NRF52832 BLE Scan
Hi
Can I get some idea on which functions to make changes to in order to scan and report(for example on uart) the number of ble devices present in NRF52832 kit range.
I know ble central uart example does the scan, but I don't seem to forward with which functions to start off with.
I am using NRF52832 micro devkit with softdevice s132.
  • Look at the Advertising Report Handler - on_adv_report()
    The central discovers devices after scan_start() has been called. The callback function scan_evt_handler is called with ble_gap_evt_adv_report_t when a device is discovered during scanning. You can then append the discovered device in a list with its UUID. A device can be discovered multiple times, you should therefore only append it, if it's not already in the list. See this sequence diagram.
     * Copyright (c) 2014 - 2018, Nordic Semiconductor ASA
     * All rights reserved.
     * @brief BLE LED Button Service central and client application main file.
     * This file contains the source code for a sample client application using the LED Button service.
    #include <stdint.h>
    #include <stdio.h>
    #include <string.h>
    #include "nrf_sdh.h"
    #include "nrf_sdh_ble.h"
    #include "nrf_sdh_soc.h"
    #include "nrf_pwr_mgmt.h"
    #include "app_timer.h"
    #include "boards.h"
    #include "bsp.h"
    #include "bsp_btn_ble.h"
    #include "ble.h"
    #include "ble_hci.h"
    #include "ble_advertising.h"
    #include "ble_conn_params.h"
    #include "ble_db_discovery.h"
    #include "ble_lbs_c.h"
    #include "nrf_ble_gatt.h"
    #include "nrf_ble_scan.h"
    #include "nrf_log.h"
    #include "nrf_log_ctrl.h"
    #define CENTRAL_SCANNING_LED            BSP_BOARD_LED_0                     /**< Scanning LED will be on when the device is scanning. */
    #define CENTRAL_CONNECTED_LED           BSP_BOARD_LED_1                     /**< Connected LED will be on when the device is connected. */
    #define LEDBUTTON_LED                   BSP_BOARD_LED_2                     /**< LED to indicate a change of state of the the Button characteristic on the peer. */
    #define SCAN_INTERVAL                   0x00A0                              /**< Determines scan interval in units of 0.625 millisecond. */
    #define SCAN_WINDOW                     0x0050                              /**< Determines scan window in units of 0.625 millisecond. */
    #define SCAN_DURATION                   0x0000                              /**< Timout when scanning. 0x0000 disables timeout. */
    #define MIN_CONNECTION_INTERVAL         MSEC_TO_UNITS(7.5, UNIT_1_25_MS)    /**< Determines minimum connection interval in milliseconds. */
    #define MAX_CONNECTION_INTERVAL         MSEC_TO_UNITS(30, UNIT_1_25_MS)     /**< Determines maximum connection interval in milliseconds. */
    #define SLAVE_LATENCY                   0                                   /**< Determines slave latency in terms of connection events. */
    #define SUPERVISION_TIMEOUT             MSEC_TO_UNITS(4000, UNIT_10_MS)     /**< Determines supervision time-out in units of 10 milliseconds. */
    #define LEDBUTTON_BUTTON_PIN            BSP_BUTTON_0                        /**< Button that will write to the LED characteristic of the peer */
    #define BUTTON_DETECTION_DELAY          APP_TIMER_TICKS(50)                 /**< Delay from a GPIOTE event until a button is reported as pushed (in number of timer ticks). */
    #define APP_BLE_CONN_CFG_TAG            1                                   /**< A tag identifying the SoftDevice BLE configuration. */
    #define APP_BLE_OBSERVER_PRIO           3                                   /**< Application's BLE observer priority. You shouldn't need to modify this value. */
