_data.data.p_data = (uint8_t *) m_beacon_info;
    manuf_specific_data.data.size = APP_BEACON_INFO_LENGTH;
    // Build and set advertising data.
    memset(&advdata, 0, sizeof(advdata));
    advdata.name_type = BLE_ADVDATA_NO_NAME;
    advdata.flags = flags;
    advdata.p_manuf_specific_data = &manuf_specific_data;
    // Initialize advertising parameters (used when starting advertising).
    memset(&m_adv_params, 0, sizeof(m_adv_params));
    m_adv_params.properties.type = BLE_GAP_ADV_TYPE_NONCONNECTABLE_NONSCANNABLE_UNDIRECTED;
    m_adv_params.p_peer_addr = NULL; // Undirected advertisement.
    m_adv_params.filter_policy = BLE_GAP_ADV_FP_ANY;
    m_adv_params.interval = NON_CONNECTABLE_ADV_INTERVAL;
    m_adv_params.duration = 0; // Never time out.
    err_code = ble_advdata_encode(&advdata, m_adv_data.adv_data.p_data, &m_adv_data.adv_data.len);
    err_code = sd_ble_gap_adv_set_configure(&m_adv_handle, &m_adv_data, &m_adv_params);
    /**@brief Function for starting advertising. */
    err_code = sd_ble_gap_adv_start(m_adv_handle, APP_BLE_CONN_CFG_TAG);
    /**@brief Function for initializing logging. */
    /**@brief Function for initializing LEDs. */
    ret_code_t err_code = bsp_init(BSP_INIT_LEDS, NULL);
    /**@brief Function for initializing timers. */
    static void timers_init(void)
    /**@brief Function for initializing power management. */
    nrf_pwr_mgmt_run();
    // Initialize.
    log_init();
    timers_init();
    leds_init();
    ble_stack_init();
    advertising_init();
    // Start execution.
    NRF_LOG_INFO("Beacon/Tag started.");
    advertising_start();
    // Enter main loop.
    for (;; )
