Application UART pin shifting operation in interrupt routine
Hi Every one,
I am trying to use two uart's communications concurrently  in nrf51422, in my code i am running timer of one second.
Every one second in timer routine trying to shift UART pins by using app_uart_close(); and uart_init(); functions with new pin set of RX & TX.
while it leaving Interrupt routine again initializing with older UART pins.
i got a problem with UART communication after switching to  second UART it unable to send proper values.
(it is sending only first character of second UART).
please help me is that is correct way to do shifting of UART communication pins?
please follow my attached code for better understanding.
/* timer handler for Every one second */
static void Energy_meter_handler(void * p_context)
uint32_t err_code;
nrf_delay_ms(5);
printf("UART 1 closed");
err_code=app_uart_close();     // Closing main UART
nrf_delay_ms(25);
Uart_Init1();                              // initializing with new UART pins
nrf_delay_ms(25);
printf("UART 2 opened");
/* operations on second UART */
if(!ENG_SET)
Set_Energy_meter_Reg();
Read_Values_from_Energy_Meter();
Energy_Meter=false;
printf("UART 2 closed");
err_code=app_uart_close();    // Closing Second UART
nrf_delay_ms(25);
uart_init();                               // re-initializing with previous UART
nrf_delay_ms(25);
printf("UART 1 opened");
Calculate_values();
printf("\n\rVrms : %f\tIrms : %f\n",VOL_RMS,CUR_RMS);
nrf_delay_ms(5);
Thanks in Advance.
  • This is an example taken in SDK11 from BLE uart code for nrf51422, please check
    Thanks & regards
    Ram
    This is my Code
    /* Copyright (c) 2014 Nordic Semiconductor. All Rights Reserved.
     * The information contained herein is property of Nordic Semiconductor ASA.
     * Terms and conditions of usage are described in detail in NORDIC
     * SEMICONDUCTOR STANDARD SOFTWARE LICENSE AGREEMENT.
     * Licensees are granted free, non-transferable use of the information. NO
     * WARRANTY of ANY KIND is provided. This heading must NOT be removed from
     * the file.
    /** @file
     * @defgroup ble_sdk_uart_over_ble_main main.c
     * @ingroup  ble_sdk_app_nus_eval
     * @brief    UART over BLE application main file.
     * This file contains the source code for a sample application that uses the Nordic UART service.
     * This application uses the @ref srvlib_conn_params module.
    #include <stdint.h>
    #include <string.h>
    #include "nordic_common.h"
    #include "nrf.h"
    #include "ble_hci.h"
    #include "ble_advdata.h"
    #include "ble_advertising.h"
    #include "ble_conn_params.h"
    #include "softdevice_handler.h"
    #include "app_timer.h"
    #include "app_button.h"
    #include "ble_nus.h"
    #include "app_uart.h"
    #include "bsp.h"
    #include "bsp_btn_ble.h"
    #include <nrf_delay.h>
    #define IS_SRVC_CHANGED_CHARACT_PRESENT 0                                           /**< Include the service_changed characteristic. If not enabled, the server's database cannot be changed for the lifetime of the device. */
    #define CENTRAL_LINK_COUNT              0                                           /**< Number of central links used by the application. When changing this number remember to adjust the RAM settings*/
    #define PERIPHERAL_LINK_COUNT           1                                           /**< Number of peripheral links used by the application. When changing this number remember to adjust the RAM settings*/
    #define DEVICE_NAME                     "Nordic_UART"                               /**< Name of device. Will be included in the advertising data. */
    #define NUS_SERVICE_UUID_TYPE           BLE_UUID_TYPE_VENDOR_BEGIN                  /**< UUID type for the Nordic UART Service (vendor specific). */
    #define APP_ADV_INTERVAL                64                                          /**< The advertising interval (in units of 0.625 ms. This value corresponds to 40 ms). */
    #define APP_ADV_TIMEOUT_IN_SECONDS      180                                         /**< The advertising timeout (in units of seconds). */
    #define APP_TIMER_PRESCALER             0                                           /**< Value of the RTC1 PRESCALER register. */
    #define APP_TIMER_OP_QUEUE_SIZE         4                                           /**< Size of timer operation queues. */
    #define MIN_CONN_INTERVAL               MSEC_TO_UNITS(20, UNIT_1_25_MS)             /**< Minimum acceptable connection interval (20 ms), Connection interval uses 1.25 ms units. */
    #define MAX_CONN_INTERVAL               MSEC_TO_UNITS(75, UNIT_1_25_MS)             /**< Maximum acceptable connection interval (75 ms), Connection interval uses 1.25 ms units. */
    #define SLAVE_LATENCY                   0                                           /**< Slave latency. */
    #define CONN_SUP_TIMEOUT                MSEC_TO_UNITS(4000, UNIT_10_MS)             /**< Connection supervisory timeout (4 seconds), Supervision Timeout uses 10 ms units. */
    #define FIRST_CONN_PARAMS_UPDATE_DELAY  APP_TIMER_TICKS(5000, APP_TIMER_PRESCALER)  /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
    #define NEXT_CONN_PARAMS_UPDATE_DELAY   APP_TIMER_TICKS(30000, APP_TIMER_PRESCALER) /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
    #define MAX_CONN_PARAMS_UPDATE_COUNT    3                                           /**< Number of attempts before giving up the connection parameter negotiation. */
    #define DEAD_BEEF                       0xDEADBEEF                                  /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
    #define UART_TX_BUF_SIZE                256                                         /**< UART TX buffer size. */
    #define UART_RX_BUF_SIZE                256                                         /**< UART RX buffer size. */
    static ble_nus_t                        m_nus;                                      /**< Structure to identify the Nordic UART Service. */
    static uint16_t                         m_conn_handle = BLE_CONN_HANDLE_INVALID;    /**< Handle of the current connection. */
    static ble_uuid_t                       m_adv_uuids[] = {{BLE_UUID_NUS_SERVICE, NUS_SERVICE_UUID_TYPE}};  /**< Universally unique service identifier. */
    APP_TIMER_DEF(Energy_meter_timer_id);
    /**@brief Function for assert macro callback.