    NRF_BLE_SCAN_DEF(m_scan);                                       /**< Scanning module instance. */
    BLE_LBS_C_DEF(m_ble_lbs_c);                                     /**< Main structure used by the LBS client module. */
    NRF_BLE_GATT_DEF(m_gatt);                                       /**< GATT module instance. */
    BLE_DB_DISCOVERY_DEF(m_db_disc);                                /**< DB discovery module instance. */
    //static char const m_target_periph_name[] = "Nordic_Blinky";     /**< Name of the device we try to connect to. This name is searched in the scan report data*/
    #define SCAN_LIST_REFRESH_INTERVAL 10000  // 10 sec
    static uint32_t device_number;
    #define FOUND_DEVICE_REFRESH_TIME APP_TIMER_TICKS(SCAN_LIST_REFRESH_INTERVAL) /**< Time after which the device list is clean and refreshed. */
    #define DEVICE_NAME_MAX_SIZE 20
    #define DEVICE_TO_FIND_MAX 50
    typedef struct
        bool      is_not_empty;                                   /**< Indicates that the structure is not empty. */
        uint16_t  size;                                           /**< Size of manuf data. */
        uint8_t   addr[BLE_GAP_ADDR_LEN];                         /**< Device address. */
        char      dev_name[DEVICE_NAME_MAX_SIZE];                 /**< Device name. */
        uint8_t   manuf_buffer[BLE_GAP_ADV_SET_DATA_SIZE_MAX];    /**< Buffer for storing an  manuf data. */
    } scanned_device_t;
    void device_list_print(scanned_device_t * p_device);
    scanned_device_t   m_device[DEVICE_TO_FIND_MAX];                 /**< Stores device info from scan data. */
    void scan_device_info_clear(void)
        memset(m_device, 0, sizeof(m_device));
        device_number = 0;
    /**@brief Function for printing the devices.
     *@details Function print list of devices.
     * @param[in] device      Pointer to the struct storing the scanned devices.
        NRF_LOG_INFO("Devices found %d", device_number);
        // We could now clear the list:
        scan_device_info_clear();
    scanned_device_t * scan_device_info_get(void)
        return m_device;
    typedef struct
        uint8_t * p_data;   /**< Pointer to data. */
        uint16_t  data_len; /**< Length of data. */
    } data_t;
    static void device_to_list_add(ble_gap_evt_adv_report_t const * p_adv_report)
        uint8_t  idx             = 0;
        uint16_t dev_name_offset = 0;
        uint16_t field_len;
        data_t   adv_data;
        // Initialize advertisement report for parsing
        adv_data.p_data   = (uint8_t *)p_adv_report->data.p_data;
        adv_data.data_len = p_adv_report->data.len;
        for ( idx = 0; idx < DEVICE_TO_FIND_MAX; idx++)
            // If address is duplicated, then return.
            if (memcmp(p_adv_report->peer_addr.addr,
                       m_device[idx].addr,
                       sizeof(p_adv_report->peer_addr.addr)) == 0)
                return;
        // Device is not in the list.
        for (idx = 0; idx < DEVICE_TO_FIND_MAX; idx++)
            if (!m_device[idx].is_not_empty) // We find an empty entry
                   device_number = device_number +1;
                    m_device[idx].is_not_empty = true; //validating the list record
                    memset(m_device[idx].addr,
                    0,
                    sizeof(p_adv_report->peer_addr.addr));
                    memcpy(m_device[idx].addr,
                    return;
    /**@brief Function to handle asserts in the SoftDevice.
     * @param[in] line_num     Line number of the failing ASSERT call.
     * @param[in] p_file_name  File name of the failing ASSERT call.
        app_error_handler(0xDEADBEEF, line_num, p_file_name);
    /**@brief Function for the LEDs initialization.
