SAADC + BLE UART (NUS), The saadc_callback function doesnt execute.
Hi
I'm using NRF52840 + SDK15.0.0 and softdevice 6.0.0
I have joined two program one is ble_app_uart  and other SAADC capturing ultrasound noise. (Saadc program works perfectly alone, without softdevice, BLE, etc)
The idea is when the device is connected to cellphone, and the cellphone send "!" by UART, the device start to measure the SAADC and sends the ultrasound data by NUS.
I have assigned SAADC in the timer1. (static const nrf_drv_timer_t    m_timer = NRF_DRV_TIMER_INSTANCE(1);)  Even I testedin the timer2
My problem is when activate SAADC (saadc_sampling_event_enable();) the SAADC fuction doesnt execute event saadc_callback, it seems does nothing.
I have writen some output to terminal if the program execute the saadc_callback, but the saadc_callback doesnt running.
I have change the priority of the SAADC to 2. But It didnt work.
Any Sugestion?
Ricardo
    uint32_t err_code;
    for (uint32_t i = 0; i < p_evt->params.rx_data.length; i++)
      do
        err_code = app_uart_put(p_evt->params.rx_data.p_data[i]);
        if ((err_code != NRF_SUCCESS) && (err_code != NRF_ERROR_BUSY))
          NRF_LOG_ERROR("Failed receiving NUS message. Error 0x%x. ", err_code);
      } while (err_code == NRF_ERROR_BUSY);
    if (p_evt->params.rx_data.p_data[p_evt->params.rx_data.length - 1] == '\r')
      while (app_uart_put('\n') == NRF_ERROR_BUSY);
    if(p_evt->params.rx_data.p_data[0] == '!')
    Datos_Capturados_Ultrasonido    = false;
    Capturar_datos_SAADC            = true;
    RealFFT_Instance.fftLenReal= Total_samples;
    // ***** HERE IS MY PROBOLEM  ************
    while (!Datos_Capturados_Ultrasonido){}  // HERE...
    // I created the while, because I wait to the data is readed ok...
    saadc_sampling_event_disable();
    uint8_t Ble_transfer[0]= FFT_Real[0];
    uint8_t Ble_transfer[1][] = (uint8_t)FFT_Real[0];
    uint16_t length = (uint16_t)sizeof(FFT_Real[0]);
    memcpy(Ble_transfer[0], FFT_Real[0], 0x100); //lenght
      err_code = ble_nus_data_send(&m_nus, Ble_transfer[0], &length, m_conn_handle);  //&length
      if ( (err_code != NRF_ERROR_INVALID_STATE) && (err_code != NRF_ERROR_BUSY) &&
          (err_code != NRF_ERROR_NOT_FOUND) )
  ret_code_t err_code;
  //NRF_LOG_INFO("FUERA DEL LOOP");
  //printf("fuera del loop %d \r\n",loop_number);
  //NRF_LOG_FLUSH();
if (Capturar_datos_SAADC)
    NRF_LOG_INFO("Loop ultrasonido numero");
    printf("Loop ultrasonido numero %d \r\n",loop_number);
    NRF_LOG_FLUSH();
    loop_number++;
    err_code =  nrf_drv_saadc_buffer_convert(p_event->data.done.p_buffer, SAMPLES_IN_BUFFER);
    for (int k=0;k<SAMPLES_IN_BUFFER;k++)
      In_Data[muestra][k] = (int16_t)((p_event->data.done.p_buffer[k]-512)<<8); //
    if (muestra==(muestreos))
      Datos_Capturados_Ultrasonido = true;
      // nrf_drv_timer_pause(&m_timer);
      memset(FFT_Complex, 0, sizeof FFT_Complex);
      memset(In_Data, 0, sizeof In_Data);
      memset(FFT_Real, 0, sizeof FFT_Real);
      memset(p_event->data.done.p_buffer, 0, sizeof p_event->data.done.p_buffer);
      m_adc_evt_counter=0;
      //nrf_drv_timer_resume(&m_timer);
      muestra=0;
      muestra++;
Main
  muestra = 0;
  bool erase_bonds;
  uart_init();
  log_init();
  timers_init();
  power_management_init();
  ble_stack_init();
  gap_params_init();
  gatt_init();
  services_init();
  advertising_init();
  conn_params_init();
  // SAADC START
  printf("UART 1.\r\n");
  saadc_sampling_event_init();
  saadc_init();
  //saadc_sampling_event_enable();
  printf("SAADC Configured.\r\n");
  // Start execution.