     * @warning This handler is an example only and does not fit a final product. You need to analyse
     * @param[in] line_num    Line number of the failing ASSERT call.
     * @param[in] p_file_name File name of the failing ASSERT call.
     *          the device. It also sets the permissions and appearance.
        uint32_t                err_code;
                                              strlen(DEVICE_NAME));
    /**@brief Function for handling the data from the Nordic UART Service.
     * @details This function will process the data received from the Nordic UART BLE Service and send
     *          it to the UART module.
     * @param[in] p_nus    Nordic UART Service structure.
     * @param[in] p_data   Data to be send to UART module.
     * @param[in] length   Length of the data.
    /**@snippet [Handling the data received over BLE] */
    static void nus_data_handler(ble_nus_t * p_nus, uint8_t * p_data, uint16_t length)
        for (uint32_t i = 0; i < length; i++)
            while(app_uart_put(p_data[i]) != NRF_SUCCESS);
        while(app_uart_put('\n') != NRF_SUCCESS);
        uint32_t       err_code;
        ble_nus_init_t nus_init;
    /**@brief Function for handling an event from the Connection Parameters Module.
     * @details This function will be called for all events in the Connection Parameters Module
     *          which are passed to the application.
     * @note All this function does is to disconnect. This could have been done by simply setting
     *       the disconnect_on_fail config parameter, but instead we use the event handler
     *       mechanism to demonstrate its use.
        uint32_t err_code;
        if(p_evt->evt_type == BLE_CONN_PARAMS_EVT_FAILED)
    /**@brief Function for handling errors from the Connection Parameters module.
        APP_ERROR_HANDLER(nrf_error);
        // Prepare wakeup buttons.
        uint32_t err_code;
        switch (ble_adv_evt)
            case BLE_ADV_EVT_FAST:
            case BLE_ADV_EVT_IDLE:
                sleep_mode_enter();
    /**@brief Function for the application's SoftDevice event handler.
     * @param[in] p_ble_evt SoftDevice event.
    static void on_ble_evt(ble_evt_t * p_ble_evt)
        uint32_t                         err_code;
            case BLE_GAP_EVT_CONNECTED:
                // Pairing not supported
                // No implementation needed.
    /**@brief Function for dispatching a SoftDevice event to all modules with a SoftDevice
     *        event handler.
     * @details This function is called from the SoftDevice event interrupt handler after a
     *          SoftDevice event has been received.
    static void ble_evt_dispatch(ble_evt_t * p_ble_evt)
        ble_conn_params_on_ble_evt(p_ble_evt);
        ble_nus_on_ble_evt(&m_nus, p_ble_evt);
        ble_advertising_on_ble_evt(p_ble_evt);
        bsp_btn_ble_on_ble_evt(p_ble_evt);
    /**@brief Function for the SoftDevice initialization.
     * @details This function initializes the SoftDevice and the BLE event interrupt.
        uint32_t err_code;
        nrf_clock_lf_cfg_t clock_lf_cfg = NRF_CLOCK_LFCLKSRC;
        // Initialize SoftDevice.
        SOFTDEVICE_HANDLER_INIT(&clock_lf_cfg, NULL);
        ble_enable_params_t ble_enable_params;
        err_code = softdevice_enable_get_default_config(CENTRAL_LINK_COUNT,
                                                        PERIPHERAL_LINK_COUNT,
                                                        &ble_enable_params);
        //Check the ram settings against the used number of links
        CHECK_RAM_START_ADDR(CENTRAL_LINK_COUNT,PERIPHERAL_LINK_COUNT);
        // Enable BLE stack.
        err_code = softdevice_enable(&ble_enable_params);
        // Subscribe for BLE events.
        err_code = softdevice_ble_evt_handler_set(ble_evt_dispatch);
     * @param[in]   event   Event generated by button press.
        uint32_t err_code;
        switch (event)
            case BSP_EVENT_SLEEP:
                sleep_mode_enter();
            case BSP_EVENT_DISCONNECT:
                err_code = sd_ble_gap_disconnect(m_conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION);
            case BSP_EVENT_WHITELIST_OFF:
                err_code = ble_advertising_restart_without_whitelist();
     *          a string. The string will be be sent over BLE when the last character received was a
     *          'new line' i.e '\n' (hex 0x0D) or if the string has reached a length of
     *          @ref NUS_MAX_DATA_LENGTH.