     * @details Initializes all LEDs used by the application.
    static void leds_init(void)
    /**@brief Function to start scanning.
    static void scan_start(void)
        ret_code_t err_code;
        err_code = nrf_ble_scan_start(&m_scan);
        bsp_board_led_off(CENTRAL_CONNECTED_LED);
        bsp_board_led_on(CENTRAL_SCANNING_LED);
        // For readability.
        ble_gap_evt_t const * p_gap_evt = &p_ble_evt->evt.gap_evt;
            // Upon connection, check which peripheral has connected (HR or RSC), initiate DB
            // discovery, update LEDs status and resume scanning if necessary. */
            case BLE_GAP_EVT_CONNECTED:
                NRF_LOG_INFO("Connected.");
    //            err_code = ble_lbs_c_handles_assign(&m_ble_lbs_c, p_gap_evt->conn_handle, NULL);
    //            APP_ERROR_CHECK(err_code);
    //            err_code = ble_db_discovery_start(&m_db_disc, p_gap_evt->conn_handle);
                // Update LEDs status, and check if we should be looking for more
                // peripherals to connect to.
                bsp_board_led_on(CENTRAL_CONNECTED_LED);
                bsp_board_led_off(CENTRAL_SCANNING_LED);
            } break;
            // Upon disconnection, reset the connection handle of the peer which disconnected, update
            // the LEDs status and start scanning again.
                NRF_LOG_INFO("Disconnected.");
                scan_start();
            } break;
            case BLE_GAP_EVT_TIMEOUT:
                // We have not specified a timeout for scanning, so only connection attemps can timeout.
                if (p_gap_evt->params.timeout.src == BLE_GAP_TIMEOUT_SRC_CONN)
                    NRF_LOG_DEBUG("Connection request timed out.");
            } break;
            case BLE_GAP_EVT_CONN_PARAM_UPDATE_REQUEST:
                // Accept parameters requested by peer.
                err_code = sd_ble_gap_conn_param_update(p_gap_evt->conn_handle,
                                            &p_gap_evt->params.conn_param_update_request.conn_params);
            } break;
                ble_gap_phys_t const phys =
                    .rx_phys = BLE_GAP_PHY_AUTO,
                    .tx_phys = BLE_GAP_PHY_AUTO,
            } break;
            case BLE_GATTC_EVT_TIMEOUT:
            } break;
            case BLE_GATTS_EVT_TIMEOUT:
            } break;
                // No implementation needed.
     * @details Initializes the SoftDevice and the BLE event interrupts.
        uint32_t ram_start = 0;
        // Enable BLE stack.
    /**@brief Function for handling events from the button handler module.
     * @param[in] pin_no        The pin that the event applies to.
     * @param[in] button_action The button action (press/release).
    static void button_event_handler(uint8_t pin_no, uint8_t button_action)
        switch (pin_no)
            case LEDBUTTON_BUTTON_PIN:
                //APP_ERROR_HANDLER(pin_no);
    /**@brief Function for handling Scaning events.
     * @param[in]   p_scan_evt   Scanning event.
    static void scan_evt_handler(scan_evt_t const * p_scan_evt)
        switch(p_scan_evt->scan_evt_id)
            case NRF_BLE_SCAN_EVT_CONNECTING_ERROR:
                err_code = p_scan_evt->params.connecting_err.err_code;
             case NRF_BLE_SCAN_EVT_NOT_FOUND:
                 device_to_list_add(p_scan_evt->params.p_not_found);
    /**@brief Function for initializing the button handler module.
    static void buttons_init(void)
        //The array must be static because a pointer to it will be saved in the button handler module.
        static app_button_cfg_t buttons[] =
            {LEDBUTTON_BUTTON_PIN, false, BUTTON_PULL, button_event_handler}
        err_code = app_button_init(buttons, ARRAY_SIZE(buttons),
                                   BUTTON_DETECTION_DELAY);
    /**@brief Function for initializing the log.
    static void log_init(void)
    /**@brief Function for handling the list_timer event,
    static void adv_list_timer_handle(void * p_context)
        // Print devices
        scanned_device_t * p_device_list = scan_device_info_get();
        device_list_print(p_device_list);
        //scan_device_info_clear();
    /**@brief Function for initializing the timer.
    static void timer_init(void)
        // Timer for refreshing scanned devices data.