  advertising_start();
  // Enter main loop.
  for (;;)
    idle_state_handle();
void timer_handler(nrf_timer_event_t event_type, void * p_context)
  uint32_t ticks = nrf_drv_timer_us_to_ticks(&m_timer,10);  //HERE THE TIMER If i use 50 it is for 10.000 hz
                                 NRF_TIMER_CC_CHANNEL0,
                                 ticks,
                                 NRF_TIMER_SHORT_COMPARE0_CLEAR_MASK,
                                 false);
  uint32_t timer_compare_event_addr = nrf_drv_timer_compare_event_address_get(&m_timer,
        NRF_TIMER_CC_CHANNEL0);
  //setup ppi channel so that timer compare event is triggering sample task in SAADC
                                        timer_compare_event_addr,
                                        saadc_sample_task_addr);
void saadc_sampling_event_disable(void)
  ret_code_t err_code = nrf_drv_ppi_channel_disable(m_ppi_channel);
void saadc_init(void)
  nrf_saadc_channel_config_t channel_config =
    NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(NRF_SAADC_INPUT_AIN0);
  channel_config.acq_time         = NRF_SAADC_ACQTIME_3US;
  channel_config.burst            = NRF_SAADC_BURST_ENABLED   ;                           //NRF_SAADC_BURST_DISABLED  es mas lento  ///< Burst mode is enabled. SAADC takes 2^OVERSAMPLE number of samples as fast as it can, and sends the average to Data RAM.
  channel_config.reference        = NRF_SAADC_REFERENCE_VDD4;
  channel_config.gain             = NRF_SAADC_GAIN1_4;
  err_code = nrfx_saadc_calibrate_offset();
   //Configure SAADC
  nrf_drv_saadc_config_t saadc_config;// = NRF_DRV_SAADC_DEFAULT_CONFIG;
  saadc_config.low_power_mode     = false;                                          //true
  saadc_config.resolution         = NRF_SAADC_RESOLUTION_10BIT;
  saadc_config.oversample         = NRF_SAADC_OVERSAMPLE_DISABLED;                //NRF_SAADC_OVERSAMPLE_DISABLED;   NRF_SAADC_OVERSAMPLE_2X
  saadc_config.interrupt_priority = APP_IRQ_PRIORITY_LOWEST;                    //APP_IRQ_PRIORITY_LOW;
  err_code = nrf_drv_saadc_init(&saadc_config, saadc_callback);
  err_code = nrf_drv_saadc_channel_init(0, &channel_config);
  NRF_SAADC->SAMPLERATE  =  (1 << 12);                                          // Timer mode
  NRF_SAADC->SAMPLERATE  |= 80;                                                 // 16MHz / 80 counts = 200 000 triggers per second
  // See http://infocenter.nordicsemi.com/topic/com.nordic.infocenter.nrf52840.ps/saadc.html?cp=2_0_0_5_22_8_11#register.SAMPLERATE for details.
  err_code = nrf_drv_saadc_buffer_convert(m_buffer_pool[0], SAMPLES_IN_BUFFER);  //(m_buffer_pool[0], SAMPLES_IN_BUFFER);
  err_code = nrf_drv_saadc_buffer_convert(m_buffer_pool[1], SAMPLES_IN_BUFFER);