    /**@snippet [Handling the data received over UART] */
        static uint8_t index = 0;
        uint32_t       err_code;
        switch (p_event->evt_type)
            case APP_UART_DATA_READY:
                index++;
                if ((data_array[index - 1] == '\n') || (index >= (BLE_NUS_MAX_DATA_LEN)))
                    err_code = ble_nus_string_send(&m_nus, data_array, index);
                    index = 0;
            case APP_UART_FIFO_ERROR:
    /**@brief  Function for initializing the UART module.
    /**@snippet [UART Initialization] */
    static void uart_init(void)
        const app_uart_comm_params_t comm_params =
            RX_PIN_NUMBER,
            TX_PIN_NUMBER,
            RTS_PIN_NUMBER,
            CTS_PIN_NUMBER,
            APP_UART_FLOW_CONTROL_ENABLED,
            false,
            UART_BAUDRATE_BAUDRATE_Baud115200
        APP_UART_FIFO_INIT( &comm_params,
                           UART_RX_BUF_SIZE,
                           UART_TX_BUF_SIZE,
                           uart_event_handle,
                           APP_IRQ_PRIORITY_LOW,
                           err_code);
    /**@snippet [UART2 Initialization] */
    static void uart_init2(void)
            RX_PIN_NUMBER1,
            TX_PIN_NUMBER1,
            RTS_PIN_NUMBER,
            CTS_PIN_NUMBER,
            APP_UART_FLOW_CONTROL_DISABLED,
            false,
                           UART_RX_BUF_SIZE,
                           UART_TX_BUF_SIZE,
                           NULL,
                           err_code);
        uint32_t      err_code;
        ble_advdata_t advdata;
        ble_advdata_t scanrsp;
        // Build advertising data struct to pass into @ref ble_advertising_init.
        memset(&advdata, 0, sizeof(advdata));
        advdata.name_type          = BLE_ADVDATA_FULL_NAME;
        advdata.include_appearance = false;
        advdata.flags              = BLE_GAP_ADV_FLAGS_LE_ONLY_LIMITED_DISC_MODE;
        memset(&scanrsp, 0, sizeof(scanrsp));
        scanrsp.uuids_complete.uuid_cnt = sizeof(m_adv_uuids) / sizeof(m_adv_uuids[0]);
        scanrsp.uuids_complete.p_uuids  = m_adv_uuids;
        ble_adv_modes_config_t options = {0};
        options.ble_adv_fast_enabled  = BLE_ADV_FAST_ENABLED;
        options.ble_adv_fast_interval = APP_ADV_INTERVAL;
        options.ble_adv_fast_timeout  = APP_ADV_TIMEOUT_IN_SECONDS;
        err_code = ble_advertising_init(&advdata, &scanrsp, &options, on_adv_evt, NULL);
        bsp_event_t startup_event;
        uint32_t err_code = bsp_init(BSP_INIT_LED | BSP_INIT_BUTTONS,
                                     APP_TIMER_TICKS(100, APP_TIMER_PRESCALER),
                                     bsp_event_handler);
    /**@brief Function for placing the application in low power state while waiting for events.
    static void power_manage(void)
        uint32_t err_code = sd_app_evt_wait();
    /**@brief .Energy meter timer hadler
    static void Energy_meter_handler(void)
    		printf("\n\r handler Closing first UART\n\r");
    		nrf_delay_ms(5);
    		app_uart_close();
    		nrf_delay_ms(25);
    		uart_init2();
    		nrf_delay_ms(25);
    		printf("\n\r handler Second UART DATA\n\r");
    		app_uart_close();
    		nrf_delay_ms(25);
    		uart_init();
    		nrf_delay_ms(25);
    		printf("\n\r handler Re initializing uart 1\n\r");
    		nrf_delay_ms(5);
    /**@brief Application main function.
        uint32_t err_code;
        bool erase_bonds;
        // Initialize.
        APP_TIMER_INIT(APP_TIMER_PRESCALER, APP_TIMER_OP_QUEUE_SIZE, false);
        uart_init();
        ble_stack_init();
        gap_params_init();
        services_init();
        advertising_init();
        conn_params_init();
    		err_code = app_timer_create(&Energy_meter_timer_id,APP_TIMER_MODE_REPEATED,Energy_meter_handler);
    		err_code = app_timer_start(Energy_meter_timer_id, APP_TIMER_TICKS(1000, APP_TIMER_PRESCALER), NULL);
        printf("\r\nUART Start!\r\n");
        err_code = ble_advertising_start(BLE_ADV_MODE_FAST);
    		// Enter main loop.
        for (;;)
            power_manage();
  • Have you made sure you have disabled flow control on the receiving side, when you start the second UART transfer?