        APP_TIMER_DEF(adv_list_timer);
        err_code = app_timer_create(&adv_list_timer, APP_TIMER_MODE_REPEATED, adv_list_timer_handle);
        err_code = app_timer_start(adv_list_timer, FOUND_DEVICE_REFRESH_TIME, NULL);
    /**@brief Function for initializing the Power manager. */
    static void scan_init(void)
        nrf_ble_scan_init_t init_scan;
        memset(&init_scan, 0, sizeof(init_scan));
        init_scan.connect_if_match = false;
        init_scan.conn_cfg_tag     = APP_BLE_CONN_CFG_TAG;
        err_code = nrf_ble_scan_init(&m_scan, &init_scan, scan_evt_handler);
    //    // Setting filters for scanning.
    //    err_code = nrf_ble_scan_filters_enable(&m_scan, NRF_BLE_SCAN_NAME_FILTER, false);
    //    err_code = nrf_ble_scan_filter_set(&m_scan, SCAN_NAME_FILTER, m_target_periph_name);
    /**@brief Function for initializing the GATT module.
    static void gatt_init(void)
        ret_code_t err_code = nrf_ble_gatt_init(&m_gatt, NULL);
     * @details Handle any pending log operation(s), then sleep until the next event occurs.
        NRF_LOG_FLUSH();
        nrf_pwr_mgmt_run();
        // Initialize.
        log_init();
        timer_init();
        leds_init();
        buttons_init();
        power_management_init();
        ble_stack_init();
        scan_init();
        gatt_init();
        // Start execution.
        NRF_LOG_INFO("BLE scanner example started, will print the number of devices found after %d seconds",SCAN_LIST_REFRESH_INTERVAL/1000);
        scan_start();
        // Turn on the LED to signal scanning.
        // Enter main loop.
        for (;;)
            idle_state_handle();
    Best regards
    Jared.
    thanks a lot for this answer, it helped me a lot because I was looking for the same thing. I have one question though:
    Where the device name is located? is it supposed to be sent within an adv packet? According to the "ble_gap_evt_adv_report_t" struct, its field "data" of type "ble_data_t" is the received adv or scan response data (ble_gap.h file). The struct "ble_data_t" contains a uint8_t pointer and a uint16_t length. Is the device name located in there? I'm doing this inside the function "device_to_list_add()", when a device is not in the list:
    uint8_t * aux = p_adv_report->data.p_data;
    uint16_t aux_len = p_adv_report->data.len;
    uint8_t aux_array[100] = {};
    memcpy(aux_array,aux,aux_len);
    printf("Adv Data %x\r\n",aux_array);
    Thanks a lot for your help
  • ////////////////////////////////// RFID READER V1.0.0 2024 //////////////////////////
    /* 2024 */
    /* R&D EMBEDDED TEAM */
    /* RFID PROJECT */
    /* ACTIVE RFID & ACTIVE TAG */
    /* CENTRAL */
    /* EMPLOYEE ID 013 */
    #include <stdint.h>
    #include <stdio.h>
    #include <string.h>
    #include "boards.h"
    #include "bsp.h"
    #include "ble.h"
    static char const m_target_periph_name[] = "(NORDIC)"; /**< Name of the device we try to connect to. This name is searched in the scan report data*/
    #define SCAN_LIST_REFRESH_INTERVAL 10000 // 100 sec
    typedef struct
    uint8_t data_buffer[BLE_GAP_ADV_SET_DATA_SIZE_MAX]; /**< Buffer for storing an manuf data. */
    uint8_t rssi ;
    } scanned_device_t;
    device_number = 0;
    return m_device;
    typedef struct
    } data_t;
    uint8_t idx = 0;
    uint16_t field_len;
    int i = 0;
    data_t adv_data;
    m_device[idx].addr,
    return;
    0,
    //###=========================================ADVERTIZED DATA SCAN SUCCESSFUL =######=========================================================###//
    /*88888888888888888888888888888888888888888888888 NAME OF DEVICE IN LITERAL 888888888888888888888888888888888888888888888888888*/
    //////////////////////////////////////////////////// TOTAL NO OF DEVICE //////////////////////////////////////////////////////////////
    NRF_LOG_INFO("[TOTAL NUM].DEVS:%d Count\r\n",device_number);
    printf("[TOTAL NUM].DEVS:%d Count\r\n",device_number);
    m_device[idx].rssi = p_adv_report->rssi;
    printf("[SIGNAL ].RSSI:%d dBm\r\n",m_device[idx].rssi);
    ///////////////////////////////////////////// SIGNAL STRENGTH INDEX ////////////////////////////////////////////////////////////////////////
    /////////////////////////// APPLICATION RFID(CENTRAL) DETECTION DATA>> TAG(PHERIFERIAL) //////////////////////////////////////////////////////////////
    //uint8_t * full_name_data = ble_advdata_parse(m_device[idx].data_buffer, m_device[idx].size,BLE_GAP_AD_TYPE_COMPLETE_LOCAL_NAME);
    uint16_t len_full_name = ble_advdata_search(m_device[idx].data_buffer,m_device[idx].size, &dev_name_offset,BLE_GAP_AD_TYPE_COMPLETE_LOCAL_NAME);
    memset(m_device[idx].dev_name,
    0,
    len_full_name);
    memcpy(m_device[idx].dev_name,
    &m_device[idx].data_buffer[dev_name_offset],
    len_full_name);
    printf("[SIGNATURE].NAME:");
    for(i=0; i<len_full_name;i++)
    printf("%c",m_device[idx].data_buffer[dev_name_offset+i]);
    printf("\r\n");
    /*88888888888888888888888888888888888888888888888 NAME OF DEVICE IN HEX 88888888888888888888888888888888888888888888888*/
    printf("[HEX ID ].ADDR:");
    for(i=0; i< (uint16_t)(sizeof(p_adv_report->peer_addr.addr));i++)
    if(i==0)
    printf("%02X",m_device[idx].addr[i]);
    printf(":%02X",m_device[idx].addr[i]); //add colon in order to give format to address
    printf("\r\n");
    // ##### if you do not want to print adv data then comment #####////
    m_device[idx].size = p_adv_report->data.len;
    memset(m_device[idx].data_buffer,
    0,
    p_adv_report->data.len);
    memcpy(m_device[idx].data_buffer,
    p_adv_report->data.p_data,
    printf("[ADV DATA ].DATA:");
    for(i=0; i< p_adv_report->data.len;i++)
    printf("%x",m_device[idx].data_buffer[i]);
    printf("\r\n");
    /* DATA */
    printf("[ADV DATA ].DATA:%x\r\n",aux_array);
    return;
    * @param[in] p_ble_evt Bluetooth stack event.
    * @param[in] p_context Unused.
    // For readability.
    } break;
    scan_start();
    } break;
    } break;
    } break;
    } break;
    } break;
    } break;
    switch (pin_no)
    // Print devices
    NRF_LOG_FLUSH();
    nrf_pwr_mgmt_run();
    // Initialize.
    log_init();
    timer_init();
    leds_init();
    buttons_init();
    ble_stack_init();
    scan_init();
    gatt_init();
    // Start execution.
    NRF_LOG_INFO("[[BLE [RFID V1.0.0] Scanner Started]] Total: %d seconds",SCAN_LIST_REFRESH_INTERVAL/1000);
    scan_start();
    // Enter main loop.
    for (;;)
  • i need help in above code to add putty/mobaxterm for mode of UART COMMUNICATION , CAN PRINT ALL DATA AT SAME TIME OF SCAN IN SERIAL. WHAT BI NEED TO MODIFY
    REGARD SHAMBHU
